Diagram xml and default.xml [message #201135] |
Fri, 08 August 2008 12:46 |
Originally posted by: sk_stani.gbg.bg
Hallo,
I need to use different xml from the default one to generated my gmf
diagram.
More precisely I want to adopt already existing xml (which has all the
information needed to generate a diagram but in different format). I saw
that in the default one are used xmi and xmlns is there way to avid them.
Could some one point me the place where these xmls are parsed and/or a way
to change these classes.I am not sure that my question is completely
understandable and correct so don't hesitate to correct me!
Best Regard Stanislav
Re: Diagram xml and default.xml [message #201199 is a reply to message #201161] |
Fri, 08 August 2008 14:24 |
Sorry but it seems that i have mistaken i don't want my meta model to
generate my meta model with xsd but to have my diagram xml ( i am talking
about after you have created a diagram not to store it in a default way )
Re: Diagram xml and default.xml [message #201426 is a reply to message #201309] |
Mon, 11 August 2008 14:28 |
Alex,
I have one more question. I've read a post from you that there are option
to storing model and diagram information in the same file. what is it's
name and where it is located
Thanks for the help
FUDForum. Page generated in 0.03978 seconds
