Home » Language IDEs » Java Development Tools (JDT) » Refactor > Rename
Re: Refactor > Rename [message #19511 is a reply to message #19464] |
Mon, 12 May 2003 07:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: sbernatsky.ukr.net
Hello.
snpe wrote:
> I try refactor > rename for class, field, method and it don't work.
> I don't get Compilation unit,I have nothing in source,nothing in log.
> Command do nothing.
> What is a problem ?
> My system : linux-gtk (rh 8.0), eclipse 2.1
I've found the same behaviour when I compiled eclipse from sources with
javac target '1.3' (this is default for javac from j2sdk 1.4.1) or '1.4'.
best regards,
Stanislav V. Bernatsky
Re: Refactor > Rename [message #19954 is a reply to message #19908] |
Mon, 12 May 2003 15:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: adam_kiezun.ch.ibm.spam.protection.com
> Refactor -> rname don't work, too
can you try searching for references (to the element that you'd like to rename) and tell me if that works
thanks
a.
eclipse.org
Re: Refactor > Rename [message #20813 is a reply to message #20195] |
Tue, 13 May 2003 09:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Hello Adam,
> If I try rename when have bad selection (nothing select or complete line
> select) I get error
what kind of error?
can you post a simple example here?
a.
eclipse.org
Re: Refactor > Rename [message #20861 is a reply to message #20813] |
Tue, 13 May 2003 13:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Haris Peco![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=snpe%40snpe.rs) Messages: 1072 Registered: July 2009 |
If I select nothing and call refactor -> rename I get dialog with error :
Operation unavailable on the current selection.
Select a java project, source folder, resource package,
completion unit, type , field, method, parameter or a local variable.
If I select a java project or anything I get nothing.
It haven't message, error ...
I am try on win xp (cvs eclipse 2.1), too.It is same.
regards
Haris Peco
Adam Kiezun wrote:
>> Hello Adam,
>> line
>> select) I get error
> what kind of error?
> a.
> eclipse.org
Re: Refactor > Rename [message #20886 is a reply to message #20861] |
Tue, 13 May 2003 11:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
then i guess that's expected if you select something that is not
a reference to anything that could be renamed.
do you mean that you cannot rename a java project?
a.
eclipse.org
Re: Refactor > Rename [message #20892 is a reply to message #20886] |
Tue, 13 May 2003 14:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
yes, I can't rename java project, field, class, method.
I can rename nothing
regards
Haris Peco
Re: Refactor > Rename [message #21323 is a reply to message #20892] |
Tue, 13 May 2003 12:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
even when you select a field in the outline view?
or a package in the package explorer?
what do you get then? what error?
a.
eclipse.org
Re: Refactor > Rename [message #21434 is a reply to message #21427] |
Tue, 13 May 2003 15:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
i can now and i've always been able to
now, i'm running the I-build 20030507+latest jdt plugins+latest text plugins
but it did work for me (and everybody else i know) in any stable or release build of eclipse 1.0, 2.0 or 2.1
my os is winXp
a.
eclipse.org
Re: Refactor > Rename [message #21545 is a reply to message #21456] |
Tue, 13 May 2003 16:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Is it possible that any plugin crash refactor - I have next plugins (except
> default) :
it sure is
i never used any of these plugins, though, so i have no idea
a.
eclipse.org
Re: Refactor > Rename [message #21767 is a reply to message #21337] |
Tue, 13 May 2003 17:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: vkyr.nospam-ision.net
I see *absolutely* the same behaviour as "snpe" described in this thread on
several University computers which all run Eclipse 2.1 final under W2K.
Valentino
"snpe" <snpe@snpe.co.yu> schrieb im Newsbeitrag
news:b9qplh$nmj$1@rogue.oti.com...
> Yes.I select a field in the outline or a package or source and refactor
> ->rename
> I get nothing, no error, no log, nothing
> regards
> Haris Peco
Re: Refactor > Rename [message #21812 is a reply to message #21545] |
Tue, 13 May 2003 17:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
NO, it isn't! We don't have any third party plugins installed on our
University dev machines, just Eclipse 2.1 and our own actual plugin projects
which we have under development. - BTW, at home on my own two computers
(same OS same Eclipse version with plenty third party addon plugins...) I
don't get this behahaviour.
Hmmm, maybe for the Univerity computers it has something todo with access
rights or the like (I don't really know, just a guess into the blue), or
Eclipse makes somewhere some broken entry which yields any future rename
usage...? Absolutely strage related to this is, that there is always *no*
error message in the error log, console or somewhere else. - It just doesn't
do nothing in these strange and odd "rename behaviour" cases!
Valentino
"Adam Kiezun" <adam_kiezun@ch.ibm.spam.protection.com> schrieb im
Newsbeitrag news:b9r5ou$4h2$1@rogue.oti.com...
(except
> > default) :
> it sure is
> a.
> eclipse.org
Re: Refactor > Rename [message #21903 is a reply to message #21812] |
Tue, 13 May 2003 21:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: adam.kiezun.gmx.net.remove
Valentino, Haris
do you guys have a small workspace in which you can reproduce that behavior?
if so, this bug would definitely be Priority 1 for the 2.1.1 release (june/july)
a.
eclipse.org
Re: Refactor > Rename [message #22165 is a reply to message #19908] |
Wed, 14 May 2003 08:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hello again.
snpe wrote:
> I compile eclipse from source (CVS) too.
> I try window xp build (cvs build 2.1).
Which j2sk did you use for compiling?
Here are my steps to reproduce the bug.
1) get sources from cvs;
2) get build scripts from eclipse download site;
3) replace '<javac ' to '<javac target="1.3"' in build.xml files;
4) comlipe eclipse;
5) run eclipse and try to rename something. -> you couldn't do it.
But if you replace '<javac ' to '<javac target="1.1"' in 3) then you'll be
able to rename anything.
best regards,
Re: Refactor > Rename [message #22289 is a reply to message #21903] |
Wed, 14 May 2003 10:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Adam, I will not be before next monday in the University, so you will have
to wait till monday for that. Next monday I can then check the Java SDK
version on one of those odd behaving machines and try to send you a
minimalistic workspace which might indicate what we are talking about in a
reproducable manner (well, I don't really know if it is reproducable from a
workspace, but maybe you can see enough out of this?).
Valentino
"Adam Kiezun" <adam.kiezun@gmx.net.remove> schrieb im Newsbeitrag
news:b9rom9$luq$1@rogue.oti.com...
> Valentino, Haris
behavior?
(june/july)
> a.
> eclipse.org
Re: Refactor > Rename [message #23093 is a reply to message #22964] |
Wed, 14 May 2003 15:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Adam ?
guys, do you also see the problem if you use the normal, pre-build eclipse distribution?
a.
eclipse.org
Re: Refactor > Rename [message #23424 is a reply to message #21948] |
Wed, 14 May 2003 15:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
news:b9rq32$mrh$1@rogue.oti.com...
> Adam Kiezun wrote:
> Question for Valentino :
> Are You build eclipse from CVS ?
Well, I believe you mean with "You build Eclipse from CVS", if I use the
Eclipse sources from an eclipse.org cvs server or the like (?).
NO, I don't. - I use instead the Eclipse "jdt.ui" sources which are coming
along with the Eclipse 2.1 SDK. I always import the Eclipse "jdt.ui" plugin
with sources into my dev workspace and the I'am recompiling these. The
reason I usually tend to use a source import of the whole "jdt.ui" inside my
workspace is, that I'am adapting/combining foreign source model refactoring
plugins with the standard Eclipse Java refactorings which come along inside
the jdt.ui.
However, I now always have the effect, that after importing the Eclipse
"jdt.ui" plugin sources in the above described way (even I leave the jdt.ui
clean/unmodified by me), the rename refactorings don't work inside any
"runtime-workbench" launch. All other refactorings in contrast seem to work
instead. - I can only fix this odd "runtime-workbench" rename refactoring
behaviour, by deleting the imported "jdt.ui" and it's sources completely
from the dev workspace. Since thus the next time when the runtime-workspace
is launched it uses again the default Eclipse deployed "jdt.ui" plugin from
the Eclipse plugin directory and not the imported and deleted stuff I had
before in the workspace.
Valentino
Re: Refactor > Rename [message #23467 is a reply to message #23093] |
Wed, 14 May 2003 17:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yes, I use instead the Eclipse "jdt.ui" sources which are coming along with
the Eclipse 2.1 SDK. I always import the Eclipse "jdt.ui" plugin with
sources into my dev workspace and the I'am recompiling these. The reason I
the jdt.ui.
Valentino
Newsbeitrag news:b9tnov$8jt$1@rogue.oti.com...
> > Adam ?
distribution?
> a.
> eclipse.org
Re: Refactor > Rename [message #23809 is a reply to message #23765] |
Wed, 14 May 2003 21:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
AFAIK we only have JDK 1.4 versions on those computers in the University,
even I'am not absolutely sure for this, so I will check this on monday when
I'am again there. - However, at home I use Eclipse 2.1 final on two
computers, both running W2K and the JDK 1.4.1 and here I don't have these
problems. At home it works so far.
Valentino
news:b9u9uj$qq9$1@rogue.oti.com...
> It is a problem that jdt.ui isn't compatible with jdk 1.3+
> Thanks
> Haris Peco
with
I
> > refactoring plugins with the standard Eclipse Java refactorings which
come
> > along inside the jdt.ui.
> > jdt.ui clean/unmodified by me), the rename refactorings don't work
inside
> > any "runtime-workbench" launch. All other refactorings in contrast seem
to
> > work instead. - I can only fix this odd "runtime-workbench" rename
> > refactoring behaviour, by deleting the imported "jdt.ui" and it's
sources
> > completely from the dev workspace. Since thus the next time when the
> > runtime-workspace is launched it uses again the default Eclipse deployed
> > "jdt.ui" plugin from the Eclipse plugin directory and not the imported
and
> > deleted stuff I had before in the workspace.
> > Valentino
> >> > Adam ?
> >> eclipse
> > distribution?
> >> a.
> >> eclipse.org
Re: Refactor > Rename [message #24009 is a reply to message #23049] |
Thu, 15 May 2003 08:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hello.
> I have yet any problem with Eclipse.It is maybe same reason.
> Update manager don't work - I haven't directory for update and I can't add
> any dir. - I get NullException.
> Is it same problem (jdk 1.1) ?
I don't know. I rolled back to '<javac target="1.1"' just because it
solved my problems.
Stanislav V. Bernatsky.
Re: Refactor > Rename [message #24073 is a reply to message #23093] |
Thu, 15 May 2003 08:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hello, Adam.
distribution?
Well, as far as I remember, I had no problem with the 2.0 pre-build
eclipse distribution. It was the last one which I downloaded from eclipse
site. Other versions were build from cvs sources.
Now I use 2.1.1 (M20030430) build from cvs source with '<javac
target="1.1"' and 'refactor->rename' works fine.
I'll recompile with '<javac target="1.3"' option and post result a bit
later.
Stanislav Bernatsky.
Re: Refactor > Rename [message #24361 is a reply to message #23809] |
Thu, 15 May 2003 13:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Is eclipse from cvs ?
> when I'am again there. - However, at home I use Eclipse 2.1 final on two
> Valentino
>> Thanks
>> Haris Peco
> with
>> > reason
> I
> come
> inside
> to
> sources
>> > deployed "jdt.ui" plugin from the Eclipse plugin directory and not the
>> > imported
> and
>> > Valentino
>> >> > Adam ?
>> >> eclipse
>> > distribution?
>> >> a.
>> >> eclipse.org
Re: Refactor > Rename [message #24648 is a reply to message #24361] |
Thu, 15 May 2003 15:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
NO, it's the "jdt.ui" plugin from inside of the Eclipse 2.1 final SDK (and
thus not from the CVS server), which I import with included sources into the
workspace and then recompile for usage in the Eclipse runtime-workspace.
Valentino
news:b9vsgl$uhh$2@rogue.oti.com...
University,
these
> > Valentino
> >> Thanks
> >> Haris Peco
along
> > with
> >> > reason
> > I
> > come
Eclipse
> > inside
seem
> > to
> > sources
the
> >> > imported
> > and
> >> > Valentino
> >> >> > Adam ?
> >> >> eclipse
> >> > distribution?
> >> >> a.
> >> >> eclipse.org
Current Time: Wed Jun 26 19:36:39 GMT 2024
Powered by FUDForum. Page generated in 0.06000 seconds
