Home » Language IDEs » ServerTools (WTP) » Line endings
Line endings [message #204313] Tue, 13 November 2007 06:46 Go to next message
Originally posted by: jan.bares.ips-ag.net
Eclipse correctly detects line endings for existing files like *.java and
*.txt. However for existing *.html, *.xml, *.jsp the line endings are not
detected and platform specific line-ending are used. This results in
line-endings mismatch. Why, where can I change this?
In Preference/General/Workspace and Project/Properties/Resource I have
test "default", but this is only for new files.
Eclipse 3.3.1.1
Re: Line endings [message #204326 is a reply to message #204313] Tue, 13 November 2007 09:10 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
jan_bar wrote:
> and *.txt. However for existing *.html, *.xml, *.jsp the line endings
> are not detected and platform specific line-ending are used. This
> results in line-endings mismatch. Why, where can I change this?
> Eclipse 3.3.1.1
Jan have these files been checked out from source control? If so, you
can control this on the Team preference page, on the Files and
Directories tab.
Also, which OS are you experiencing the problems.
Re: Line endings [message #204334 is a reply to message #204326] Tue, 13 November 2007 09:33 Go to previous messageGo to next message
Thanks David, see inline
> Directories tab.
I use SVN/Subversive, but the problem is not bound to VCS. When I edit
*.txt or *.java files with UNIX line endings, Eclipse detects them and
uses UNIX line endings for new lines. But for *.html, *.xml, *.jsp file
this detection doesn't work and Eclipse uses Windows line endings. The
results is mixed line endings.
Windows XP.
Thanks, Jan
Re: Line endings [message #204461 is a reply to message #204313] Thu, 15 November 2007 11:59 Go to previous messageGo to next message
Originally posted by: wuamy.ca.ibm.com
jan_bar wrote:
> Eclipse 3.3.1.1
Have you tried Preferences/Web and XML/HTML Files, XML Files, JSP Files?
Re: Line endings [message #204736 is a reply to message #204461] Tue, 20 November 2007 03:15 Go to previous messageGo to next message
Yes, I have Web and XML/HTML files, line delimiter = no translation, but
maybe this is the problem? Actually I need line delimiter = "use the same
as in existing file". Why I cannot set this settings?
Re: Line endings [message #204894 is a reply to message #204736] Fri, 23 November 2007 20:39 Go to previous message
On Tue, 20 Nov 2007 03:15:10 -0500, jan_bar <jan.bares@ips-ag.net> wrote=
>> Have you tried Preferences/Web and XML/HTML Files, XML Files, JSP Fil=
es?
> Yes, I have Web and XML/HTML files, line delimiter =3D no translation,=
but
> maybe this is the problem? Actually I need line delimiter =3D "use the=
same
no translation does mean to use the same as in existing file, and, last =
I check, this worked
just fine.
So, if you are seeing problem, you might open a bug, and detail exactly =
how to reproduce.
And, you might attach your configuration and log from the about box, so =
we can verify if there's
anything that looks odd.
Previous Topic:About WTP2.0 with OC4j
Next Topic:Moving WSAD5 to JBOSS 4.2.1 with eclipse IDE
Current Time: Thu Oct 16 13:38:52 EDT 2025
Powered by FUDForum. Page generated in 0.04208 seconds
