Home » Language IDEs » ServerTools (WTP) » Not able to create Any J2EE project
Not able to create Any J2EE project [message #206219] Mon, 31 December 2007 05:02 Go to next message
Originally posted by: inderjeet.singh.siemens.com
Hi All,
I am currently using the Eclipse WTP 0.7 version with JDK 1.4.2_10. It is
working perfectly fine. I normally work on web applications using the
eclipse environment along with JBoss as my server.
Now I was planning to switch to Eclipse WTP 2.0. I downloaded the file
"wtp-all-in-one-sdk-R-2.0-200706260303-win32.zip" from internet and tried
to use it. I extracted the file and opened the eclipse from it. Eclipse
3.3 opens but there is not option to create any J2EE project (EJB or
Dynamic web project) exists in this editor. Neither there is any J2EE
perspective. I tried to create a server runtime but there is only one
option of basic HTTP server and no other server is there.
Can someone help me that what am I missing to get all those options which
were there in WTP 0.7 but are missing in WTP 2.0
I am neither able to create a dynamic web project nor to create a new
Jboss server instance.... :-(
Thanks in Advance
Inder Jeet Singh
Re: Not able to create Any J2EE project [message #206228 is a reply to message #206219] Mon, 31 December 2007 06:36 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi !
which Java version do you use? Must plugins of Eclipse 3.3 require 1.5 (but you
can of course compile with previous java versions, 1.5 is only required for
startup).
Hope this helps
Wolfgang
Inder Jeet Singh schrieb:
> Hi All,
> is working perfectly fine. I normally work on web applications using the
> tried to use it. I extracted the file and opened the eclipse from it.
> Eclipse 3.3 opens but there is not option to create any J2EE project
> (EJB or Dynamic web project) exists in this editor. Neither there is any
> J2EE perspective. I tried to create a server runtime but there is only
> one option of basic HTTP server and no other server is there.
> which were there in WTP 0.7 but are missing in WTP 2.0
> Thanks in Advance
> Inder Jeet Singh
Re: Not able to create Any J2EE project [message #206282 is a reply to message #206228] Wed, 02 January 2008 06:44 Go to previous message
I changed my JDK to 1.5 and it all started working...... :-)
thanks for the help.
Previous Topic:Creting EJB project in JUnit test
Next Topic:Configuration Eclipse (Tomcat)
Current Time: Fri Mar 14 01:22:17 EDT 2025
Powered by FUDForum. Page generated in 0.05029 seconds
