Home » Eclipse Projects » Remote Application Platform (RAP) » Deploy in TOMCAT tutorial
Deploy in TOMCAT tutorial [message #19695] Fri, 20 April 2007 15:48 Go to next message
Originally posted by: rhernandez_64.hotmail.com
I use rap.psf and add org.eclipse.rap.demo.feature, every thing is OK the
import download the plugins but in the root of org.eclipse.rap.feature
doesnt appear the deploy tutorial
regards
Re: Deploy in TOMCAT tutorial [message #19746 is a reply to message #19695] Fri, 20 April 2007 17:43 Go to previous messageGo to next message
Originally posted by: b.muskalla.gmx.net
The deployment tutorial resides in the org.eclipse.rap.demo.feature and
not in org.eclipse.rap.feature project and it is called
deployment_tutorial.html.
Greets
Benny
> the import download the plugins but in the root of
> org.eclipse.rap.feature doesnt appear the deploy tutorial
> regards
Re: Deploy in TOMCAT tutorial [message #19786 is a reply to message #19746] Fri, 20 April 2007 18:24 Go to previous messageGo to next message
You are right, is org.eclipse.rap.demo.feature but is not there
deploy_tutorial.html
this is part of my rap.psf
<project
reference="1.0,:pserver:anonymous@dev.eclipse.org :/cvsroot/technology,org.eclipse.rap/org.eclipse.rap.demo,or g.eclipse.rap.demo.feature "
Re: Deploy in TOMCAT tutorial [message #19914 is a reply to message #19786] Mon, 23 April 2007 09:10 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
I just checked the CVS - the current version number of the
deployment_tutorial.html is 1.1, so it is in the repository. It is true that
the 'org.eclipse.rap.demo.feature' isn't added to the rap.psf file, so it
has to be checked out manually. Maybe this will be changed in the future and
the tutorial will be added to the next milestone help plugin. After that we
will provide it online as an infocenter installation.
Ensure that you have checked out the 'org.eclipse.rap.demo.feature' and not
the 'org.eclipse.rap.feature' which is used for the milestone build. We also
tried the anonymous account but the deployment_tutorial.html was there.
Maybe try the CVS Repository Exploring perspective to find it. If you are
still not able to check out the complete project, please give us some more
hints for troubleshooting, since maybe not only the tutorial is missing - so
putting the tutorial into the wiki would not be the solution.
Ciao
Frank
"Rafael Hernandez" <rhernandez_64@hotmail.com> schrieb im Newsbeitrag
news:c48a6bd65be8db3095c5528f6bd1df38$1@www.eclipse.org...
> <project
Re: Deploy in TOMCAT tutorial [message #19987 is a reply to message #19914] Tue, 24 April 2007 11:09 Go to previous messageGo to next message
Ok. Now How I can download the deploy_tutorial.html !!!!!!!
Re: Deploy in TOMCAT tutorial [message #20027 is a reply to message #19987] Tue, 24 April 2007 13:32 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
You can view it (without pictures) here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.rap/org .eclipse.rap.demo.feature/deployment_tutorial.html?root=Tech nology_Project&view=co
Maybe you should try to delete the org.eclipse.rap.demo.feature project
in your workspace and import the project again from CVS with the Import
Project wizard.
Re: Deploy in TOMCAT tutorial [message #20065 is a reply to message #20027] Tue, 24 April 2007 16:26 Go to previous messageGo to next message
Thanks a lot !
Re: Deploy in TOMCAT tutorial [message #20266 is a reply to message #20065] Tue, 24 April 2007 21:09 Go to previous messageGo to next message
When Run ant build of webappbuilder.xml the console display
BUILD FAILED
C:\workspace\org.eclipse.rap.demo.feature\script\webappBuild er.xml:64: The
following error occurred while executing this line:
C:\workspace\org.eclipse.rap.demo.feature\script\webappBuild er.xml:81:
C:\eclipse\rap\org.eclipse.equinox.servletbridge\bin not found.
Hot fix it ?
Rafael Hernandez
Caracas - Venezuela
Re: Deploy in TOMCAT tutorial [message #20322 is a reply to message #20266] Thu, 26 April 2007 09:14 Go to previous message
did you checkout the servlet bridge bundles and modified the
webappBuilder.xml as described in the tutorial?
Ciao
Frank
news:fcc754d44c34162ba597f641b07ddbc4$1@www.eclipse.org...
> BUILD FAILED
> Hot fix it ?
> Rafael Hernandez
> Caracas - Venezuela
Previous Topic:DemoSelectionViewPart
Next Topic:Display problem in a ViewPart toolbar
Current Time: Thu Dec 26 11:48:59 GMT 2024
Powered by FUDForum. Page generated in 0.04061 seconds
