Home » Language IDEs » Java Development Tools (JDT) » How to create ICompilationUnit from source
How to create ICompilationUnit from source [message #204459] Fri, 20 May 2005 15:49 Go to next message
Hi all,
I'd like to create an ICompilationUnit instance from either
- source code as String or
- source code as IDOMCompilationUnit
I've checked the Eclipse source code, but couldn't find a way to achieve
this. Any ideas?
Marcel Stör
http://www.frightanic.com
Re: How to create ICompilationUnit from source [message #207341 is a reply to message #204459] Mon, 20 June 2005 04:46 Go to previous messageGo to next message
You can use: IPackageFragment#createCompilationUnit(String, String, ...)
Note this is the first topic of 'Manipulating Java code' of the JDT Programmer's Guide in Help.
Jerome
Marcel Stör wrote:
> Hi all,
> this. Any ideas?
Re: How to create ICompilationUnit from source [message #210684 is a reply to message #207341] Fri, 22 July 2005 16:34 Go to previous messageGo to next message
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> schrieb im Newsbeitrag
news:d95vou$ktn$1@news.eclipse.org...
It's not that I didn't know that...
My problem is a bit more tricky, though. Our Swing application is running
outside Eclipse i.e. it's not a plugin. Still, I would like to invoke
Eclipse' "Organize imports" feature for a given String that represents a
Java class.
Marcel Stör
Re: How to create ICompilationUnit from source [message #212090 is a reply to message #210684] Thu, 11 August 2005 04:43 Go to previous message
Sorry. Invoking org.eclipse.jdt.core code outside a running Eclipse instance is not supported.
> Java class.
Previous Topic:help moving project location
Next Topic:change eclipse vm frequently: easy solution?
Current Time: Tue Oct 14 17:09:46 EDT 2025
Powered by FUDForum. Page generated in 0.04688 seconds
