Re: AXIS Engine exception in BIRT Report Viewer [message #202162 is a reply to message #202116] |
Tue, 21 November 2006 18:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Lavanya,
Take a look at this bugzilla entry.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=142351
Jason
"lavanya" <lavanya@pramati.com> wrote in message
news:ejuoqj$50c$1@utils.eclipse.org...
> Hi all,
> I'm using BIRT reports integrated with my j2ee application.
> Environment: BIRT 2_1_1 , Pramati Application server
> I used to have all the jars inisde my server/lib directory. no problem.
> everything was fine
> Now I've moved all the jars to the application lib (web/WEB-INF/lib/).
> nothing is in my server lib folder.(* all the jars in classpath)
> Trying to open reports from the application. i'm getting the following
> error:
> " The AXIS engine could not find a target service to invoke! targetService
> is null "
> Interesting ly., I'm getting this error only when i'm using format as
> HTML.
> Pdf view is working fine.
> The ONLY difference i've in both format views is : i've a filter for pdf
> view , which does nothing excpet overriding "Content-disposition" header.
> I've tried moving the few libraies to server/lib folder and tried again.
> no luck
> I've referred this link :
> ( http://birtworld.blogspot.com/2006/01/deploying-birt-20-rc-t o-jboss.html)
> Any idea how to resolve this???
> Thanks
> Lavanya PinnamaReddy
Re: AXIS Engine exception in BIRT Report Viewer [message #203029 is a reply to message #202411] |
Mon, 27 November 2006 15:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Lavanya,
Are you still having a problem with this?
Jason
news:ek1mh6$55c$1@utils.eclipse.org...
> Tried that also.
> It used to work.
> Now it's not working.
> I suspect some configuration issue.
> other than copying from WebViewerExample, what are the things i need to
> configure??
> PS: pdf view is workign fine. problem is with on;y html view.
> "Jason Weathersby" <jweathersby@actuate.com> wrote in message
> news:ejvf8o$kjs$1@utils.eclipse.org...
>> Lavanya,
>> Jason
>>> Hi all,
>>> everything was fine
>>> error:
>>> targetService is null "
>>> HTML.
>>> header.
>>> no luck
>>> Thanks
Re: AXIS Engine exception in BIRT Report Viewer [message #203324 is a reply to message #203211] |
Tue, 28 November 2006 15:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I believe this problem has to do with the WebViewer's AJAX code using the
web service to retrieve the pages.
The WebViewer makes heavy use of the axis libs. Is there any chance you
have multiple versions of axis in the classpath?
Can you log a bug for this problem?
Jason
news:ekghnn$r7g$1@utils.eclipse.org...
> Yes Jason.
> I'm still facing the same problem.
> It's a blocker for me in my appliation to proceed..
> news:ekf1kf$fmk$1@utils.eclipse.org...
>> Lavanya,
>> Jason
>>> Tried that also.
>>> It used to work.
>>> configure??
>>>> Lavanya,
>>>> Jason
>>>>> Hi all,
>>>>> problem. everything was fine
>>>>> (web/WEB-INF/lib/). nothing is in my server lib folder.(* all the jars
>>>>> in classpath)
>>>>> error:
>>>>> HTML.
>>>>> pdf view , which does nothing excpet overriding "Content-disposition"
>>>>> header.
>>>>> again. no luck
>>>>> Thanks
FUDForum. Page generated in 0.03892 seconds
