Home » Eclipse Projects » Eclipse Platform » PropertyPage's element
PropertyPage's element [message #1668] Tue, 22 April 2003 06:24 Go to next message
Hi all
i wonder why the PropertyPage (pages appears in the default properties
dialog) insist on making the element in it which is passed to the page as
IAdaptable else a class cast exception occurs.
in my case the object i want to see its properties is not IAdaptable and i
don't want it to implement this interface
i know that there are alot of usefulness of IAdaptable, but if i don't have
access to make my object implement that interface then i won't be able to
access its properties from the properties dialog
i hope someone from eclipse team answer me
thanks
joe
Re: PropertyPage's element [message #7782 is a reply to message #1668] Wed, 23 April 2003 17:15 Go to previous message
Originally posted by: John_Arthorne.oti.com_
The API for property pages is currently defined in terms of IAdaptable
(IWorkbenchPropertyPage). If you're passing a non IAdaptable as input,
then you must be using non-API to do so (hence the ClassCastExceptions).
If you want to request that this API be changed, I suggest entering a
feature request in bugzilla. For now, you can either make your object
implement IAdaptable, or pass in a wrapper object that implements
IAdaptable and that can return your object.
Joseph Khalil wrote:
> Hi all
> thanks
> joe
Previous Topic:USER-EXCLUDE in platform.cfg
Next Topic:make C-o open/show Outline view?
Current Time: Thu Apr 24 01:14:30 EDT 2025
Powered by FUDForum. Page generated in 0.03137 seconds
