bootclasspath [message #206138] |
Thu, 19 April 2007 15:31 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: pinosol.gmail.com
How can I set up bootclasspath in the project settings? I know only one
way to do it. It can be done through setting of JVM.
Re: bootclasspath [message #206727 is a reply to message #206625] |
Sun, 22 April 2007 21:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: eclipse5.rizzoweb.com
Asaf Yaffe wrote:
>> one way to do it. It can be done through setting of JVM.
> Why would you need that in the Project Settings? What are you trying to
> accomplish?
> If you want to define the bootclasspath when you launch a class from
> your project, create a launch configuration for the class, and add the
> -Xbootclasspath argument to the "VM Arguments" section of the
> "Arguments" tab.
An alternative to using -Xbootclasspath as an argument is to edit the
Classpath tab of the launch configuration - it has places to add both
bootstrap and application libraries to the runtime environment.
Hope this helps,
Eric
FUDForum. Page generated in 0.08019 seconds
