Home » Eclipse Projects » Eclipse Platform » Natures supposed to be stateless?
Natures supposed to be stateless? [message #203754] Sun, 29 February 2004 17:15 Go to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
When I make a nature and add it to the project, i dont get the same
nature back. Digging through the code I see that natures are cloned
upon adding. This means that natures must not supposed to maintain any
state!?!
I didn't know that nor read it anywhere.
Would someone verify that a Nature should not maintain any project state
information since the project is not guaranteed to return the same
instance at every request for the nature?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Natures supposed to be stateless? [message #203880 is a reply to message #203754] Mon, 01 March 2004 02:29 Go to previous messageGo to next message
> state!?!
As far as I know its simply an id added to a project. But you may set
persistent properties to any project.
Bye,
Martin (Kersten)
Re: Natures supposed to be stateless? [message #204418 is a reply to message #203880] Mon, 01 March 2004 20:12 Go to previous messageGo to next message
Originally posted by: smesh.openrules.com
In 2.X IProjectNature is:
public interface IProjectNature {
public void configure() throws CoreException;
public void deconfigure() throws CoreException;
public IProject getProject();
public void setProject(IProject project);
You can use setProject()...
Sam Mesh - http://openrules.com
Life is very short, and there's no time,
For coding and testing, my friend.
>>state!?!
Re: Natures supposed to be stateless? [message #204562 is a reply to message #204418] Tue, 02 March 2004 09:53 Go to previous message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Natures by themselves are stateless. If a nature needs state, it needs
to reconstruct the state when it receives the setProject call. Eclipse
calls setProject after it creates the nature. No one else should call
setProject().
Thanks, Rich Kulp
Previous Topic:Plugin export problem when MANIFEST in it
Next Topic:java.lang.OutOfMemoryError
Current Time: Fri Apr 25 01:22:12 EDT 2025
Powered by FUDForum. Page generated in 0.03056 seconds
