Home » Eclipse Projects » Babel » Babel server documentation
Babel server documentation [message #19932] Thu, 25 September 2008 11:25 Go to next message
Originally posted by: atoulme.intalio.com
it seems the Eclipse Babel instance uses .htaccess files or does
rewrites from the Apache config file.
Would it be ok to share those files or the conditional rules on the
Babel server development wiki page ?
Antoine
Re: Babel server documentation [message #19972 is a reply to message #19932] Thu, 25 September 2008 22:53 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
Antoine Toulme wrote:
> Antoine
Antoine, what makes you say we use rewrites? One thing I absolutely
*detest* is apps that use all kinds of clumsy and obscure rewrites just
to make URLs pretty.
Here are the relevant portions of the babel.eclipse.org Apache config.
As you'll see, we have AllowOverride None, so no .htaccess is used.
<VirtualHost *:80>
ServerAdmin webmaster@eclipse.org
ServerName babel.eclipse.org
DocumentRoot /home/data/httpd/babel.eclipse.org/html/
<Directory "/home/data/httpd/babel.eclipse.org/html/">
Options -Indexes -FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
</Directory>
Alias /babel /home/data/httpd/babel.eclipse.org/babel/html
<Directory /home/data/httpd/babel.eclipse.org/babel/html>
Options FollowSymLinks
DirectoryIndex index.php index.html
AllowOverride None
Order Allow,Deny
Allow From All
</Directory>
RewriteEngine On
# Redirect logins to https
RewriteRule ^/babel/login.php https://%{SERVER_NAME}/babel/login.php
</VirtualHost>
The base http://babel.eclipse.org is forwarded to
http://babel.eclipse.org/babel via index.php at the DocumentRoot:
Re: Babel server documentation [message #20008 is a reply to message #19972] Thu, 25 September 2008 22:54 Go to previous messageGo to next message
<?php
header("Location: babel/");
Re: Babel server documentation [message #20048 is a reply to message #19972] Thu, 25 September 2008 23:02 Go to previous messageGo to next message
>> Thanks,
>> Antoine
Sorry, that sounds a bit dry :-) What I meant was, what problem are
you encountering to consider rewrites an issue?
Re: Babel server documentation [message #20082 is a reply to message #20048] Fri, 26 September 2008 06:25 Go to previous messageGo to next message
> Sorry, that sounds a bit dry :-) What I meant was, what problem are you
No problem, I'm just looking for an elegant way to hide base.conf.
If it was just me, I would move it to /etc.
When trying to type its URL on babel, I get a 404, so either there is a
rewrite rule here, or you moved base.conf.
and how do you hide folder pages (for example someone trying this trick:
http://babel.eclipse.org/babel/js) ?
That might be really basic knowledge.
Antoine
Re: Babel server documentation [message #21324 is a reply to message #20082] Fri, 26 September 2008 13:30 Go to previous messageGo to next message
> Antoine
The server's base.conf is outside of the DocumentRoot, so it is not
accessible.
DocumentRoot = /home/data/httpd/babel.eclipse.org/html/
base.conf = /home/data/httpd/babel.eclipse.org/base.conf
We also disable Indexes so you can't get a listing of files in directories
You get good performance gains by specifying AllowOverride None (thus
disabling .htaccess files), in that Apache does not crawl the directory
tree looking for .htaccess files.
Re: Babel server documentation [message #21330 is a reply to message #21324] Fri, 26 September 2008 15:35 Go to previous messageGo to next message
> accessible.
Thank you, that was the info I was after.
Re: Babel server documentation [message #21335 is a reply to message #21330] Fri, 26 September 2008 23:29 Go to previous messageGo to next message
Denis, I think this info is missing from the wiki page:
http://wiki.eclipse.org/Babel_/_Server_Tool_Development_Proc ess
In particular the page says:
Alias /babel "/var/www/babel/server/html/"
<Directory "/var/www/babel/server/html/">
AllowOverride None
Order allow,deny
Allow from all
</Directory>
But since it is the documentRoot, why go about defining an alias ?
I think that's what threw me off, I have no good knowledge of Apache and
wouldn't have been too sure where to place the DocumentRoot.
Antoine
Re: Babel server documentation [message #21351 is a reply to message #21335] Mon, 29 September 2008 13:57 Go to previous message
When I wrote those docs my DocumentRoot wasn't
"/var/www/babel/server/html/". I've updated the docs to make the path
to babel more abstract.
Thanks for the suggestion :)
> AllowOverride None
> Order allow,deny
> Allow from all
> </Directory>
> Antoine
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: Babel server documentation [message #573949 is a reply to message #19932] Thu, 25 September 2008 22:53 Go to previous message
> Antoine
<VirtualHost *:80>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
AllowOverride None
Order Allow,Deny
Allow From All
</Directory>
RewriteEngine On
</VirtualHost>
Re: Babel server documentation [message #573979 is a reply to message #19972] Thu, 25 September 2008 22:54 Go to previous message
<?php
Re: Babel server documentation [message #574010 is a reply to message #19972] Thu, 25 September 2008 23:02 Go to previous message
>> Thanks,
>> Antoine
Re: Babel server documentation [message #574040 is a reply to message #20048] Fri, 26 September 2008 06:25 Go to previous message
Antoine
Re: Babel server documentation [message #574057 is a reply to message #20082] Fri, 26 September 2008 13:30 Go to previous message
> Antoine
accessible.
Re: Babel server documentation [message #574085 is a reply to message #21324] Fri, 26 September 2008 15:35 Go to previous message
> accessible.
Re: Babel server documentation [message #574111 is a reply to message #21330] Fri, 26 September 2008 23:29 Go to previous message
AllowOverride None
Order allow,deny
Allow from all
</Directory>
Antoine
Re: Babel server documentation [message #574189 is a reply to message #21335] Mon, 29 September 2008 13:57 Go to previous message
> AllowOverride None
> Order allow,deny
> Allow from all
> </Directory>
> Antoine
Previous Topic:errorLog() function
Next Topic:Galileo release plan, and how it will fit with Babel
Current Time: Sat Dec 21 15:12:13 GMT 2024
Powered by FUDForum. Page generated in 0.04713 seconds
