Home » Archived » BIRT » EngineTask.setParameterValue is becoming NULL
EngineTask.setParameterValue is becoming NULL [message #202130] Tue, 21 November 2006 15:26 Go to next message
Lavanya Pinnamareddy is currently offline Lavanya PinnamareddyFriend
Member
Hi all ,
I'm using BIRT 2_1_1.
I'm using BIRT reports in my application
log level in web.xml is "FINEST"
when i'm trying to access HTML format i'm getting this in the log file.
org.eclipse.birt.report.engine.api.impl.ReportEngine
createGetParameterDefinitionTask
FINE: ReportEngine.createGetParameterDefinitionTask:
reportRunnable=org.eclipse.birt.report.engine.api.impl.ReportRunnable@5761f9
Nov 21, 2006 8:49:35 PM org.eclipse.birt.report.engine.api.impl.EngineTask
setAppContext
FINE: EngineTask.setAppContext: context=
is something not going correctly??
PDF foramt is working fine for me.
any clue??
Lavanya PinnamaReddy
Re: EngineTask.setParameterValue is becoming NULL [message #202160 is a reply to message #202130] Tue, 21 November 2006 18:02 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Lavanya,
Is this just using the default Web Viewer example or are you using code?
If you are using the Web Viewer what does your URL look like?
Jason
"lavanya" <lavanya@pramati.com> wrote in message
news:ejv5rp$1ql$1@utils.eclipse.org...
> Hi all ,
> setAppContext
> any clue??
> Thanks
Re: EngineTask.setParameterValue is becoming NULL [message #202344 is a reply to message #202160] Wed, 22 November 2006 04:40 Go to previous messageGo to next message
Member
Jason,
I'm using default WebViewer example
URL looks like this...
http://localhost:8181/pms/frameset?__report=/AgingByVersion. rptdesign&&__format=html
http://localhost:8181/pms/frameset?__report=/AgingByVersion. rptdesign&&__format=pdf
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:ejvev8$j10$1@utils.eclipse.org...
> Lavanya,
> Jason
>> Hi all ,
>> org.eclipse.birt.report.engine.api.impl.EngineTask setAppContext
>> any clue??
>> Thanks
Re: EngineTask.setParameterValue is becoming NULL [message #202457 is a reply to message #202344] Wed, 22 November 2006 15:48 Go to previous messageGo to next message
Try
http://localhost:8181/pms/frameset?__report=/AgingByVersion. rptdesign&__format=html
Jason
news:ek0kcn$4cc$1@utils.eclipse.org...
> Jason,
>> Lavanya,
>> Jason
>>> Hi all ,
>>> any clue??
>>> Thanks
Re: EngineTask.setParameterValue is becoming NULL [message #202617 is a reply to message #202457] Thu, 23 November 2006 05:58 Go to previous messageGo to next message
Member
Same Error Jason. NO change.
Here i'm attching the log file.
any more clues??
news:ek1rgf$ojh$1@utils.eclipse.org...
> Try
> Jason
>> Jason,
>>> Lavanya,
>>> Jason
>>>> Hi all ,
>>>> any clue??
>>>> Thanks
Re: EngineTask.setParameterValue is becoming NULL [message #203046 is a reply to message #202617] Mon, 27 November 2006 15:55 Go to previous messageGo to next message
What app server are you using?
Jason
news:ek3db2$vi1$1@utils.eclipse.org...
> any more clues??
>> Try
>> Jason
>>> Jason,
>>>> Lavanya,
>>>> code?
>>>> Jason
>>>>> Hi all ,
>>>>> file.
>>>>> any clue??
>>>>> Thanks
Re: EngineTask.setParameterValue is becoming NULL [message #203217 is a reply to message #203046] Tue, 28 November 2006 05:35 Go to previous message
Member
Pramati application server.
I tested WebViewerExample. it works fine for both HTML and PDF views.
I don't think any issues with the app server.
Only problem i suspect is configuration issue , due to which it's not able
to get target service.
news:ekf1pb$g6l$1@utils.eclipse.org...
> Jason
>> any more clues??
>>> Try
>>> Jason
>>>> Jason,
>>>>> Lavanya,
>>>>> code?
>>>>> Jason
>>>>>> Hi all ,
>>>>>> file.
>>>>>> any clue??
>>>>>> Thanks
Previous Topic:escape word for "%"
Next Topic:Problems with a custom dataSetPage
Current Time: Wed Jan 15 08:58:13 GMT 2025
Powered by FUDForum. Page generated in 0.03407 seconds
