Home » Language IDEs » Java Development Tools (JDT) » Search UI problems
Search UI problems [message #19998] Mon, 12 May 2003 12:01 Go to next message
I am having problems adding entries to the search results view. What should
the groupByKey parameter be in the addMatch method? I use a custom string
as below, but get a nullpointer error. I have got a handle on the view from
SearchUI. I also have a valid IResource How do I get one of these keys?
IMarker im = element.getResource().createMarker(SearchUI.SEARCH_MARKER);
im.setAttribute(IMarker.LINE_NUMBER, detailed.getSourceLineNumber());
im.setAttribute(IMarker.MESSAGE, elem.toString());
view.addMatch(elem.toString(), new
String("CME_RESULT"),element.getResource(), im);
Thanks for your help
Jon
Re: Search UI problems [message #20192 is a reply to message #19998] Mon, 12 May 2003 13:13 Go to previous messageGo to next message
>Jon
The groupBy stuff allows you to group multiple matches into one Search
view entry. Java search for example groups by Java elements i.e. if
there are multiple matches inside method only one entry is added to the
Search view and the number of matches is shown in the entry's label,
e.g.: myMethod() (2 matches). In your case the resource itself might be
a good candidate.
HTH
Dani
Re: Search UI problems [message #20202 is a reply to message #20192] Mon, 12 May 2003 14:37 Go to previous message
Thanks! Makes more sense.
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:b9okn6$697$1@rogue.oti.com...
should
string
from
> >Jon
> a good candidate.
> HTH
> Dani
Previous Topic:error=193: org.eclipse.core.runtime.CoreException[120]: java.io.IOException: CreateProcess: D:\j2sd1
Next Topic:how to change font
Current Time: Tue Nov 04 07:46:17 EST 2025
Powered by FUDForum. Page generated in 0.27334 seconds
