Home » Newcomers » Newcomers » Docs Java Api
Docs Java Api [message #204208] Tue, 10 April 2007 16:22 Go to next message
Originally posted by: landolini.yahoo.it
How can I see the API Docs from Eclipse IDE ?
I cannot find how to set it ...I suppose so as in Netbeans
is possible...
Many thanks .
Re: Docs Java Api [message #204242 is a reply to message #204208] Tue, 10 April 2007 18:47 Go to previous messageGo to next message
Paul A. Rubin is currently offline Paul A. RubinFriend
> is possible... Many thanks .
Not sure this is the best way, but I go to Window -> Preferences... ->
Java -> Installed JREs, click on the JRE I'm using, click Edit...,
select rt.jar, and click Javadoc Location...
/Paul
Re: Docs Java Api [message #204258 is a reply to message #204242] Tue, 10 April 2007 20:35 Go to previous messageGo to next message
I' ve done but I don't see Docs Api , using Package Explorer,
under Project > JRE System Library....there are only the JRE
library.
Re: Docs Java Api [message #204288 is a reply to message #204258] Tue, 10 April 2007 22:17 Go to previous messageGo to next message
> library.
I may have misunderstood what you wanted. Context-specific bits of the
API will be visible in the Javadoc tab if you click on a token, or in a
tooltip if you hover over a token.
If you want to be able to read the API docs in a window in Eclipse, I'm
not sure how to do that. I usually just open the index in a separate
browser and leave it open.
/Paul
Re: Docs Java Api [message #204296 is a reply to message #204208] Tue, 10 April 2007 22:19 Go to previous messageGo to next message
Two options:
A) Put the cursor on a class or method and press Shift+F2 to open the
Javadoc in your web broswer.
B) Open the Javadoc view via Window > Show View. That will show a small
view of the Javadoc based on where the cursor is at all times.
Hope this helps,
Eric
Re: Docs Java Api [message #204307 is a reply to message #204296] Wed, 11 April 2007 07:52 Go to previous messageGo to next message
I get or a short description of the tag pointed by cursor
or using shift + F2 this wrong result(of course the html page exist !)>>>
http://immagini.p2pforum.it/out.php/i133049_screenshotEclips e2.png
..then the original Api doc is not visible.
Re: Docs Java Api [message #204392 is a reply to message #204307] Thu, 12 April 2007 00:00 Go to previous messageGo to next message
Lidder is currently offline LidderFriend
Member
I have the same problem and get the same error. I have to reset the
javaDocs location to force the docs to appear again. I have stopped using
docs on my computer and just let eclipse take me to javadocs online. Have
you tried searching for it at https://bugs.eclipse.org/bugs/? Maybe it's a
known issue. I will keep looking as well ...
Re: Docs Java Api [message #204442 is a reply to message #204307] Thu, 12 April 2007 07:22 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
If you are sure that you setup the Javadoc locations correctly and it
doesn't' work then please file a bug against JDT UI with steps to reproduce.
Dani
Re: Docs Java Api [message #204558 is a reply to message #204442] Thu, 12 April 2007 18:38 Go to previous message
I'm not a developer !...only a beginner.
Of course the Docs location is correct and Netbeans works fine.
Previous Topic:How do I set the default folder for File -> Open File???
Next Topic:Upload on Save
Current Time: Tue Jan 28 16:10:31 GMT 2025
Powered by FUDForum. Page generated in 0.09935 seconds
