Home » Language IDEs » ServerTools (WTP) » Design view with WTP?
Design view with WTP? [message #200232] Sat, 22 September 2007 13:21 Go to next message
Originally posted by: neorf.despammed.com
How can i have the design view as dreamweaver? i've seen this image at this
post http://dev.eclipse.org/newslists/news.eclipse.webtools/msg13 837.html
where has been activated some buttons to switch between showing only source
code, only design or both divided either horizontally or vertically.
how can i activate it? i've installed complete WTP plugin
thanks
neorf
Re: Design view with WTP? [message #200240 is a reply to message #200232] Sat, 22 September 2007 21:34 Go to previous messageGo to next message
David Carver is currently offline David CarverFriend
> thanks
You need to install the full version of WTP as it isn't included in the
WST distribution. Just install the complete JEE and JST packages, and
I think you should get what you want. You then want to open HTML pages
using the Web Page Designer editor instead of the HTML editor.
Re: Design view with WTP? [message #200271 is a reply to message #200240] Sun, 23 September 2007 14:05 Go to previous messageGo to next message
Into Eclipse, how can i open page with Web Page Design? what do you mean?
i just use File-> Open... or File->New Project... how can i choose?
thanks
neorf
Re: Design view with WTP? [message #200279 is a reply to message #200240] Sun, 23 September 2007 16:16 Go to previous messageGo to next message
Werner Keil is currently offline Werner KeilFriend
Cool, thanks a lot for the tip.
One thing you notice in this screenshot quite badly (though it is the
Java Perspective) as well as the latest WTP 3 preview is some
perspectives still being extremely cluttered with 'single-button'
toolbars...
Has anybody thought about getting those more compact at least for WTP ??
(I'm not talking about every Eclipse project out there)
Take Mylyn for example, as it has become part of most Europa distros by
now. Mylyn blends in perfectly with some of the standard Eclipse
Workbench toolbars and places its 'New Task' button into this combo
instead of wasting space by introducing its own 'New' toolbar just for
this one buttton.
I am wondering, why the 5 'New something' actions in WTP could not also
be grouped better or at least some of them use this extension point?
If you think, Bugzilla is a better place to claim such issue, please let
me know? Also, should there be a similar entry already (well, if I find
time, I might just use Mylyn to search for it anyway ;-)
Werner
David Carver wrote:
>> this post
>> source code, only design or both divided either horizontally or
>> vertically.
>> thanks
Re: Design view with WTP? [message #200328 is a reply to message #200271] Sun, 23 September 2007 23:36 Go to previous messageGo to next message
ok, done just with right click on .htm file and i've chosen: open with-> web
page editor...
thanks
neorf
Re: Design view with WTP? [message #200370 is a reply to message #200279] Mon, 24 September 2007 04:44 Go to previous message
Lawrence Mandel is currently offline Lawrence MandelFriend
>me know?
I think so. Opening the issue in bugzilla ensures it won't get lost in the
mass of incoming requests. If you don't have time or can't find a similar
bug I'd err on the side of opening a bug. The owner will mark as a dup if
an existing bug is already open.
Lawrence
Previous Topic:Validating an XML snippet against a default schema, without referencing it
Next Topic:Exporting WSDL as image
Current Time: Thu Dec 26 18:38:06 GMT 2024
Powered by FUDForum. Page generated in 0.03454 seconds
