Home » Newcomers » Newcomers » Installation problem
Installation problem [message #202203] Thu, 29 March 2007 09:08 Go to next message
Originally posted by: davids.evertech.com.au
Downloaded eclipse-SDK-3.2.2-win32.zip and was extracting the contents to
my C: drive. However in the process of doing so I get the error message
"The system cannot find the file specified". Have downloaded twice from
the internet with the same result.
Attempted to grab all the missing stuff but the installation I cobbled
together doesn't have any tutorial help files; says "No standby content
available. No standby content part defined with id:
org.eclipse.platform.cheatsheet.". Not sure if this is connected with the
initial problem.
Anybody have similar experience?
David
Re: Installation problem [message #202214 is a reply to message #202203] Thu, 29 March 2007 09:36 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
> to my C: drive. However in the process of doing so I get the error
> message "The system cannot find the file specified".
What tool are you using to extract the ZIP? To what path on your drive
are you extracting it?
There have been lots of problems when people try to use the built-in ZIP
file handling in WindowsXP and if they try to extract to a long path on
their filesystem.
Hope this helps,
Eric
Re: Installation problem [message #202523 is a reply to message #202214] Fri, 30 March 2007 19:21 Go to previous messageGo to next message
I have just opened the zip file by double clicking on it in Windows XP and
then dragged the Eclipse folder to the root of my C: drive. What is wrong
with that?
David S
Re: Installation problem [message #202582 is a reply to message #202523] Sat, 31 March 2007 19:17 Go to previous message
> and then dragged the Eclipse folder to the root of my C: drive. What is
> wrong with that?
There have been reports of misadventures when unzipping the eclipse
download using the Windows default zip facility (as you are doing).
Don't know what the problem is, but something apparently goes splat on
occasion. The remedy is to download a freebie zip utility (WinZip,
ZipCentral, 7-Zip, ...) and use that to unzip the archive.
There's also apparently a problem if the unzipped path names end up too
long, but unzipping to C:\Eclipse won't be any problem.
/Paul
Previous Topic:Remove a plugin at runtime?
Next Topic:Display resultset to window dialoge box
Current Time: Fri Apr 25 19:43:54 EDT 2025
Powered by FUDForum. Page generated in 0.09541 seconds
