Re: [CDT4.0] Project Properties controll [message #203584 is a reply to message #203576] |
Thu, 25 October 2007 06:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: dmsubs.NOSPAM.consertum.com
You should read the Managed Build System Extensibility document, which you can
find in the Help supplied with your CDT (under CDT Plugin Developers Guide).
What you want is done through a plugin and (I think) you can do it all through
XML rather than writing Java.
Derek
Karim NABLI wrote:
> I have a little problem with the properties information of C/C++
> project. when I expand project-->properties--> c/c++ Page. I have a Page
> that contain 2 main information(tabbed pane) : behaviour & settings. So
> my need is to master the information for example the ${MAKE} value &
> ${workspace_loc} value and i would like to change them. My request is :
> there is any way to override or control these information from coding
> point of view. I know that a lot information are on "Configuration" and
> on "IBuild", but even I change them + extends
> org.eclipse.cdt.managedbuilder.properties.BuilderSettings + override a
> lot of method ==> without success. I succed to have a new tabbed pane,
> but without controlling the needed one. So if you can help me to fix
> this issue.
> Many thanks
FUDForum. Page generated in 0.05581 seconds
