Home » Language IDEs » Java Development Tools (JDT) » 3.1 M7: Ant External Tools do not work when running on a separate JRE
3.1 M7: Ant External Tools do not work when running on a separate JRE [message #204094] Wed, 18 May 2005 13:23 Go to next message
Originally posted by: eraserman.nospam.gmail.com
I'm working on a project that has ant targets to start and stop the
application server, in addition to the standard build targets.
I have many of the ANT targets mapped to external tools.
Recently upgraded to Eclipse 3.1M7, now these targets do not work unless
ANT is run in the same JRE as the workspace.
When attempting to run one of these external tools using a separate JRE,
the status text on the console tab goes to <terminated>, inmediately.
There is no output whatsoever in the console itself.
These same ant targets worked fine on Eclipse 3.1M5 (I never downloaded M6).
Ray
Re: 3.1 M7: Ant External Tools do not work when running on a separate JRE [message #204102 is a reply to message #204094] Wed, 18 May 2005 13:29 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95611
Another workaround if you are not using the Ant <input> task:
You can turn off "Set an Input Handler" on
the Main page of the Ant launch configuration.
HTH
Darins
"Ray Davis" <eraserman@nospam.gmail.com> wrote in message
news:d6fto7$ds3$1@news.eclipse.org...
M6).
> Ray
Re: 3.1 M7: Ant External Tools do not work when running on a separate JRE [message #204120 is a reply to message #204102] Wed, 18 May 2005 13:42 Go to previous message
I did have some entries with double quotes on my PATH variable. Got rid
of them, the problem went away. Thanks for the tip.
Ray
Previous Topic:Can't debug source code in M7
Next Topic:Ignoring superclass TestCases with JUnit runner
Current Time: Sat Oct 18 01:55:54 EDT 2025
Powered by FUDForum. Page generated in 0.05223 seconds
