cygwin linux remote debugging [message #201513] |
Thu, 13 September 2007 08:47 |
after 5 Day's I found out what must I do for remote debugging of a RedHat
linux from Windows (generate a crosscompile and crossdebugger and use
gdbserver on Linux side). Now I try to remote debugging for eclipse.
I setup eclipse with RSE to connect the linux over ssh.
it looks good.
console
$ "gdbserver :7774 /dflentw/tmp/eclipse_test/ws1/test_2/Debug/ test_2;exit
Process /dflentw/tmp/eclipse_test/ws1/test_2/Debug/test_2 created; pid =
28322
Listening on port 7774
Remote debugging from host XX.X.XX.XX"
The gdbserver is started on linux, my linux crossdebugger is started on
Windows, but I can debugging.
I get following messages when I start the Debug As:
console:
"warning: Unable to find dynamic linker breakpoint function.
GDB will be unable to debug shared library initializers
and track explicitly loaded dynamic code."
I think that is not important for my at the moment, because my testcase is
only hello Word.
But I get the Java error
!ENTRY org.eclipse.ui.console 4 2 2007-09-13 13:57:42.641
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.console".
!STACK 0
org.eclipse.cdt.debug.mi.ui.console.actions.MiConsoleVerbose ModeAction. <init>(MiConsoleVerboseModeAction.java:32)
org.eclipse.cdt.debug.mi.ui.console.MiConsolePageParticipant .init(MiConsolePageParticipant.java:70)
at org.eclipse.ui.internal.console.ConsoleView$3.run(ConsoleVie w.java:312)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.ui.internal.console.ConsoleView.doCreatePage(Con soleView.java:310)
at org.eclipse.ui.part.PageBookView.createPage(PageBookView.jav a:399)
at org.eclipse.ui.part.PageBookView.partActivated(PageBookView. java:741)
at org.eclipse.ui.internal.console.ConsoleView$4.run(ConsoleVie w.java:380)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:158)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:326)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:495)
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:268)
org.eclipse.ui.internal.progress.ProgressManager$3.run(Progr essManager.java:909)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:944)
org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:919)
org.eclipse.debug.internal.ui.DebugUIPlugin.launchInForegrou nd(DebugUIPlugin.java:993)
at org.eclipse.debug.ui.DebugUITools.launch(DebugUITools.java:5 30)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.handleLaunchPressed(LaunchConfigurationsDi alog.java:1002)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.buttonPressed(LaunchConfigurationsDialog.j ava:316)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:1133)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:38 7)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:391)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:333)
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:82)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
org.eclipse.pde.internal.runtime.logview.EventDetailsDialog. open(EventDetailsDialog.java:184)
org.eclipse.pde.internal.runtime.logview.EventDetailsDialogA ction.run(EventDetailsDialogAction.java:91)
org.eclipse.pde.internal.runtime.logview.LogView$12.doubleCl ick(LogView.java:394)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:799)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 3)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:797)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1384)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1173)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:237)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:234)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:295)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
!ENTRY org.eclipse.ui.console 4 120 2007-09-13 13:57:42.657
!MESSAGE Error logged from Console plug-in:
!STACK 0
!ENTRY org.eclipse.debug.ui 4 120 2007-09-13 13:57:42.860
!MESSAGE Error within Debug UI:
!STACK 0
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:350)
Caused by: java.lang.NoSuchMethodError:
org.eclipse.cdt.debug.core.CDIDebugModel.newDebugTarget(Lorg /eclipse/debug/core/ILaunch;Lorg/eclipse/core/resources/IPro ject;Lorg/eclipse/cdt/debug/core/cdi/model/ICDITarget;Ljava/ lang/String;Lorg/eclipse/debug/core/model/IProcess;Lorg/ecli pse/cdt/core/IBinaryParser$IBinaryObject;ZZLjava/lang/String ;Z)Lorg/eclipse/debug/core/model/IDebugTarget;
org.eclipse.rse.internal.remotecdt.RemoteRunLaunchDelegate.l aunch(RemoteRunLaunchDelegate.java:137)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:985)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Root exception:
and no output from my testcase.
I don't know is my programm running in debugger or not.
The Debug TAB shows me that the Remote Shell, debugger and the Programm is
running, but it is not stopping on my break point.
I hope anybody have an idea.
Ralf
FUDForum. Page generated in 0.05901 seconds
