Re: Background colors [message #202513 is a reply to message #202360] |
Thu, 04 October 2007 09:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Anton Leherbauer![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=aleherb%2Beclipse%40gmail.com) Messages: 490 Registered: July 2009 |
MJ wrote:
> I'm using the latest C/C++ Eclipse. I prefer black background and white
> foreground. I've changed all possible syntax color setting so that black
> background works well.
> However, I still can't change two background colors:
> 1) Folding nodes background
> I've turn on folding option in editor, then small + and - circles are
> shown up in a narrow column (just like line number column). Line number
> background is just same with background color. However, folding nodes
> background can't be changed in any options.
This is a known problem of Eclipse platform:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=179625
> 2) Hovering tooltip background
> I've enabled C/C++ hovering feature which shows identifier's definition
> in a small tooltip. Additionally, if press F2, then this tooltip
> transforms into popup window. However, both background colors are set as
> Windows' ToolTip color in display settings. By default, tooltip
> background color is set as light yellow (255, 255, 225). However, since
> my foreground color is mostly bright, its visibility is very poor. Once
> changed tooltip color setting in Windows system, then it just fine. Is
> there any way to manually change this background color?
There is already an enhancement request for that:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=194312
Anton Leherbauer
Wind River CDT Team, Austria
FUDForum. Page generated in 0.02554 seconds
