What is this? .#Aclass.java.1.2 [message #204238] |
Mon, 01 March 2004 15:10  |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
I have a couple of these .#dafsdfas.java1.2 or whatever files. They
also have an accompanying class file. What are these files? Can I
eliminate them?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: What is this? .#Aclass.java.1.2 [message #205319 is a reply to message #204260] |
Wed, 03 March 2004 11:32  |
nobody@nowhere.com wrote:
>>>>>>>>>>>>>>>>>>>Original Message <<<<<<<<<<<<<<<<<<
> On 3/1/2004, 12:10:59 PM, "CL [dnoyeb] Gilbert"
> <Lamont_Gilbert@rigidsoftware.com> wrote regarding What is this?
> .#Aclass.java.1.2:
>>eliminate them?
> Are you using CVS? I ask cause the name looks like what CVS produces
> when there are on conflicts on update. If that was the case then
> the file is backup of the changes you had before you did the update.
> -- Regards, Dan S
Thanks, you are probably correct.
Respectfully,
CL Gilbert
FUDForum. Page generated in 0.03586 seconds
