Deploy a web service client [message #204451] |
Fri, 20 May 2005 19:24 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jbailo.vestcom.com
I've been using the Eclipse WTP and think it's great...but I haven't
used Eclipse must and still don't understand deployment. I have
everything working inside of Eclipse, but now want to move it to another
server. Here's what I built:
1) I took a web service ( written in .NET ) and created a proxy to it.
I was able to test it in Eclipse using the .jsp test pages.
2) I created a java application that consumed the proxy and was able to
run the web methods from (1) and return a result which is printed to the
console.
Now I want to be able to run this client on another machine.
QUESTION
How do I deploy my web client class and all necessary and associated files?
Other questions:
My organization uses BEA Weblogic 8.1
1. Can I substitute Weblogic 8.1 for Tomcat?
2. Do I need to bother if I'm only creating a proxy ( not a web service,
but a proxy to consume the service )? In this case, isn't the only use
of the web server to run the .jsp files that test the web service?
3. Is the web service proxy dependent on the web server?
Re: Deploy a web service client [message #204644 is a reply to message #204451] |
Mon, 23 May 2005 18:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------060303000708020302020105
Here are some more details about my setup...where I'm trying to deploy a
java application client that consumes a web service proxy built with
eclipse. Attached is bitmap showing the directory structure of the
output ( howtodeploy.bmp ). The Java application
MatchCode20Client.class performs great from within Eclipse -- now I want
to run it externally and ideally from another server.
My classpath is:
C:\Documents and
Settings\jbailo\workspace\MatchCode20\WebContent\WEB-INF\cla sses >set
classpath
classpath=.;c:\Sun\jwsdp-1.5\jaxrpc\lib;m:\ema_kewadin_vcrm2 \classes;c:\Sun\AppServer\lib\j2ee.jar
When I run the application from a command window:
C:\Documents and
Settings\jbailo\workspace\MatchCode20\WebContent\WEB-INF\cla sses\org\tempuri >java
-classpath . MatchCode20Client
Exception in thread "main" java.lang.NoClassDefFoundError:
MatchCode20Client (wrong name: org/tempuri/MatchCode20Client)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:123)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at java.lang.ClassLoader.loadClass(ClassLoader.java:289)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:274 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
> console.
> QUESTION
> Other questions:
Content-Type: image/bmp;
name="howtodeploy.bmp"
Content-Disposition: inline;
filename="howtodeploy.bmp"
Qk1C9QcAAAAAADYEAAAoAAAAJAQAAOsBAAABAAgAAAAAAAzxBwAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAgAAAgAAAAICAAIAAAACAAIAAgIAAAMDAwADA3MAA8MqmAAAgQAAA IGAAACCAAAAg
oAAAIMAAACDgAABAAAAAQCAAAEBAAABAYAAAQIAAAECgAABAwAAAQOAAAGAA AABgIAAAYEAA
AGBgAABggAAAYKAAAGDAAABg4AAAgAAAAIAgAACAQAAAgGAAAICAAACAoAAA gMAAAIDgAACg
AAAAoCAAAKBAAACgYAAAoIAAAKCgAACgwAAAoOAAAMAAAADAIAAAwEAAAMBg AADAgAAAwKAA
AMDAAADA4AAA4AAAAOAgAADgQAAA4GAAAOCAAADgoAAA4MAAAODgAEAAAABA ACAAQABAAEAA
YABAAIAAQACgAEAAwABAAOAAQCAAAEAgIABAIEAAQCBgAEAggABAIKAAQCDA AEAg4ABAQAAA
QEAgAEBAQABAQGAAQECAAEBAoABAQMAAQEDgAEBgAABAYCAAQGBAAEBgYABA YIAAQGCgAEBg
wABAYOAAQIAAAECAIABAgEAAQIBgAECAgABAgKAAQIDAAECA4ABAoAAAQKAg AECgQABAoGAA
QKCAAECgoABAoMAAQKDgAEDAAABAwCAAQMBAAEDAYABAwIAAQMCgAEDAwABA wOAAQOAAAEDg
IABA4EAAQOBgAEDggABA4KAAQODAAEDg4ACAAAAAgAAgAIAAQACAAGAAgACA AIAAoACAAMAA
gADgAIAgAACAICAAgCBAAIAgYACAIIAAgCCgAIAgwACAIOAAgEAAAIBAIACA QEAAgEBgAIBA
gACAQKAAgEDAAIBA4ACAYAAAgGAgAIBgQACAYGAAgGCAAIBgoACAYMAAgGDg AICAAACAgCAA
gIBAAICAYACAgIAAgICgAICAwACAgOAAgKAAAICgIACAoEAAgKBgAICggACA oKAAgKDAAICg
4ACAwAAAgMAgAIDAQACAwGAAgMCAAIDAoACAwMAAgMDgAIDgAACA4CAAgOBA AIDgYACA4IAA
gOCgAIDgwACA4OAAwAAAAMAAIADAAEAAwABgAMAAgADAAKAAwADAAMAA4ADA IAAAwCAgAMAg
QADAIGAAwCCAAMAgoADAIMAAwCDgAMBAAADAQCAAwEBAAMBAYADAQIAAwECg AMBAwADAQOAA
wGAAAMBgIADAYEAAwGBgAMBggADAYKAAwGDAAMBg4ADAgAAAwIAgAMCAQADA gGAAwICAAMCA
oADAgMAAwIDgAMCgAADAoCAAwKBAAMCgYADAoIAAwKCgAMCgwADAoOAAwMAA AMDAIADAwEAA
wMBgAMDAgADAwKAA8Pv/AKSgoACAgIAAAAD/AAD/AAAA//8A/wAAAP8A/wD/ /wAA////AKSk
pKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSk pKSkpKSkpKSk
pKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKT/9/f39/f39/f39/f3 9/f39/f39/f3
9/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f3 9/f39/f39/f3
9/f39/f39/f39/ek//8ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgI CAgICAgICAgI
CAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgI CAgICAgICAgI
CAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAj3 pP//CPb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vYI96T//wj2//////////////////// ////////////
//////////////////////////////////////////////////////////// ////////9vb2
9vb29vb29vb29vb29vb///////////////////////////////////////// ////////////
///2CPek//8I9vf39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f3 9/f39/f39/f3
9/f39/f39/f39/f39/f39/f39/f39/f39/f39/f3//b29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb2////////
////////////////////////////////////////////////9gj3pP//CPb3 ////////////
////////////////////////////////////////////////Lfa/pAcAv7+/ v7+/t7YA////
//////////////////////////////8A////AAAAAAD//wAAAP//AAAAAAD/ /wAAAP//////
////////AP////////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// /6SkpKSkpKSk
pKSkpKSkpKSk9//29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29v////////////////////// ////////////
//////////////////////YI96T//wj29/////////////////////////// ////////////
/////////////////////y329qT/APb29vb29r+2AP////////////////// ////////////
////////////////////////////////////9/f39/f39/f39/f39/f3pPf/ 9vb29vb29vb2
9vb29vb29vb///////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// ///////2CPek
//8I9vf///////////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// //////8ttrak
BwC2ti0tLS0tLf////////////////////////////////////////////// ////////////
///////////29vb29vb29vb29vb296T3//b29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2//// ////////////
////////////////////////////////////////9gj3pP//CPb3//////// ////////////
/////////////////////////////////////////y32v6S/vy3///////// ////////////
////////////////////////////////////////////////////////9vb2 9vb29vb29vb2
9vek9//29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29v////////////////////////////// ////////////
//////////////YI96T//wj29/////////////////////////////////// ////////////
////////////////LS0tLS3///////////////////////////////////// ////////////
//////////////////////////////b29vb29vb29vb29vb3pPf/9vb29vb2 9vb29vb29vb2
9vb///////////////////////////////////////////////////////// ////////////
///////////////////////////////////////////////////////////2 CPek//8I9vf/
///29vb29vb29vb29vb296T3//b29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2//////////// ////////////
////////////////////////////////9gj3pP//CPb3//////////////// ////////////
////////////////////////////////////////////////9vb29vb2APb2 9vb29vek9//2
9vb29vb29vb29vb29vb29v////////////////////////////////////// ////////////
//////YI96T//wj29/////////////////////////////////////////// ////////////
//////////////////////b29vb2AAAA9vb29vb3pPf/9vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb/////
///////////////////////////////////////////////////2CPek//8I 9vf/////////
//////////////////////////8A//////////////////////////////// ////////////
////////////////////AP////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// ///////29vb2
AAAAAAD29vb296T3//b29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2//////////////////// ////////////
////////////////////////9gj3pP//CPb3//////////////////////// ////////////
/////////////////////////wAAAAAAAAAAAAAAAAAA//////////////// ////////////
AP////////////////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// /////wD/////
////////////////////////////////////////9vb2AAAAAAAAAPb29vek 9//29vb29vb2
9vb29vb29vb29v////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// //////////YI
96T//wj29/////////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////f39/f39/f3 9////////y22
tra2tra2tra2tra2AP////////8AAAD///8AAAD/AP8A/wAAAAD//wAAAP// /wAAAP//////
/wAAAP//AAAAAP//////AP////////8AAAAA//8AAAAA////AP///wD///// //8AAAD///8A
////AAAA////AP///wAAAP///wD//wAAAAD/AP8AAAAA//////////////// ////////////
//////////////b29vb29vb29vb29vb3pPf/9vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb/ ////////////
///////////////////////////////////////////2CPek//8I9vf///// ////////////
///////////////////////3//////////f///////8t9rcApAC3v7+/t7e3 tgD///////8A
////AP8A/////wD/AP8A////AP////8A/wD///8A//////////8A/wD///8A /////wD/////
/////////wD/AP///wD//wD//wD///////8A////AP//AP//AP///wD//wD/ ////AP////8A
//8A/////wD/AP///wD///////////////////////////////////////// ////////////
///////////////////////////////////////////////////////////2 9vb29vb29vb2
9vb296T3//b29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb2//////////////////////////// ////////////
////////////////9gj3pP//CPb3//////////////////////////////// ////////////
//////////////////////////////////////////////////////////// ////////9///
/wD////3////////Lfa/B6QHv7+/v7+3t7YA////////AP//////AP////8A /wD/AP///wD/
//8AAP8A////////////////AP8A/////wD///8A//////////////8A/wD/ ////AP8A/wD/
/////////////wD//////wD///8A/////////wD//////////wD///8A/wD/ //8A////////
////////////////////////////////9vb29vb29vb29vb29vek9//29vb2 9vb29vb29vb2
9vb29v////////////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// //YI96T//wj2
9/////////////////////////////////////////////////////////// ////////////
//////////////////////////////////////////f///8A////9/////// /y32vwCkAL+/
v7+/v7e2AP///////wAAAAAA/wD/////AP8A/wD///8A/wAA////AAAAAAD/ AAAA/////wD/
AP////8A////AP///wAAAP//////AP8A/////wD/AAD/////AAAA//////8A //////8A////
AP////////8A////////////AP//AP8A////AP////////////////////// ////////////
//////b29vb29vb29vb29vb3pPf/9vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb///////// ////////////
///////////////////////////////////2CPek//8I9vf///////////// ////////////
///////////////3/wAAAAAA//f///////8t9r8HpAe/t7+/v7+/tgD///// //8A////AP8A
/////wD/AP8A////AP8A/////wD///8A//////////8A/wD/////AP///wD/ /////////wAA
AP//AP////8A/wAA/////////////wAA////////AP///wD/////////AP// //////////8A
/wD/AP///wD///////////////////////////////////////////////// ////////////
///////////////////////////////////////////////////29vb29vb2 9vb29vb296T3
//b29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb2//////////////////////////////////// ////////////
////////9gj3pP//CPb3//////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// 9////wD////3
////////Lfa/AKQAv7+/v7+/v7YA/////////wAAAP///wAAAP8A/wD/AAAA AP///wAAAP//
AAAA////////////AP8A/////wD///8A/////////wD//////wD/////AP8A /wD/////////
/////wD//////wD///8A/////////wD/////////AAAAAP8A/wAAAAD///// ////////////
//////////////////////////////////////////ek9//29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29v//
//////////////////////////////////////////////////////YI96T/ /wj29///////
//////////////////////////////////f///8A////9////////y32vwcA 97+/v7e/v7+2
AP//////////////////////AP////////////////////////////////// /wD/AP///wD/
////AP////////8A//////8A////AP//AP//AP///////wD///8A//////8A ////AP//////
/wAA//////////////////////////////////////////////////////// ////////////
////////////////pPf/9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb///////////////// ////////////
///////////////////////////2CPek//8I9vf///////////////////// ////////////
///////3//////////f///////8t9r+k9wC/v7+/v7+3tgD///////////// /////////wD/
AP//////////////////////////////AAAA/wAAAAD///8AAAAAAP////// /wAAAAD/AAAA
AP///wD///8A////////AAAA/////////wAAAP//////////AP////////// /////wD/////
////////////////////////////////////////9v/2//b/9v/2//b/9v/2 //b3//b29vb2
9vb29vb29vb29vb2//////////////////////////////////////////// ////////////
9gj3pP//CPb3//////////////////////////////////////////////// ////////////
////////////////////////////////////////////////////9/f39/f3 9/f3////////
Lfb2pP8A9vb29vb2v7YA//////////////////////8A//////////////// ////////////
///////////////2//b/9v/2//b/9v/2//b/9//29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9v//////////
//////////////////////////////////////////////YI96T//wj29/// ////////////
/////////////////////////////////////////////y22tqQHALa2LS0t LS0t////////
///////////////////////////////////////////////////////////2 //b/9v/2//b/
9v/2//b/9vf/9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb///////////////////////// ////////////
///////////////////2CPek//8I9vf///////////////////////////// ////////////
////////////////////Lfa/pL+/Lf////////////////////////////// ////////////
//////////////////////////////////b/9v/2//b/9v/2//b/9v/3//b2 9vb29vb29vb2
9vb29vb2//////////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// ////9gj3pP//
CPb3//////////////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// //////8tLS0t
Lf////////////////////////////////////////////////////////// ////////////
//////b/9v/2//b/9v/2//b/9v/29//29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29v////// ////////////
//////////////////////////////////////YI96T//wj29/////////// ////////////
////////////////////////////////////////////////////9v/2//b/ 9v/2//b/9v/2
//f/9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb///////////////////////////////// ////////////
///////////2CPek//8I9vf///////////////////////////////////// ////////////
////////////////////////9v/2//b/9v/2//b/9v/2//b3//b29vb29vb2 9vb29vb29vb2
////////////////////////////////////////////////////////9gj3 pP//CPb3////
///////////2CAgICAgICAgICAgICPb///////////////////////////// ////////////
//////////////////////////////////////////////////////////// ///////////2
//b/9v/2//b/9v/2//b/9//29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
9vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29v////////////// ////////////
//////////////////////////////YI96T//wj29/////////////////// ////////////
///////////////////////////////////////////////////////2B6Sb m5ubm5ubm5ub
m6QH//////////////////////////////////////////////////////// ////////////
///////////////////////////////////////////2//b/9v/2//b/9v/2 //b/9vf/9vb2
///2CPek//8I9vf///////////////////////////////////////////// ////////////
////////////////////////////CCYmJiUlJSUlHR0dHR1SpP////////// ////////////
//////////////////b/9v/2//b/9v/2//b/9v/3//b29vb29vb29vb29vb2 9vb29vb29vb2
//////////////////////////////////////////////////////f39/f3 9/f39///////
/2a3Zr+/v7+/v7+/v2+/HZv//////wAAAAD///8AAAD//wD//////wD///// AAAA//8A////
AAAA//////////////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// //b/9v/2//b/
9v/2//b/9v/29//29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
///////////////////////////3//////////f///////9mt2a/v7+/v7+/ v79vvx2b////
////////AP8A////AP8A//////8A////AP///wD/AP///////wD///////// ////////////
////////////////////////////////////9v/2//b/9v/2//b/9v/2//f/ 9vb29vb29vb2
9////wD////3////////Zrduv7+/v7+/v7+/d78dm////////////wD/AP// ////AP////8A
/wD//wD//////wD//////wAA//////////////////////////////////// ////////////
////////9v/2//b/9v/2//b/9v/2//b3//b29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
//////////////////////////////////////////////f///8A////9/// /////2a3br+/
v7+/v7+/v3e/HZv///////////8A/wAAAAAA/wD/////AP8A//8AAAAAAP8A ////AAD/////
///////////////////////////////////////////////////////2//b/ 9v/2//b/9v/2
//b/9//29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb29vb2 9vb29vb29vb2
Re: Deploy a web service client [message #204653 is a reply to message #204644] |
Mon, 23 May 2005 18:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I tried this as well. It seems to get a little further...do I need to
add something else to my classpath?
C:\Documents and
s>java -cp . org.tempuri.MatchCode20Client
javax/xml/rpc/Service
Exception
org.tempuri.MatchCode20Client.printIfMale(MatchCode20Client. java:19)
at org.tempuri.MatchCode20Client.main(MatchCode20Client.java:12 )
> My classpath is:
> C:\Documents and
> classpath
> C:\Documents and
> at
> at java.security.AccessController.doPrivileged(Native Method)
>> another server. Here's what I built:
>> to run the web methods from (1) and return a result which is printed
>> to the console.
>> QUESTION
>> files?
>> Other questions:
>> service, but a proxy to consume the service )? In this case, isn't
>> the only use of the web server to run the .jsp files that test the web
>> service?
> My classpath is:
> C:\Documents and
> classpath
> C:\Documents and
> at
>> to the console.
>> QUESTION
>> files?
>> Other questions:
>> service?
FUDForum. Page generated in 0.02933 seconds
