Eclipse - C++ - Cannot step into function [message #200333] |
Mon, 27 August 2007 16:44 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: someone.nospam.net
I am using Eclipse Europa under Redhat Enterprise 3
I have set up a test project to get used to the environment and see if it is
usable for work.
I made a hello world program
calls
foo() from libtest.a
bar() from libtest2.a
Everything compiles and runs fine. I debug and it stop at main. I use F5 to
Step into and F6 to step over. It will try to step into cout but cannot find
the source, which is fine. However, when I try to step into the foo() or
bar() functions it just skips over them instead of stepping into them. I
really need to be able to step into functions for this to be a usable
environment!
It further confuses me that I can right click the function call in
HelloWorld, and click go to definition, and it finds the source. So, why
can't the debugger step into the function?
1) Helloworld, libtest.a, and libtest2.a are all compiled using g++ -g in
thier Makefiles, and are all part of the Eclipse workspace
2) HelloWorld has libtest.a and libtest2.a directories listed under
Properties -> C/C++ Include Paths and symbols -> Discovered Paths ->
Include Paths
3) libtest.a and libtest2.a are both checked under HelloWorld ->
Properties -> Project References
4) HelloWorld -> Properties -> Run/Debug Settings -> HelloWorld -> Edit ->
Source -> Default has both libraries directories listed
5) HelloWorld -> Properties -> Run/Debug Settings -> HelloWorld -> Edit ->
Source -> Workspace has both libraries directories listed
6) HelloWorld -> Properties -> Run/Debug Settings -> HelloWorld -> Edit ->
Debugger has:
debugger: gdb debugger
main tab -> GDB debugger: gdb
main tab -> GDB command file: <blank>
main tab -> Protocol: default
Does anyone have any ideas on why Eclipse skips over the functions I want to
step into?
Re: Eclipse - C++ - Cannot step into function [message #200387 is a reply to message #200333] |
Mon, 27 August 2007 21:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
"Christopher Pisz" <someone@nospam.net> wrote in message
news:fauv1p$8p6$1@build.eclipse.org...
> is usable for work.
> calls
> to Step into and F6 to step over. It will try to step into cout but cannot
> find the source, which is fine. However, when I try to step into the foo()
> or bar() functions it just skips over them instead of stepping into them.
> I really need to be able to step into functions for this to be a usable
> environment!
> Include Paths
> Debugger has:
> to step into?
Found the problem. It was my makefile macros. I had one for include paths
and if it was empty it figured the following -g was the path instead of the
debug flag.
FUDForum. Page generated in 0.02548 seconds
