Home » Eclipse Projects » Subversive » using existing subtree copy
using existing subtree copy [message #19124] Mon, 19 May 2008 14:26 Go to next message
Hi!
Say, I have (manually checked out) local SVN subtree copy and a (not-Java)
project this subtree uses. I'd want to be able (and having read-only rights
only) to update the subtree inside the IDE instead of 'svn up'. Which the
plugin subcomponents must I install? What are my further steps?
Re: using existing subtree copy [message #19128 is a reply to message #19124] Tue, 20 May 2008 10:06 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Andrew,
If I correctly understand your situation, you can do following:
1) Install into Eclipse IDE Subversive plug-in. Minimally required set is
SVN Team Provider itself and any of available connector libraries. More
about installing this plug-ins you can read at:
http://www.eclipse.org/subversive/downloads.php
2) Then you can create new project at the path of content which is already
checked out from SVN.
After that you can share imported file system content with the Subversive
SVN team provider.
Andrew Gaydenko wrote:
> Hi!
Re: using existing subtree copy [message #19136 is a reply to message #19128] Tue, 20 May 2008 18:06 Go to previous messageGo to next message
Alexander, hi!
> Hello Andrew,
I have did it.
> SVN team provider.
And this is a problem. Now I have a project, project's root has two dirs and
three files checked out (as well as .svn dir). Project context menu - Team
has the only menu item "Apply patch".
>> Hi!
>> (not-Java) project this subtree uses. I'd want to be able (and having
>> read-only rights only) to update the subtree inside the IDE instead of
>> 'svn up'. Which the plugin subcomponents must I install? What are my
>> further steps?
Re: using existing subtree copy [message #19233 is a reply to message #19136] Wed, 21 May 2008 11:45 Go to previous messageGo to next message
Hi, Andrew.
Let me ask you some questions.
1. Is there the same problem with sharing the freshly-created project?
2. What Eclipse IDE version are you using?
If it's Eclipse 3.4 M7, please make sure that the plug-in is fully
installed. Cause there's a problem with this build, cause update-manager
(see https://bugs.eclipse.org/bugs/show_bug.cgi?id=230233)
The easiest way to get to know it is to check if there an 'SVN' group in
Eclispe IDE preferences (Window->Preferences).
Please let me know ASAP.
Best regards,Alexei Goncharov
Subversive team
Re: using existing subtree copy [message #19253 is a reply to message #19233] Wed, 21 May 2008 15:58 Go to previous messageGo to next message
Alexei Goncharov wrote:
> Hi, Andrew.
Alexei, hi!
What do you mean with "freshly-created"? As I have mentioned, I have no
write access rights to really *share* something.
Andrew
I use v.3.3.1.1 with 2008.05.17 subversive/connectors zipped sites (have
tried v.3.4rc1, and last one fails to build, but this is another story).
> Subversive team
Re: using existing subtree copy [message #19299 is a reply to message #19253] Thu, 22 May 2008 05:44 Go to previous message
> Alexei, hi!
"Project context menu - Team
has the only menu item "Apply patch"."
I mean this one). Is the freshly created project behaves the same?
Was you projected checked out via command-line?
Previous Topic:Using Subversive with non-local filesystem resources
Next Topic:0.7.0.v20080307 fails be to be installed form a local site
Current Time: Mon Apr 28 02:46:39 EDT 2025
Powered by FUDForum. Page generated in 0.03913 seconds
