Home » Newcomers » Newcomers » Eclipse does not start - ExceptionInInitializerError
- Eclipse does not start - ExceptionInInitializerError [message #19795] Fri, 28 January 2005 23:25 Go to next message
Originally posted by: jerry_peng.yahoo.com
I am having problem starting up Eclipse on Solaris box. The exception
happens at the call of installFont(). Please help... Thanks in advance...
Configurations:
- Eclipse: 3.0.1-solaris-motif
- OS: Solaris 8
- JDK: 1.4.2_05
Eclipse start-up command:
> eclipse -data ~/workspace -vmargs -Xmx512m
Exception Trace:
!SESSION Jan 28, 2005 16:17:05.252
eclipse.buildId=M200409161125
java.version=1.4.2_05
BootLoader constants: OS=solaris, ARCH=sparc, WS=motif, NL=en
!ENTRY org.eclipse.osgi Jan 28, 2005 16:17:05.257
!MESSAGE Application error
!STACK 1
java.lang.ExceptionInInitializerError
org.eclipse.ui.internal.themes.ThemeElementHelper.installFon t(ThemeElementHelpe
r.java:97)
org.eclipse.ui.internal.themes.ThemeElementHelper.populateRe gistry(ThemeElement
Helper.java:54)
org.eclipse.ui.internal.Workbench.initializeFonts(Workbench. java:874)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:783)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1325)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.jav
a:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Caused by: java.lang.NullPointerException
org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.j
ava:85)
... 18 more
- Re: Eclipse does not start - ExceptionInInitializerError [message #21670 is a reply to message #19795] Mon, 31 January 2005 17:55 Go to previous message
I've found the answer!!! Finally after struggling for 3 weeks.
Please see a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=33828
I hope this helps whoever is using Reflection X on PC to access Sun WS.
-Jerry
Jerry wrote:
> Hello,
> Configurations:
> - OS: Solaris 8
> - JDK: 1.4.2_05
> Exception Trace:
> !STACK 1
> at
> r.java:97)
> at
> Helper.java:54)
> at
> at
> at
> at
> at
> a:335)
> at
> at
> at
> ava:85)
> ... 18 more
Previous Topic:SSL under IDE problem
Next Topic:J2SE 5.0 - generic types
Current Time: Thu Jan 09 03:28:00 GMT 2025
Powered by FUDForum. Page generated in 0.08676 seconds
