requesting help with eclipse and using resources [message #202965] |
Tue, 10 May 2005 08:30 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: plongo99.hotmail.com
i am working my way through the sun tutorial on swing and am having a
problem with one of the examples
( http://java.sun.com/docs/books/tutorial/uiswing/learn/exampl e5.html).
my problem is that the ptogram can not find the external image files used in
the dialog boxes.
the problem seems to be that i do not know how to tell eclipse where i have
put the image files.
the relevant bits of code seem to be:
// get the images and put them in an array of ImageIcons
for (int i = 0; i < NUM_IMAGES; i++){
images[i] = createImageIcon("images/image" + i + ".jpg");
and then latter ...
// returns an image icon or null if unable to locate resource
protected static ImageIcon createImageIcon(String path){
URL imageURL = LunarPhases.class.getResource(path);
//URL imageURL = LunarPhases.class.getResource("/images/image0.jpg");
if (imageURL == null) {
System.err.println("Resource not found: " + path);
return null;
} else {
return new ImageIcon(imageURL);
what i did ...
i created a new project in eclipse, then right-mouse buttoned the project
name in eclipse and created a new folder in the project. then i transfered
the image files to the newly created image folder, created the new class,
etc.,
when i run the program i get an error message saying the image files can not
be found.
any help would be greatly appreciated.
FUDForum. Page generated in 0.02992 seconds
