Saveing java-command (+ Classpath) into a shell scipt [message #205456] |
Wed, 01 June 2005 21:48 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: MatthiasBecker.hamburg.de
Hello
Is it possible to save the java command with classpath (including refered
projects, librarys etc...) into a shell script so that it is possible to run a
complex project direct from the commandline?
Sincerely
Matt
Re: Saveing java-command (+ Classpath) into a shell scipt [message #205464 is a reply to message #205456] |
Thu, 02 June 2005 00:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: wegener.cboenospam.com
Run your application, Go to the Debug Perspective, Select your process,
Right click and select Properties. This will display the command line used
to start your process. You can hilight with a mouse and copy it to the
clipboard for pasting.
"Matthias Becker" <MatthiasBecker@hamburg.de> wrote in message
news:d7lafe$j9c$1@news.eclipse.org...
> Hello
> run a
> Sincerely
> Matt
FUDForum. Page generated in 0.02819 seconds
