Home » Eclipse Projects » JFace » How to provide own ValidationStatus without to bind a model-property to something?
How to provide own ValidationStatus without to bind a model-property to something? [message #20075] Fri, 10 July 2009 22:50 Go to next message
Originally posted by: TheRealHawk.Freenet.de
what I want to do is something like this:
final DataBindingContext _dbx = new DataBindingContext();
_dbx.bindValue(
null,
BeansObservables.observeValue(mybean, "myProperty"),
null,
new UpdateValueStrategy().setBeforeSetValidator(new MyValidator()));
For this behavior I created a NullObservableValue which does nothing.
Is there a better eclipse-way to do this?
I simply want to observe a bean and validate its complete state (e.g. all
start-date has to be before end-dates, currency values should be greater
than 0 and so on).
--> For this I want to add my own ValidationStatusProvider to the
DataBindingContext.
Markus
Re: How to provide own ValidationStatus without to bind a model-property to something? [message #20536 is a reply to message #20075] Mon, 13 July 2009 16:07 Go to previous messageGo to next message
Matthew Hall is currently offline Matthew HallFriend
Markus,
MultiValidator (despite the name being mismatched to what you're trying
to do) will help you here.
final IObservableValue myBeanObservable =
BeansObservables.observeValue(myBean, "myProperty");
MultiValidator myValidator = new MultiValidator() {
protected IStatus validate() {
SomeType propValue = myBeanObservable.getValue();
// Do validation on propValue and return an appropriate status
dbc.addValidationStatusProvider(myValidator);
Hope this helps,
Matthew
Markus Koch wrote:
> _dbx.bindValue(
> null,
> null,
> than 0 and so on).
> DataBindingContext.
> Markus
Re: How to provide own ValidationStatus without to bind a model-property to something? [message #20581 is a reply to message #20536] Mon, 13 July 2009 20:37 Go to previous message
This works.
Markus
"Matthew Hall" <matthall@woodcraftmill.com> schrieb im Newsbeitrag
news:h3fm3d$c27$2@build.eclipse.org...
> Markus,
> MultiValidator (despite the name being mismatched to what you're trying to
> Hope this helps,
> Matthew
> Markus Koch wrote:
>> _dbx.bindValue(
>> null,
>> null,
>> than 0 and so on).
>> DataBindingContext.
>> Markus
Previous Topic:Default menu item from a menu manager
Next Topic:[databinding] Binding same TableViewer with 2nd input
Current Time: Thu Dec 26 12:39:51 GMT 2024
Powered by FUDForum. Page generated in 0.03878 seconds
