Home » Eclipse Projects » Eclipse Platform » exporting a plugin
exporting a plugin [message #203902] Mon, 01 March 2004 03:03 Go to next message
Originally posted by: emilienbeucler.hotmail.com
I wrote a plugin that compiles and runs fine, but when I'm trying to export
it using File -> Export it just creates an empty .zip file, and I can't fine
the jar file in the workspace. I tried to create an Ant build file with the
plugin.xml file but it still doesn't work... Any idea? Thanks,
Emilien Beucler
Re: exporting a plugin [message #204463 is a reply to message #203902] Tue, 02 March 2004 00:07 Go to previous messageGo to next message
Originally posted by: wassimm.ca.ibm.com
eee wrote:
> Hello,
> Emilien Beucler
You need to edit the build.properties file at the root of your plug-in
project. This is the file that has all the rules that guide the
build/export process.
Re: exporting a plugin [message #204958 is a reply to message #203902] Wed, 03 March 2004 01:26 Go to previous message
Originally posted by: send2shriram.hotmail.com
eee wrote:
> Hello,
> Emilien Beucler
Hi Emilien,
If u want the Jar file for ur plugin, select File > Export > JAR
File.
U will get a wizard, locate where u want to save jar file and finish.
Previous Topic:Actions and MenubarPath
Next Topic:Plugins in Eclipse Build 20040226
Current Time: Wed Apr 16 03:59:31 EDT 2025
Powered by FUDForum. Page generated in 0.03037 seconds
