Home » Archived » BIRT » Null pointer Exception - further info
Null pointer Exception - further info [message #201402] Thu, 16 November 2006 16:26 Go to next message
Originally posted by: stuart.polonious.com.au
So I got the java from the CVS. Although I think it's HEAD, couldn't
get any release tags showing.
I think this is the LOC that is in error for me. It's looking like a
config parameter:
IResourceLocator locator = config.getResourceLocator( );
ResourceLocator??
This is the method:
public IReportRunnable openReportDesign( String designName )
throws EngineException
logger.log( Level.FINE,
"ReportEngine.openReportDesign: designName={0} ", designName );
return helper.openReportDesign( designName, locator);
Re: Null pointer Exception - further info [message #201435 is a reply to message #201402] Thu, 16 November 2006 16:52 Go to previous messageGo to next message
--------------020404090201020701040107
Content-Type: text/plain; charset=ISO-8859-1
Further info:
I have followed the http://wiki.eclipse.org/index.php/Servlet_Example
example to the letter and it works fine for one report (attached) but
not for the other (previously attached).
Any help greatly appreciated.
Stuart Guthrie
Content-Type: text/xml;
name="WorkQueueByDeveloper.rptdesign"
Content-Disposition: inline;
filename="WorkQueueByDeveloper.rptdesign"
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.2" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 1.0.1 Build &lt;20051130-1157></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 &lt;&lt;Your Company Name here>></property>
<data-sources>
<oda-data-source extensionID="org.eclipse.datatools.connectivity.oda.flatfile " name="Data Source" id="41">
<text-property name="displayName">Data Source</text-property>
<property name="HOME">/tmp/reports</property>
<property name="CHARSET">UTF-8</property>
<property name="INCLTYPELINE">NO</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.datatools.connectivity.oda.flatfile.dataSet " name="Data Set" id="42">
<text-property name="displayName">Data Set</text-property>
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">"DateFrom"</property>
<property name="dataType">string</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">"DateTo"</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">"TaskId"</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">"Description"</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">"TaskTypeDescription"</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">"LocationDescription"</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">"AllocatedDate"</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">"ReviewDate"</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">"DueDate"</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">"OriginalDueDate"</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">"CompletedDate"</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">"TimeInDays"</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">"Timeliness"</property>
</structure>
<structure>
<property name="position">14</property>
<property name="name">"OverDueDays"</property>
</structure>
<structure>
<property name="position">15</property>
<property name="name">"Complaints"</property>
</structure>
<structure>
<property name="position">16</property>
<property name="name">"DiaryTextSize"</property>
</structure>
<structure>
<property name="position">17</property>
<property name="name">"TaskStatus"</property>
</structure>
<structure>
<property name="position">18</property>
<property name="name">"ClientName"</property>
</structure>
<structure>
<property name="position">19</property>
<property name="name">"SupplierName"</property>
</structure>
<structure>
<property name="position">20</property>
<property name="name">"LegalPrivilege"</property>
</structure>
<structure>
<property name="position">21</property>
<property name="name">"QtrAllocated"</property>
</structure>
<structure>
<property name="position">22</property>
<property name="name">"MthAllocated"</property>
</structure>
<structure>
<property name="position">23</property>
<property name="name">"QtrCompleted"</property>
</structure>
<structure>
<property name="position">24</property>
<property name="name">"MthCompleted"</property>
</structure>
<structure>
<property name="position">25</property>
<property name="name">"Actual Savings"</property>
</structure>
<structure>
<property name="position">26</property>
<property name="name">"Invoiced Cost"</property>
</structure>
<structure>
<property name="position">27</property>
<property name="name">"Expenses"</property>
</structure>
<structure>
<property name="position">28</property>
<property name="name">"Kms"</property>
</structure>
<structure>
<property name="position">29</property>
<property name="name">"BudgetTimeIncludingTravel"</property>
</structure>
<structure>
<property name="position">30</property>
<property name="name">"BudgetTime"</property>
</structure>
<structure>
<property name="position">31</property>
<property name="name">"Time On Job"</property>
</structure>
<structure>
<property name="position">32</property>
<property name="name">"Travel Time"</property>
</structure>
<structure>
<property name="position">33</property>
<property name="name">"Total Cost"</property>
</structure>
<structure>
<property name="position">34</property>
<property name="name">"Secondary Client"</property>
</structure>
<structure>
<property name="position">35</property>
<property name="name">"Tertiary Client"</property>
</structure>
<structure>
<property name="position">36</property>
<property name="name">"Business"</property>
</structure>
<structure>
<property name="position">37</property>
<property name="name">"Business Unit"</property>
</structure>
<structure>
<property name="position">38</property>
<property name="name">"Client Contact First Name"</property>
</structure>
<structure>
<property name="position">39</property>
<property name="name">"Client Contact Last Name"</property>
</structure>
<structure>
<property name="position">40</property>
<property name="name">"Contact First Name"</property>
</structure>
<structure>
<property name="position">41</property>
<property name="name">"Contact Last Name"</property>
</structure>
<structure>
<property name="position">42</property>
<property name="name">"Contractor First Name"</property>
</structure>
<structure>
<property name="position">43</property>
<property name="name">"Contractor Last Name"</property>
</structure>
<structure>
<property name="position">44</property>
<property name="name">"Customer Relations First Name"</property>
</structure>
<structure>
<property name="position">45</property>
<property name="name">"Customer Relations Last Name"</property>
</structure>
<structure>
<property name="position">46</property>
<property name="name">"Developer First Name"</property>
</structure>
<structure>
<property name="position">47</property>
<property name="name">"Developer Last Name"</property>
</structure>
<structure>
<property name="position">48</property>
<property name="name">"External Developer First Name"</property>
</structure>
<structure>
<property name="position">49</property>
<property name="name">"External Developer Last Name"</property>
</structure>
<structure>
<property name="position">50</property>
<property name="name">"Internal Reviewer First Name"</property>
</structure>
<structure>
<property name="position">51</property>
<property name="name">"Internal Reviewer Last Name"</property>
</structure>
<structure>
<property name="position">52</property>
<property name="name">"Internal Staff First Name"</property>
</structure>
<structure>
<property name="position">53</property>
<property name="name">"Internal Staff Last Name"</property>
</structure>
<structure>
<property name="position">54</property>
<property name="name">"Manager First Name"</property>
</structure>
<structure>
<property name="position">55</property>
<property name="name">"Manager Last Name"</property>
</structure>
<structure>
<property name="position">56</property>
<property name="name">"Prospect First Name"</property>
</structure>
<structure>
<property name="position">57</property>
<property name="name">"Prospect Last Name"</property>
</structure>
<structure>
<property name="position">58</property>
<property name="name">"Rep First Name"</property>
</structure>
<structure>
<property name="position">59</property>
<property name="name">"Rep Last Name"</property>
</structure>
<structure>
<property name="position">60</property>
<property name="name">"Supplier Contact First Name"</property>
</structure>
<structure>
<property name="position">61</property>
<property name="name">"Supplier Contact Last Name"</property>
</structure>
<structure>
<property name="position">62</property>
<property name="name">"User Contact First Name"</property>
</structure>
<structure>
<property name="position">63</property>
<property name="name">"User Contact Last Name"</property>
</structure>
<structure>
<property name="position">64</property>
<property name="name">"Customer Reference"</property>
</structure>
<structure>
<property name="position">65</property>
<property name="name">"Issue Number"</property>
</structure>
<structure>
<property name="position">66</property>
<property name="name">"Priority"</property>
</structure>
<structure>
<property name="position">67</property>
<property name="name">"Version"</property>
</structure>
<structure>
<property name="position">68</property>
<property name="name">"Client Reporting Code"</property>
</structure>
<structure>
<property name="position">69</property>
<property name="name">"Search Code"</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<property name="queryText">select * from TaskReport.csv</property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<grid id="3">
<property name="width">100%</property>
<column id="4"/>
<row id="5">
<cell id="6">
<text id="7">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</cell>
</row>
</grid>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="8">
<property name="height">0.333in</property>
<property name="width">5.968in</property>
<column id="9"/>
<row id="10">
<property name="verticalAlign">text-bottom</property>
<cell id="11">
<property name="verticalAlign">top</property>
<label id="12">
<property name="fontFamily">sans-serif</property>
<property name="fontWeight">bold</property>
<property name="textUnderline">underline</property>
<property name="textAlign">center</property>
<text-property name="text">Work Queue By Developer</text-property>
</label>
</cell>
</row>
</grid>
<table name="table1" id="13">
Re: Null pointer Exception - further info [message #201493 is a reply to message #201435] Thu, 16 November 2006 18:11 Go to previous messageGo to next message
This issue was rectified by removing chartengine from the WEB-INF/lib
directory... Interestingly this fixed the issue but charts still work.
So maven 2.0 dependencies for Birt are now:
<!-- Add Birt 2.1.0 Support -->
<dependency>
<groupId>birt-runtime</groupId>
<artifactId>dte</artifactId>
<version>2.1.0</version>
</dependency>
<dependency>
<artifactId>model</artifactId>
</dependency>
<dependency>
<artifactId>engine</artifactId>
</dependency>
<dependency>
<artifactId>scriptapi</artifactId>
</dependency>
<dependency>
<artifactId>flute</artifactId>
</dependency>
<dependency>
<artifactId>core</artifactId>
</dependency>
<dependency>
<artifactId>js</artifactId>
</dependency>
<dependency>
<artifactId>sac</artifactId>
</dependency>
<dependency>
<groupId>org.eclipse.emf</groupId>
<artifactId>common</artifactId>
<version>2.2.0</version>
</dependency>
<dependency>
<artifactId>ecore-xmi</artifactId>
</dependency>
<dependency>
<artifactId>ecore</artifactId>
</dependency>
<dependency>
<groupId>commons-cli</groupId>
<artifactId>commons-cli</artifactId>
<version>1.0</version>
</dependency>
<dependency>
<groupId>commons-codec</groupId>
<artifactId>commons-codec</artifactId>
<version>1.3</version>
</dependency>
<dependency>
<artifactId>commons-discovery</artifactId>
<version>0.2</version>
</dependency>
<dependency>
<artifactId>jaxrpc</artifactId>
</dependency>
<dependency>
<artifactId>viewservlets</artifactId>
</dependency>
<dependency>
<artifactId>saaj</artifactId>
</dependency>
<!--wsdl4j, leave for now, we are not calling currently calling
webservices in birt-->
<!-- Removed due to reported OSGI bug.
<dependency>
<artifactId>chart-engine</artifactId>
</dependency>
<dependency>
<groupId>com.ibm</groupId>
<artifactId>icu</artifactId>
<version>3.4.4.1</version>
</dependency>
<dependency>
<artifactId>dataadapter</artifactId>
</dependency>
<!-- End of BiRT depencencies-->
Stuart Guthrie
Stuart Guthrie wrote:
> Further info:
> Stuart Guthrie
> <data-sources>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
Re: Null pointer Exception - further info [message #201662 is a reply to message #201493] Fri, 17 November 2006 12:48 Go to previous message
Stuart,
Can you add something to the Wiki that states what you did?
Look at the comments section of the servlet example.
Jason
"Stuart Guthrie" <stuart@polonious.com.au> wrote in message
news:ejir6h$s2e$2@utils.eclipse.org...
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> Stuart Guthrie
>> Further info:
>> Stuart Guthrie
>> <?xml version="1.0" encoding="UTF-8"?>
>> id="1">
>> <data-sources>
>> <oda-data-source
>> Source" id="41">
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> Code"</property>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> Client"</property>
>> </structure>
>> <structure>
>> Client"</property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
>> </structure>
>> <structure>
>> Name"</property>
Previous Topic:Error after deploying my report on tomcat
Next Topic:Width in ems for PDF not working?
Current Time: Sun Nov 02 17:52:50 EST 2025
Powered by FUDForum. Page generated in 0.04566 seconds
