Navigation History Problem!!! [message #207325] |
Mon, 08 March 2004 11:26 |
Originally posted by: res.cs.stir.ac.uk
I have the problem when starting up my editor I am presented with the
error:
org.eclipse.ui.internal.NavigationHistory$1.partClosed(Navig ationHistory.java:70)
at org.eclipse.ui.internal.PartListenerList$3.run(PartListenerL ist.java:89)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:813)
at org.eclipse.core.runtime.Platform.run(Platform.java:457)
org.eclipse.ui.internal.PartListenerList.firePartClosed(Part ListenerList.java:87)
org.eclipse.ui.internal.WorkbenchPage.firePartClosed(Workben chPage.java:1281)
org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:889)
org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:854)
at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:87 )
org.eclipse.ui.internal.TabbedEditorWorkbook$1.itemClosed(Ta bbedEditorWorkbook.java:132)
at org.eclipse.swt.custom.CTabFolder.closeNotify(CTabFolder.jav a:316)
at org.eclipse.swt.custom.CTabFolder.access$13(CTabFolder.java: 306)
at org.eclipse.swt.custom.CTabFolder$4.handleEvent(CTabFolder.j ava:447)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:847)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2311)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1992)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1506)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1482)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:246)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
in the error log. Can anybody help? Thanks in advance.
Ross
FUDForum. Page generated in 0.03761 seconds
