Home » Archived » BIRT » Hibernate on BIRT -Viewer Internal error problem
Hibernate on BIRT -Viewer Internal error problem [message #207022] Mon, 18 December 2006 09:24 Go to next message
In our project , we are using BIRT and hibernate
Running a simple birt scripted source with hibernate resulted in HTTP staus
500 internal error
in the viewer.
I see that this problem was posted before but with no solution for it.
Is this a bug ? any workarounds ?
Please reply , this is very critical in our project and may change our
decision of using birt or not.
Thanks , Shady
Re: Hibernate on BIRT -Viewer Internal error problem [message #207043 is a reply to message #207022] Mon, 18 December 2006 09:26 Go to previous messageGo to next message
The problem was stated here with no solution or reply:
http://dev.eclipse.org/newslists/news.eclipse.birt/msg11791. html
http://dev.eclipse.org/newslists/news.eclipse.birt/msg12482. html
"Shady" <sh_said@yahoo.com> wrote in message
news:em68bh$qk1$1@utils.eclipse.org...
> Hi
> staus 500 internal error
> in the viewer.
> Thanks , Shady
Re: Hibernate on BIRT -Viewer Internal error problem [message #207120 is a reply to message #207043] Mon, 18 December 2006 14:45 Go to previous message
Are you using hibernate only in a scripted ds? or ODA?
If you are using in a Scripted Data Set post your code. What version of
Hibernate and BIRT are you using.
Jason
news:em68ef$ttv$1@utils.eclipse.org...
>> Hi
>> in the viewer.
>> Thanks , Shady
Previous Topic:Instructions on deploying the BIRT WebViewerExample to WAS CE
Next Topic:Error create data set with computed column
Current Time: Thu Mar 13 16:18:35 EDT 2025
Powered by FUDForum. Page generated in 0.04799 seconds
