Home » Eclipse Projects » GEF » Remove model objects or remove visuals?
Remove model objects or remove visuals? [message #202051] Mon, 07 November 2005 11:58 Go to next message
Originally posted by: larserka.stud.ntnu.no
My plugin has two models made in EMF, a datamodel and a view model.
There's a 1-to-1 mapping between
my view model and my editparts. My editparts represents a tree with nodes
and links. I need to be able
to "collapse and expand" my tree. If i click on a node I want the child
nodes and child nodes of child nodes and so on to disapear. If i click on
a collapsed node i want the child nodes to show again. How do I do this
the "clean way"?
Should I remove the visuals for the editparts that I dont want to show, or
remove the model object from the view
model?
Lars.
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Remove model objects or remove visuals? [message #202188 is a reply to message #202051] Mon, 07 November 2005 18:18 Go to previous messageGo to next message
Felix L J Mayer is currently offline Felix L J MayerFriend
My philosophy is to leave the EditParts and Figures in place as long the
model is there. But sometimes I make Figures invisible depending on flags in
the model. This means that my LayoutManager needs to check if Figures are
invisible and behave accordingly.
"Lars Erik" <larserka@stud.ntnu.no> wrote in message
news:op.szvcv8zxle1400@b222-02.ad.ime.ntnu.no...
> the "clean way"?
> model?
> Lars.
Re: Remove model objects or remove visuals? [message #202218 is a reply to message #202051] Mon, 07 November 2005 19:09 Go to previous messageGo to next message
venkataramana m is currently offline venkataramana mFriend
Member
Any tree-node (view-model element) is either in a collapsed or expanded state. Based on that, you can toggle between returning list of children or empty-list. And ofcourse may be to reflect the current state in visuals as well, createFigure may return a figure for the node with different decorations.
So I think it is easy and better to deal with view-model rather than adding/removing child visuals.
~Venkat
Re: Remove model objects or remove visuals? [message #202244 is a reply to message #202188] Mon, 07 November 2005 22:06 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
I like making figures invisible too. I had severe problems for
instance, trying to add a label figure and remove it based on a property
of the model. This was because of my funky layout manager I am guessing.
So I dont relayout them. I add figure, and setVisible depending on what
the model wants.
If its only appearance, I wouldnt remove the models. Tree does not
'remove' its nodes from the model when they are hidden.
CL
>>the "clean way"?
>>model?
>>Lars.
Re: Remove model objects or remove visuals? [message #202275 is a reply to message #202051] Tue, 08 November 2005 01:39 Go to previous message
Originally posted by: ganshuman.126.com
you can use flag to indicate the showmodel in editpart. all in attachment.
??????:op.szvcv8zxle1400@b222-02.ad.ime.ntnu.no...
> the "clean way"?
> model?
> Lars.
  • Attachment: subject.zip
    (Size: 83.05KB, Downloaded 114 times)
Previous Topic:Move connection label
Next Topic:Why doesn't the Tool of a CombinedTemplateCreationEntry get used for drag and drop from the palette?
Current Time: Thu Dec 26 12:34:09 GMT 2024
Powered by FUDForum. Page generated in 0.04192 seconds
