How to add JAR creation to the build chain (builder) ? [message #203503] |
Sat, 14 May 2005 21:55 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: sami.p.heikkinen.poista.mail.suomi.net
After compiling source files, I would like to add the .class files to a JAR
file. THi scan be done using the export-funtionality and it also adds the
jar-task (description) to the dekstop, but how can I add this JAR creation
to the build chain (builder) so that it creates the JAR-file when I compile
to project? Or do I need to use ANT for that?
Regards, Sami
Re: How to add JAR creation to the build chain (builder) ? [message #203597 is a reply to message #203503] |
Mon, 16 May 2005 15:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: eclipse.rizzoweb.com
Sami Heikkinen wrote:
Yes, Ant is the answer (at least as far as Eclipse 3.0.2; perhaps 3.1
has some new functionality to help with this?)
Note that you can create an Ant script that does the JAR and set that to
automatically run after the Eclipse builder finishes compiling.
HTH,
Eric
Re: How to add JAR creation to the build chain (builder) ? [message #203904 is a reply to message #203597] |
Tue, 17 May 2005 19:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thanks. Got it working.
"Eric Rizzo" <eclipse@rizzoweb.com> wrote in message
news:d6adoq$32k$2@news.eclipse.org...
>> JAR file. THi scan be done using the export-funtionality and it also adds
>> the jar-task (description) to the dekstop, but how can I add this JAR
>> creation to the build chain (builder) so that it creates the JAR-file
>> when I compile to project? Or do I need to use ANT for that?
> Yes, Ant is the answer (at least as far as Eclipse 3.0.2; perhaps 3.1 has
> HTH,
> Eric
FUDForum. Page generated in 0.03494 seconds
