GEF import statements [message #205193] |
Mon, 16 April 2007 10:13  |
Originally posted by: coa03ysa.shef.ac.uk
I am building a graphical editor using Eclipse's Graphical Editing
Framework. I am currently working on constructing the editor itself.
Unfortunately some of my import statements "cannot be resolved". To be
specific, the unrecognized statements are:
import org.eclipse.ui.IFileEditorInput;
import org.eclipse.ui.part.FileEditorInput;
I would be most grateful if somebody could give me some steer with respect
to how to solve this problem so that I could get on with the project. Many
thanks.
Yvon
Re: GEF import statements [message #205484 is a reply to message #205463] |
Tue, 17 April 2007 09:28  |
Originally posted by: irbull.cs.uvic.ca
Knowing what plug-ins you need always seems to be a bit of a mystery to
me. Usually when I get compile errors in my import statements I assume
I haven't depended on the right project. However, if you don't have the
required project anywhere in your workspace, it can sometimes be hard to
figure out what project you need. I have found myself depending on a
bunch of projects, and then used the PDE to remove unneeded
dependencies, although there must be a better way.
Glad to hear you got it working.
cheers,
ian
Yvon Asafu-Adjaye wrote:
> Thank you very much. That worked. I had added org.eclipse.ui to the
> Dependencies tab, but I had not added org.eclipse.ui.ide. Do you know of
> any other plugin that I need to include in the Dependencies list for the
> project? So far this is the list in the Dependencies tab:
> org.eclipse.gef
> org.eclipse.emf
> org.eclipse.core.runtime
> org.eclipse.core.resources
> org.eclipse.ui
> org.eclipse.ui.ide
> Many thanks.
> Yvon
FUDForum. Page generated in 0.10711 seconds
