Modified JBoss plugin which waits for successful deploy [message #200009] |
Wed, 19 September 2007 09:07 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
--------------020000060706050906030703
Hi everybody,
I was a bit annoyed about the sleep timeouts in the WTP 2.0 JBoss plugin, so I
tried to modify it to use JBoss specific logic to wait for successful
deployment, no matter whether it takes 1 second or 2 minutes.
I modified the WTP internal JBoss plugin, attached are the modified files
(buildfiles/jboss323.xml and some pieces of code).
Maybe someone wants to take a look at it, comment about it and has improvement
suggestions.
Basically, I connect to the MBean server and use methods of the MainDeployer MBean:
InitialContext ctx = new InitialContext(props);
MBeanServerConnection server = (MBeanServerConnection)
ctx.lookup("jmx/invoker/RMIAdaptor");
ObjectName objName = new ObjectName("jboss.system:service=MainDeployer");
Object objIsDeployed = server.invoke(objName, "isDeployed",
new Object[] { strUrl },
new String[] { "java.lang.String" });
This is the first alpha, there is still a lot to do.
Known issues:
-fails sometimes for JAR and WAR files. EAR seem to work fine.
-undeploy task should first undeploy, then delete the file.
-works only for servers on localhost:8080
-fails on deploy during server startup.
-should have a maximum wait timeout if something fails.
Usage: extract the files to
" plugins\org.eclipse.jst.server.generic.jboss_1.5.102.v200706 08 "
I tested it against JBoss 4.2 on a windows machine, should work with 4.0, too.
5.0 Beta2 fails, probably because the MainDeployer is work in progress. It could
even work with WTP 1.5 ;-). The code is compiled with JDK 1.5.
Best regards
Wolfgang Knauf
Content-Type: application/x-zip-compressed;
name="buildfiles.zip"
Content-Disposition: inline;
filename="buildfiles.zip"
UEsDBAoAAAAAAAmfMjcAAAAAAAAAAAAAAAAOAAAAYnVpbGRmaWxlcy9kZS9Q SwMECgAAAAAA
CZ8yNwAAAAAAAAAAAAAAABQAAABidWlsZGZpbGVzL2RlL2tuYXVmL1BLAwQK AAAAAAAJnzI3
AAAAAAAAAAAAAAAAHAAAAGJ1aWxkZmlsZXMvZGUva25hdWYvZWNsaXBzZS9Q SwMECgAAAAAA
Q7YyNwAAAAAAAAAAAAAAACoAAABidWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlw c2UvamJvc3Nk
ZXBsb3llci9QSwMEFAACAAgAc7MyN/0TLLy6AQAAJQMAAEEAAABidWlsZGZp bGVzL2RlL2tu
YXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9KQm9zc0RlcGxveWVyVXRpbC5j bGFzc5VS227T
QBA90yax65q2mPRCuRdok5Ri4JEgHgriAUXwUBpEparaxNt008WO1hskPoW/ gJdUAokP4KMQ
YzuiQIoE+zBn58zZmdnZ/fb981cA97HlYIpwL5LhcSyGh6HsajVIZdjvJGka yYFO3ksTPt9m
7+nY27VKOygRFvrinQi1iHvhy05fdi2h8kjFyj4mTNfqbULpSRJJD9OY8VFG hTDfUrF8MXzb
keaV6GhJCFpJV+i2MCrzx2TJHqmU8KD1v301CbM9aXN+12jCeq112uWONSru NeuTlIvzBAo9
XMCig+pvdyskPpawTPBSK4xNXyt7RFg8K/meg4uE5T8D20OlI2lcXCKUD5WW Dz2s4Eo2l6t/
ydTOFNd93MAaT1YMBjKOCFv/dKNxuWaW4paP21gnuDYpgoRq7cwh1LhO3lvI 6oPUmmeqeKMJ
LU9iJxmariwUSxMvcTc7wq3zV0C2pnjHX4Ctw17ISIzlxgncT3nYY1vJSRez bP1CwHiOcQZz
mB8f3ueUWWyzESyMEHxA9QtW3gSrJ7jcGOHaCDc/5sTGL8TPEnN5PwEnrGKV h3NaahN1NBiJ
d5n6zg9QSwMEFAACAAgAcrMyN8vPOIIaAQAAFAIAAEAAAABidWlsZGZpbGVz L2RlL2tuYXVm
L2VjbGlwc2UvamJvc3NkZXBsb3llci9KQm9zc0RlcGxveWVyVXRpbC5qYXZh fY5BS8QwEIXv
hf6HoafuCs3dZWFXxYN6UsoeJdtO2rixDckUFfG/O0na3hSSGZh5871nZXOR HUKL1WWQk6qw
Mdp6rN7Oo/ctWjN+odvlWZ6J7bYmbaAx0ntQowPqEaIOFmGewRZiOciJetac RqM6OXTwGPBh
Fb7IMzudjW5m2sMNU+5mSHDJs2/WAXveOpSE0SuqoH5+Wt29xUYrjS0obbAK 1pAShHaw0sl3
ePXk7nm9TB3S5AY4RpIn6Uhzvg9NPRQBcy2KJBWhzTlZR9xeyAVxhxTD1M6U 82hx2YSjGJ7j
i2PbrlCwDpX+rNJOKyiXmyqm8CeOUBai2MB+D+SmxFppAHPyBCzgajXdJcVP amg8/ncp/jrl
wu8XUEsDBBQAAgAIAAy1MjdNp33twwUAAI4KAAA/AAAAYnVpbGRmaWxlcy9k ZS9rbmF1Zi9l
Y2xpcHNlL2pib3NzZGVwbG95ZXIvVW5kZXBsb3lBbmRXYWl0LmNsYXNzlVbr cxNVFP/dJulu
QxDYlkeBYgoW2lI2gPJoyqstVIppQdKHaRHcJLfptpvddXdTUhXF9/v9QP2A fnH8gh9kxhTt
iDh+0xn54Dj+N+rZ3bSlNIC2M3vvPfeec8/5/c49J7/+/cN1ALtwSUAVg5zl sUldKYzFeEZT
TZvHJtKGbWe5qRnT3IoN6v60U88OK6ojIMiwckKZUmKaoudiJ9MTPOMwVB9Q ddU5xBBobhli
CHYbWR5GADURhFDNsCKh6ry/kE9za0BJa5xBShgZRRtSLNVdl4VBZ1y1GXYm /p9XHaSZV1Sd
YU3zaGLBu6RjqXquo6W3BqtQK0Ba5Hty2nZ4PoI6rCa/jQKFsdpXVo3YKdJ0 SJ8r+Q4Raxk2
3HZn9LxiR21HsRyeDaMeGwSsZ6itoB/BRjQwCKYr0sjJ1c0VfBwScD/D5oWN Xk3jOUXrtHKF
PNedY8UMNx3V0AU0Mqy93UBXQdWy3BKxhaH1WFHJONp01NB5VCnrR/MF24mm edQ2eUYdU3k2
2hiPhhFFk8tRgzvbFkEzWohNxTS5nmXY2NzbkrjDVR2uxvYI2rCDQXQMf5Oh rnmpCp3dhKYw
dmK3gF1E8D34PdFFq6Pl1aCjahE8iIcYluW44+0NWhrD1ko4LhUJ2EteeeIC mSJqDJNbjsrt
MPagRkQ7setuy7qSJwV5jNAzrGnZTWlV0URQfm0zrJw8oZskdLhFJ7gt93vH uw2SFJ0eX8k1
eTCCQzhM3trcKV82zbC/grd3999/XJR+ncREJQcLliabkzlbRDelhOehC+Pc MYKWiBdxjGHd
reqmZUypxKCrL+JhFxzdjMdimvsixw3bie/a2d4uoLeMSzHmK8Z6fUDKEYdx HI+4uZMg++Xg
PICPK/a44z5oymoR/fQqJ/LFmKpPGZPE7em+3s6sYlIAroFTETyK05RymmFM Fsx7k1oGRcAA
nfW9yyu6kuNuksf6uriiJ7k1xS3yUqeT3osZmo/klrO+JSKRi3iModHHzvaq QtwmG2qGH+yj
sjKXiGEMoqkGo3hcwBmGVQtOdRmGRhdHcBbnGEI9nYkkgV6bWHKCyFSIKreA UGDRMcOKFsp1
RZZlERmGsDqX+VkBfHHF8uAQkStLZVcq+9JlSEKNYAKTBKaPNYPqg3mHsCuk 3+hSpEf/Ex9h
goUqnQ6DIZL2gx1StAL3WsKIiCcZmOwWSjsCx62HIa8ehuD/UQ0t4ikB04sC HhinApqN4Gk8
Qwq2xjllSLD5hJtXz1LedppmVLXnIXRrWmMYF/GCgOfnirFnaL56RvCi149M vz4rmckBix4z
WaVCSa2ntkK4BKjtWF7JkSrtUiSGSbprEpWKDB0IZJwiQ0PiLo/Ju8TLW4YK pFXMa9IRjPSE
S+WC9cpMMyxPG1rvfGbRmjRvXUtLOWWo4sX5prgYR9oMJ42CleE9qtu5625r j7Krg0ZQ8B6/
VTSjXwL0FWgVo5HRGGqdgfittx2mb7UnDGMZfSP+ARqX01iD+7DCV2Y/Q6R/ 4K+rWCmtKWFd
6/XgF9g4i02pWURT0uYZPNB6vYStJZB5+afWwO5riCVmsSc1g319bdJ+KV7C geE26YjU5U+O
Sj3uZBbHU20zONG/Q+or4eQNJOPBWQympOEZpOKhqxiJV7uXPkGXfo1D9cH6 kJQO/ohAKrA9
SWM2FZDGkt9jPIS4UC/cwGi8ur66BO0zrHL1zBKsOhSu4bwn/fyfG670gmct nNhewnNVVwJX
KEwRv+F3ymMfFh0b6FtH0nUEw3psox8UMjXfvYTvYWymKrqFimgTRrAVHK0w sQMFwvgC9duL
2I13qHleovEy9aavsA/foB3fIY5Z2v8FB+mmI7iJLvyBbvyJHg/+MwQ5QYyX 8DKNMr7EK3iV
PNuLT/EaXifPRugZv4E3iV8OFW/hbQTp5rN027tEWwEpvIdzROllNOB9fEDU 3aTVh/jI4/5j
j/RP/gVQSwMEFAACAAgA8bQyN9ROONSmAwAAXAgAAD4AAABidWlsZGZpbGVz L2RlL2tuYXVm
L2VjbGlwc2UvamJvc3NkZXBsb3llci9VbmRlcGxveUFuZFdhaXQuamF2YZVW 32/iOBB+r9T/
YcpT6PWc9nGp0B1t6R53/SWgu3tarSoTpmBwbMt2Cqjq/35jJ0BoWWkvD0nw zHwz8/nzBMOz
OZ8gjJHNFS+eGWZSGIdsNtLOjdFIvUJ7fnhweCByo62HGX/hrPBCsgerDVov 0L23L1nOFcHm
qDy7vUCuBmhf0F5qpTDzQqvzn/vfj2bkc8dzfO+keC7UhBGKx6X/ibWnhBdc bp0OD0wxkiKD
THLn4FGVXXXU+CsX/vDgNbgApMfH4QHHGw/gEFkAbgzF81A3cDWGBcXBs7bg iixD51gVWD3+
NNzyHLiduHIlDY+qCOcJJwOhPORcqGTgLVX9/Ud0bwbH1xgEg5XzmDNdeGbI xUuVNN7VToW4
AGg9jhvN87IPAG9X5UuFBCCeIQn4TKKa+CkcteGsuTZuvChyavUCFC6gJyVO uOzYSRE2pbvM
0MT+k0Z3yTMvV6AVhqKjHfLCeRghOIOZeBY4hqMWNOA3qKUNFZZ53tYvZffU g320Etrw9wXx
fVWp7jGIbII+LpI9tvD99EeJs4ZI08/oqXLKHTUG2UZkra0PTL03rTRdiLko tc20ncSf6de4
5swfhiTY/ksvrnSPMPuYa4+duMNDfbuKOl4jbrUPhl4d1R5o2y4n226jA3Po K+sqqcTJene9
Ya9z83R5fzfsfhs+XXcuh/f9f0+gQcWxmTKMNh7tM6ca2F3UdxV6TXug7arx K1ke+zdPD/98
fnrod69737qDNXxkoTo1dOppG38J7qF//6V31e0/ES5BUZXEq9QZl1PtfOvs 9NOnmhgBdg8k
ZH5ZkbVrSGLGbQF7x8Z6j9uQ7LU3AzyTWs8LkzRm+TIV6kXP0ab9215nzA2R tlNcmu47ZyVs
KeAyI/O61GrSrIdvZxXo0Sw+y962BiojEu1inlaAExm2b+nwr4X+riK4nGI2 jwOmGsDjMII2
ar7QWlLvMNKytz4sY8pbrbPrzs2gW0Pc12EYH+HkhSRFNVUYYzUBLKZCIiQ7 SdioTPGFywKT
JrTbNGwK3DdKSgICKzs1VmyWu5JUnJGKxMapcVIjkObi63o6vJ1s0cMVvDbT 85WEGD5MkpOY
y9UGvNV5hQ98JRVhzd0qd2LC5PxfFOyQ8JH7pFHnOFzDqUU+Zk4imuTs9LRu ffs4MPfsZccY
EG6zjWH2HtUkVcXS9yubQrKd5LhsvvtM4LIEHXj6VzC0NHVqU8yiL6yC38/O d2DLe2U8jba3
kJlu/wFQSwMEFAACAAgADLUyN7pAKW3OBQAADQsAAEIAAABidWlsZGZpbGVz L2RlL2tuYXVm
L2VjbGlwc2UvamJvc3NkZXBsb3llci9VbmRlcGxveUlmUmVxdWlyZWQuY2xh c3OVVst7E1UU
/90m7UxDEDqlQKHFFCz0RYbybsrDFqgNpgUJLaTFxyS5TaedzAwzk5LiA99v RdGNCz93uoGF
fH6pWkU+P1f+F25c6taVemYmacGGh83X3HvPPefc8/idc/Lr39/fAtCLTwXU MPRmuTyrK4Up
mWc01bS5PJM2bDvLTc2Y55Y8pvvb+NQZfrGgWjwrIMiwdkaZU2RN0XPyqfQM zzgMdYdUXXWO
MAQ6OscZgseMLA8hgPowalHHsCah6ny0kE9z66yS1jiDlDAyijauWKp7LhOD zrRqM+xJ/G/D
+kk4r6g6w/qOycSygUnHUvVcf2e8Hg1oFCDdZX5y3nZ4Pox1aCLTjQJ50uQL q4Z8miQdkudK
vl/EBobWlc9GLil2hPzQeDaEZmwWsImhsYqGMFrQyiCYLkkjM5s6qlg5LuBR hq3LF3HSnFO0
AStXyHPdOVHMcNNRDV1AG8OG/yoYLKhallsitjF0nSgqGUebjxg6jyhl+Ui+ YDuRNI/YJs+o
Uyo50BaLhBBBu5uoVne3I4wOdFJKFdPkepahpSPembjHU/2uRHcYPdjJIDqG f8mwrmOlCPFu
QXsIu7BbQC/Drgck+eQgnY6XT2OOqoWxB3sZVuW4492NWRrD9mpxXEkSsJ+s 8sgFUkWpMUxu
OSq3Q9iHehF9DJvd66iu5EkgOkXRM6z5qItrVdFEEMJ2GFYuOqObRHS4RRzc jo567McMohSd
IV/IVXk4jCM4Stba3Ck/Ns9wsIq197ffrzAC4ABlopqBBUuLmrM5W8QxgoRn oRvGChuFlhIv
4gTDxjvFTcuYUymDrryIJ9zg6GZMljW3LKcN24n17urrExAvx6Uo+4Jy3A9I 2eMQhvGki50E
6S875wV4WLGnHbeqCdUiRqkuZ/JFWdXnjFnK7ZmR+EBWMckBV8HpMJ7CGYKc ZhizBfPBSS0H
RcBZ4vWtyyu6kuMuyOWRQa7oSW7NcYus1ImTKkYE9SXRp7qQD6DbxW7KRfsE w86HglEF9QIu
LIXljod9swgRXMQzDG1+ImyvycRselrN8MMj1KUqqA5hEu31UJARkGZoWH5v 0DA08iKMLKgv
1g4NJJKUwcbECg5CBtVbSK1UCrVo9e4e51kuYrZMjbrUqE9dhSSoNekwKPh+ bhhUPxT38KwK
XCdXZmbyofIXIs8vhmGBen447fszrmgF7s2RCREFmhyVpuuClv5EXKI8FspE EVRUDQOmGVHt
SIXIsyKepw5bJuuGE6lcRNpCeBFXBLxUadOePUt9NYyXvXFl+p1bycyetajM abhQCyUrG6s4
RqGzHctrRlK121oqNZNk1yeqtR9iCGScIk2XxH3KzHvEwy5DlfRURTzJCEZ6 xk3asvbqOWVY
nTa0+BKG6EySd56lldljqOHFpYF5dxzpMpQ0ClaGD6nuYN+wcnRGXTG0gfyH +1dDO/qtQN8C
nWRaGa21XQsQv/auQ/Rd5xEbsIq+wz4DratprccjWOML12yGSB+w9ptYK60v YWPXreAXaFnE
ltQiIilp6wIe67pVwvYSSH30p67A7m8hJxaxL7WAAyM90kEpVsKhcz3S49Kg vzkuDbmbRQyn
ehZwcnSnNFLCqdtIxoL0iKd1jLQ2B0s4V8J5UkzPLmIyJT29gGdjtTfxXKyu OdhcK00Ff0Qg
FehO0jqdCkgzye+g1SImNAu3oRBTXQnmZzjv2u6QEk9orrrQuYfS6Goqkqav 0ORuL3vbUKK7
hBdqrgeuU9BE1sxaqDD8IF+mOQ1sohBuoaDSLwJsRRTbsZ92R6ldDqOT+nU3 Jmjsc7q5QiP9
XZrNV7EXn9Po+5LWG8T9DQ7gB/ThF/TjNxzCnziMv2j9B0dYHc3GBppYLRhi rRhmbTjJtmHE
S+wFSiYlD6/gVTpF8Qdew+tk5X78jjfwJlk5gZ/xFt4m5HAs4B16PUj/1/Ae 3idAXMUH9OEE
lhsw8CGdBXqjDh/hYw9V1zw4ffIvUEsDBBQAAgAIAAu1Mjf42+Of3gMAADUK AABBAAAAYnVp
bGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95ZXIvVW5kZXBs b3lJZlJlcXVp
cmVkLmphdmG1Vltv4joQfkfiP0x5Ct0e0z4uFdqlLd2Ts70J6O4erVaVCQOY OnaO7bSgqv/9
TJyEkF5W7cMihINn/M03Vyfh0S2fI0yR3SqezhhGUiQW2XKirZ1iIvUazWGz 0WyIONHGwZLf
cZY6IdmV0QkaJ9A+la9YzBXBxqgcOz9CrkZo7tAca6UwckKrw9f1LydL0rng MT5VUjwWas4I
xeHKvSINlXCCy0qp2ejs7jYbsAvXKncIuAKeJFJEPOMCYgbCgbBQ+DvdI40p 3HPanWkDNo0i
tHaWSkgLCM/Ug55otKC0W5DxDKkG7CWQGLQbff/zmaduQcjftZzNOR38mgV/ I+80G0k6IRiI
JLd2QzycDfG/VBicNhsPpAi5Z/BnfIOcTbZ8TrjhMXAzt/lOJ1sKjtaRqQiE chBzoYKRMxSL
n7+8ejtT9FwBRmvrMGY6dSwhFSdV0HruGnGzEHEpcdpq+/xlZ51Z5w8FFmSe BZkFJlHN3QJ2
enDQLoUbLTq5MPoeFN5DSJhzLvtmnmY+DlYRJj5IQWuw4pGTa9AKM9peDnFq HUwQbIKRmAmi
ttOFFnyALbMZw9zOY/mQ+09hMddGQg/+OaJWOila6TrrnDk6v0ly78LP/V8V Trl2Ol/QEXuy
75sHok33dCsdWDiXdDude3Er8qZl2sz93853v2eTTwn1Vu9vfX+iQ8IcYqwd 9n3ex/p87Ru0
RKyamspWJ5b4Z6GrtoOKqVdgFl0hXQdF17HwIhyH/bOb48uL8eDH+Oa0fzy+ HP67By0ix5Yq
YZR+NDNOHNiFb9zi6CnlQZt16y1WrodnN1dfv9xcDQen4Y/BqIT3USjGAY0z SuWb4K6Gl9/C
k8HwhnAJilhSXKWmUlxo67oH+x8/bhUkQH3SQORWRbDqgsBbrAi8OA/LHPcg eFHezuCZ1Po2
TYLWMl51hLrTt2g6w/OwP+UJBa1G7qVey0HzEs7tMafzag3a24erEQx6svRr 7lklIBI+zNbb
6WZwIsLeOQ2AstRrfKhSQz8c67OIylttBg8rlY+0lhQEmGgZlp0zJQrFPjvt n40Gh3W2GdOa
cuFhHqeg8IPyKjZKrb0tp2hePZQ9+7hXjQ/wOpuZ9kCFkd2AkqY2y3db8Fhl 9ynloODcrvM7
3J5itTNskh/4xmWKQRt6PZp9Kb402X43T7Pap89W4fsclOJutftanMqs/CZK 7wsN/LkUwXuZ
vDdNLwe7n5dzGaniwnpyHaC0+KbkwQYwe2koIWHnOWix0BUfLSCo7jFctZ9c krjK0UeOXvTG
huZt8PymMehSo+Cvg8MafP5bCPe9jCT0/R9QSwMEFAACAAgAWLUyN+YP28FS BgAAgwsAAD0A
AABidWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9X YWl0Rm9yRGVw
bG95LmNsYXNzlVZJcBRVGP5eMkl3hkagwxYgMkEDSQgzgKwTFhNITGASlslC iIo9My+TTnq6
2+6ekLgggvuC+wIouCEXPMhhgqZAqiwPWhZHL148erRKDpZFqX93D4GYATRV mdfvvX/9/u//
u3/46+tLAFbhcwFFDPUpHhnSlWx/hCc11bR5ZDBh2HaKm5oxyq1Ij6I6LYa1 3dsLCDDMHFSG
lYim6OnIrsQgTzoMpZtUXXW2MBTX1HYzBLYZKR5EMcoklKCUYUZM1XlHNpPg VqeS0DiDHDOS
itatWKq7zx8GnAHVZgjH/k9MDaSXUVSdYW5NX+xGbHHHUvV0Q21bGWahXIA8 KfL4qO3wjITZ
mENRG1lKYo6vrBqR3aTpkD5XMg0i5jEsmuQxdFCxQ7ajWA5PhcPhICqwUMAC hvICBiQsQiWD
YLpHGkU5p6ZAkN0CFjMsuXHRpmk8rWiNVjqb4brTPJLkpqMauoAqhnn/NtCU VbUUt0Tcw1DX
PKIkHW00ZOg8pOT1Q5ms7YQSPGSbPKn2qzwVqoqGggih2i1Rpfu0TEINaqmY imlyPUVZ17TV
xm7hqsHVWC6hHisYRMfwLxlm10xVIdm7UR3ESqwWsIph5R3Ku6OJdtvzuy5H 1STchzUM09Lc
8e66LI1haSEcpx4JWEdRecdZMkWlMUxuOSq3g1iLMhEbGRa612FdyZBCuJ/Q M6zRsMtoVdFE
EMGWGVY6PKibdOhwiyS4He7wxLcZdDLitPhKrsnNErZgK0VrcyfvbJRhQ4Fo bx+/31vEv0aq
RKEAs5YWNofStohtRAkvQhfG62IELRVeRDPD/JvVTcsYVqmCrr6IB1xwdDMa iWhuQw4YthNd
tXLjRgFteVxGIr5ipM0HJJ9xEK3Y6XInRvbzyXkAtyr2gOP2M7FaRAe15WBm JKLqw8YQ1XZv
e1tjSjEpAdfAbgl7sJcopxnGUNa8c1HzoAjoJFk/uoyiK2nukjzS3sQVPc6t YW5RlDpJeh3T
PZHJTbK+JSoiF7GPocrHzvbGQtQmG2qSb26nuXKdiEF0oboMfXhIwIMMs24E 1WQYGjmW8DAO
MJS0NMbiBHp5bIoEFVOhAeAOE0os1G9YIZ/0NEVEJBmC6nXepwTwyQPLA0NE On8adk/D/uk0
xKFKGMQQQekjzaD6UN4i6QLk65uKc99/qkaQQKE5p8NgkBJ+qt2KluXe+2C/ iEcZFiQHeHKo
TU8aGVPjDvfTdIMi/tLMZ94YzUoYdqdliTctS+D/pYJ4DE8IeHwSIJ0DNF5T Ep7EIVKwNc6J
P4GaHbXd7sA/LOFpb7Rzi8biUUK92bIIb1XPQ+5NxaognsXzAp5jWFyYTROD V8IL3pvM9Ee7
khzqtGgOuIR4ScLLbuUDnXu7mkW8SuRoNM2QaudducM2iNdcR69ff0l4KUwY J12a1ARDeQHE
qaa2Y3kzTy50S2AZJunOjRWaciRQnHRGGCpjt+lmz4nXOAwFeFOwsUhHMBKD LptuWC9MNobp
CUNrmyA37Unz5r08lVZkPuOXgNozdofykHQRH5l4iU+Gly6DcSNrJXmL6n18 THqdh10NVIGA
8uhWRE/01UK/Au0itDJaS+rGIH7pXQfpt9Q7nIlp9Cv5ArROp7UMd2GGr1wk QaQ9cO08Zspz
c5hfdylwGovGcXfvOEK98pIx3Ft3KYelOZD58Dd1xasvIBIbx9reMaxvr5c3 yNEcNvXUy/fL
Tf7DdrnFfRhHa2/9GHZ0rJDbc9h1GfFoYBxdvXLPGHqjJeexP1rqOn2EnJ5F siJQUSInAhdR
3Fu8PE5rqrdY7o9/hYESRIUK4TL6oqUVpTloJ7DOEzYZ8257XCtWDs5sHLyA 0bOYFxXP4yn5
CBmuEHN45jxezKse//ukK/yK5zIYW57DsaJzxecIsS/wPX6kVhPxG36nTvAx PEKfEKCuF1FJ
mC3GMipCGNVYh6XYSrtW+h7Zgzrsxwpw+nowsRpZrKGOX4vDWI9j2ID3aD2F KM5gE3lpxDia
8S1ayFsrrmAnfkIMP6Mdv5DOr9hL3rtwFT34A/vwJ1l269fvRXMNb+BNWsP4 Dm/hbargOlzE
O3iXot2P4+TpfSIIJ6/HcQIBiuYoTuIDqnsWh/AhDhAnTqGJ/k9T7a9Axkf4 mHK7Suef4FOP
Rp95/DnzD1BLAwQUAAIACAAYtjI3mUSqwRkFAADsDAAAPAAAAGJ1aWxkZmls ZXMvZGUva25h
dWYvZWNsaXBzZS9qYm9zc2RlcGxveWVyL1dhaXRGb3JEZXBsb3kuamF2YZVW bU/jOBD+jsR/
GPIp5VgHPm5Rb69Ly153gaJS9kWrFXLTaevixJHjUCrEf7+xkzRJoeweQk1i j5+ZeebFk/Dw
ns8RpsjuY57NGIZSJCmy5USl6RQTqdaoT/f3RJQobWDJHzjLjJDsWqsEtRGY 0m5j/5FFPCbQ
CGPDLj8ij/uPISZGqPj0N4I3qB9Qn6k4xvA38sPJkmSueITbQjGPRDxnhGLw 0ezYHcTCCC4r
of294PBwfw8O4RsXBmZKQ+6+1QZqBhw+fyROgCeJFCG35jEn737+4ZlZ0Jlv Ss7mPJ7DF0vn
Zj/Y30uyCZ2DUHICsTrOle45Dft7T1Y/AFlwyUUMERLWlDmpFLKY+AYeW80g 0sIsnFrtYFUn
XPMIuJ6n0H/koZFrUDFCqCLiawpS0AftZtaTI4iy1MAEwSwQMi3JtQLHLpTY MBMSCwWBfRTW
p4YcD0EQJRFZ6t8YTWz+/OW0t6zgkzsEN+vUYMRUZlhCIkbGvtdwGlY8tXDa kCeMea3TnAMA
o9f5SwEFIGbgWwVMYjw3CzjowEmr3NxI0cmFViuIcQUDKXHOZbfwepOA4Ht1 ikpWNqSkCYZi
JoiAgzZ48BfU1FoLcz3P5UvuPrmhb4nJTp4hvaJqbm2ZzNG4Rdp3Lvw8/lXh lM8g+ITG8Z+6
AqDQlRXQrmRgYUzSDoKVuBd5fTKl5+4z+ObW0uRDQvXR+VetempAmCOMlMFu GGKajtXl2hVZ
iVhVMCT0mpL9lrpq2a8sdQIsRVPsrv2ictjgajAedC/uzoZX4/738d1592w8 HP04Ao+MY8s4
YRR91DNONrArV3zF0XOKg9Jr70+03I4u7q6/fLq7HvXPB9/7NyW8Y6Eoaepc FMo/grseDb8O
ev3RHeESFFlJvEoVcrlQqWmfHL9/X0tIgGa3gNA8FmQ1N3ynsXVqg3WuVQTL eCpYsiG0Ge88
1rUAj4e9YRsWVLMSATcpS/9FWrhyyRI4KM+82jRL6Q74r+63rP1MKnWfJb63 jB4DET+oe9TB
6HLQnfKEolJjMQheq+UcNK+RXB8zKi8Hv1WnrurToCZL98ypqzbICBfH1Olp WzgRYse2wrKW
GtH4qJQkv2Ci5KCstimhFuvsvHtx039RZLs6ki3gqtuXrSg/s1pQGwS/oYhN cjVfuczQb0Gn
AzMuU3ytIeU+WscbhhaE5bT7BS2Uh2Ij5B3VOKL2+lT2mOejCt3+WalNE36i VLYXtKQLiOWr
HjzXqYMXpPkFa62mlY0ztv/+Pw4aLNgcOltgeO947lW3KmqtdNquS26a/yso sJO40KIPYrrx
EokGKxWpJTKTMv+tArs7temG2I0GUzGFWNF4wIX0tuG2wQezNy2DqaLWW6Id wQqp9h/oYlZ0
N9IIwmlrQXVsMh2zJva22b7HXlgzXmjkU5ZKxMQ/OT5u7j/XP2iaCRdFt6iu yij/bL0RjyDY
jibNLjxO6S7j+YW2NbNUravhCB2t8d93QDQH1Qawg9+ynXdPsvtzd+TGl9rx I7uuMV8gu8ii
qr+miFFqWV+QsRhv4+Y9ID+6onAIO7YIKSEkfk05hr1I9dr9VNnBKroG8Ux5 8O5v8OxMhW04
G/W74/5dr399MfzRH3nwoQlchCPn6cbQ4D7WdKn627zs6orj0W1/Vwo8v5hs Sj6nYjZD7Ubg
zCSZsUS6QLO3+mp3O+re9tBTKCoyr0o6LPNtk2n4lssabXXAu5PTBmyxfOxW n20ro5//AFBL
AwQUAAIACAAltTI3j8ksSDsCAAAQEAAAFwAAAGJ1aWxkZmlsZXMvamJvc3Mz MjMueG1s7VZN
j9sgED0nv4JaOUUKtJV6adlIlVaVel2p6pnY411YAi7gZNMo/72DjfcjzWab L1Xtxidshjcz
7/EMvHJWQR6IEVO4yAqotF3AXQDjpTUZIQWUotahm6LqPQCdwwSnJsJDId1F RrNxv8cRqQIX
FgmqErUH2q7KyEzoGj++e5uxZ2Nrsxb9IQZjdBDuGp6W+FAHwvW4Eg4r9aGU GkMGy9QVnVt3
K801xTJXbLCc2qLWQCPQis6Fy8YEV/f4T1nFlR6TNA3dR8Z1MQNJT49Lk+u6 gFTMcMiGdNj0
FHHg7rfJmKWd5uwhTVM0w6qbwZvR6FvqnciSOPhRSwfFRzIape5mguRaeN9R QG+NqEsKuZYV
Mqcm1vuknaMd1tfyKiFl7epKhBtU69Ng6cHNwF1ZGy5xPg/WLVYMwcAE1oAJ rUftO8UqM6yC
kFJIbQ04Z5Gi4GpouEdWOOrTadZh06qeaOlvnqWedRzMRBz1kdwen9oZkF1F JMEm1TakTnmQ
Yu41QEU85NYUvknwaIvGwMR3iv8uZCCljRsrBkyRi30ViVBfrLtM2/ukYhxD Dc5ay+Fwm/1A
HWA/dVz7dREbTRjbesmFr9KI6mhGVGcjHmxEtc2IW2wYnbSvDeFsw79vQzia DeEENnxVHtwk
xbbzsLu0rl1IC9AQHqT7w1P4aSOl0B47IZy1aC8J15Wy9gfd0y2fTRGV+rdu K9u0ub+t7K6N
OoU2/5swam9huvNrd2HgLMyhvzQc9zlLZ8v4F1BLAwQKAAAAAAB5qzI3AAAA AAAAAAAAAAAA
CwAAAGJ1aWxkZmlsZXMvUEsBAhQACgAAAAAACZ8yNwAAAAAAAAAAAAAAAA4A AAAAAAAAAAAQ
AAAAAAAAAGJ1aWxkZmlsZXMvZGUvUEsBAhQACgAAAAAACZ8yNwAAAAAAAAAA AAAAABQAAAAA
AAAAAAAQAAAALAAAAGJ1aWxkZmlsZXMvZGUva25hdWYvUEsBAhQACgAAAAAA CZ8yNwAAAAAA
AAAAAAAAABwAAAAAAAAAAAAQAAAAXgAAAGJ1aWxkZmlsZXMvZGUva25hdWYv ZWNsaXBzZS9Q
SwECFAAKAAAAAABDtjI3AAAAAAAAAAAAAAAAKgAAAAAAAAAAABAAAACYAAAA YnVpbGRmaWxl
cy9kZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95ZXIvUEsBAhQAFAACAAgA c7MyN/0TLLy6
AQAAJQMAAEEAAAAAAAAAAAAgAAAA4AAAAGJ1aWxkZmlsZXMvZGUva25hdWYv ZWNsaXBzZS9q
Ym9zc2RlcGxveWVyL0pCb3NzRGVwbG95ZXJVdGlsLmNsYXNzUEsBAhQAFAAC AAgAcrMyN8vP
OIIaAQAAFAIAAEAAAAAAAAAAAQAgAAAA+QIAAGJ1aWxkZmlsZXMvZGUva25h dWYvZWNsaXBz
ZS9qYm9zc2RlcGxveWVyL0pCb3NzRGVwbG95ZXJVdGlsLmphdmFQSwECFAAU AAIACAAMtTI3
Tad97cMFAACOCgAAPwAAAAAAAAAAACAAAABxBAAAYnVpbGRmaWxlcy9kZS9r bmF1Zi9lY2xp
cHNlL2pib3NzZGVwbG95ZXIvVW5kZXBsb3lBbmRXYWl0LmNsYXNzUEsBAhQA FAACAAgA8bQy
N9ROONSmAwAAXAgAAD4AAAAAAAAAAQAgAAAAkQoAAGJ1aWxkZmlsZXMvZGUv a25hdWYvZWNs
aXBzZS9qYm9zc2RlcGxveWVyL1VuZGVwbG95QW5kV2FpdC5qYXZhUEsBAhQA FAACAAgADLUy
N7pAKW3OBQAADQsAAEIAAAAAAAAAAAAgAAAAkw4AAGJ1aWxkZmlsZXMvZGUv a25hdWYvZWNs
aXBzZS9qYm9zc2RlcGxveWVyL1VuZGVwbG95SWZSZXF1aXJlZC5jbGFzc1BL AQIUABQAAgAI
AAu1Mjf42+Of3gMAADUKAABBAAAAAAAAAAEAIAAAAMEUAABidWlsZGZpbGVz L2RlL2tuYXVm
L2VjbGlwc2UvamJvc3NkZXBsb3llci9VbmRlcGxveUlmUmVxdWlyZWQuamF2 YVBLAQIUABQA
AgAIAFi1MjfmD9vBUgYAAIMLAAA9AAAAAAAAAAAAIAAAAP4YAABidWlsZGZp bGVzL2RlL2tu
YXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9XYWl0Rm9yRGVwbG95LmNsYXNz UEsBAhQAFAAC
AAgAGLYyN5lEqsEZBQAA7AwAADwAAAAAAAAAAQAgAAAAqx8AAGJ1aWxkZmls ZXMvZGUva25h
dWYvZWNsaXBzZS9qYm9zc2RlcGxveWVyL1dhaXRGb3JEZXBsb3kuamF2YVBL AQIUABQAAgAI
ACW1MjePySxIOwIAABAQAAAXAAAAAAAAAAEAIAAAAB4lAABidWlsZGZpbGVz L2pib3NzMzIz
LnhtbFBLAQIUAAoAAAAAAHmrMjcAAAAAAAAAAAAAAAALAAAAAAAAAAAAEAAA AI4nAABidWls
ZGZpbGVzL1BLBQYAAAAADgAOAAgFAAC3JwAAAAA=
--------------020000060706050906030703--
Re: Modified JBoss plugin which waits for successful deploy [message #200386 is a reply to message #200009] |
Mon, 24 September 2007 14:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------090809070104000304080609
Hello again !
A bit more work, and in the new version this has changed:
-undeploy ant task first calls MainDeployer.undeploy, then the file is deleted.
-detection of failed deployments seems to work now for all scenarios.
-a wait timeout is implemented.
Still to be done:
-on server startup, wait until it comes up.
-host needs to be configured. Does anybody have an idea whether this information
is available in jboss323.xml ?
Best regards
Wolfgang
Wolfgang Knauf wrote:
> Hi everybody,
> plugin, so I tried to modify it to use JBoss specific logic to wait for
> successful deployment, no matter whether it takes 1 second or 2 minutes.
> files (buildfiles/jboss323.xml and some pieces of code).
> improvement suggestions.
> MainDeployer MBean:
> Known issues:
> 4.0, too. 5.0 Beta2 fails, probably because the MainDeployer is work in
> progress. It could even work with WTP 1.5 ;-). The code is compiled with
> JDK 1.5.
> Best regards
> Wolfgang Knauf
UEsDBAoAAAAAAJx0NzcAAAAAAAAAAAAAAAAOAAAAYnVpbGRmaWxlcy9kZS9Q SwMECgAAAAAA
nHQ3NwAAAAAAAAAAAAAAABQAAABidWlsZGZpbGVzL2RlL2tuYXVmL1BLAwQK AAAAAACcdDc3
vHw3NwAAAAAAAAAAAAAAACoAAABidWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlw c2UvamJvc3Nk
ZXBsb3llci9QSwMEFAACAAgArXs3N5t1xRBeCQAAhREAADsAAABidWlsZGZp bGVzL2RlL2tu
YXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9KQm9zc0RlcGxveS5jbGFzc41X a3gU1Rl+z+Qy
m80QwkLAVaATIJAL7AoK6kaoBBIMXQJlQ3wCgk52T5JJdmeWmVlI8FIr9kJr qa2iEqkItsW2
1EqqGy4GKG2x0Ku21ZZerbXVPu0PH5/+srfvzO7mQgJNfuyZc77L+c77XXPx PydPA1iMv8mQ
GKpjPNhtaKn2II/G9aTNg11tpm3HeDJu9nIruLaOdqvdnYx8htIubYcWjGtG R3B9WxePOgyF
t+qG7qxgyKusamHIX2XGuBd5KFJQgEKGyWHd4E2pRBu3mrW2OGfwhc2oFm/R LF3ss4f5Tqdu
MywMT9yiWpJKaLrBML1yS3jYsohj6UZHbVVjEaZgqgzfKLsjvbbDEwqmoYxs NlP0hLKMsG4G
N5CkQ/JcS9R6MINh5h2a7jSYVuZGdadmq7ajWQ6PBQIBL/y4Tsa1DFPHUaBg JmYxyElxFCcr
yyrHMbJFxocY5gwTGuNx3qHFV1odqQQ3nPqeKE86umnIKGeYcbmCupQej3HL g7kM4foeLerE
e1Vnp6lqWXk1kbIdtY2rdpJH9Xadx9TKTRvDC9WE1kPP0R3V0ROcYFB1Q7V5 1DRidlV5SPVC
RYVw4SzxtUBBJarI2VoyyY0Y4VLZWBW+gjG1QqJGwUIsYvA4ZobIMK1yrAjx zkaFF9djiYzF
DNdP3P3c2uTocQU34EaG4g7uuLRNVpxh/nhIj3f3Mtws4yaGKSPwNxzewS0F tyBE5ic1y+Z0
dgX3NXpwK4VXxiI6Udv1OFcXCARWCMw+zLBoQsbksPNgJYOyYGHOLSHVg1UM RTnfBARW9Qoa
sIbB264bsQi3dnCLYfm4SeAe9QQTmqF1cBEQwXV1XDMyQqtMw6AkpuiqldHI cN0Y5kyWN2kJ
7sFHGMpdbwRsN4dCNinRo3z5OkrCnE+8uB0VRWjCBhnrRwFbZ5pxulnBR7GR oaBhZThST5kT
HsNBGDQzzBKZ5yJqWmpGuxvPtm5EOYFCtaZ4CJRAoACZv5gXm3GnjC2jkr65 kzIypmArttHV
dpzzJBWPyrVVLR7cTTjquZiKyWgbXS5cHD2IZU8D4jSQOS1GOzplUGjPnxjK CnR0URbpxg6z
m4qeXhm+CuK1Y9050sMZxtotV4+uLJcMSgvFPTa4E6QK4EU3KjwwGSZR7gwD 7MH2LGeAOAPE
KYMK81zT6sjkYjA2xBscFms02k0PUpQxEUdzUnZILYKFnQp60Esvtt1DUfvH WOvBPVQlhRTP
CN2n4H58TPhJnBG44f9ztyvrVp2Pi5x78LKcy0Jw5ZwrwkP4pIxPMMybyE0K PiXMK2xY2Riu
Xy163R4Fn8Fn6YhvT2lx+7Jakbt/s0iLzynYK+I/v3njpnoPHiHAcqHnhYY9 wpZHFTwmbpAj
zSs3NtevFn3scQVPuB2LW1Tt91Pwj8gJgdpTCg7gS8SQEhWwJDzS17XC2TUe PMNQo3ZSD2vX
qEzF1HJ1VSePdqu2G6dq3MxkW4w7RLcDQu1hBc/iy6TQTrUN32iLvu7ekKIa HIxwp7YYX8Vz
Mo5QPI0iKPgavk6v1B1uaY5piW5dNUK2MXtOCo7ieRnfpCAZS1XwLbxAqBm8 x7m8k2Tx9aCf
rIqMNFO0MUs8/CV6AFGGfaqK2wYUHMcJwpkgaXIV0wyz2UteOqXgZUFR2jIl qUWLp6gCnma4
Jq7bFOxRM5GMc4fHe4cLx1kybNjyVSY1cjfri3EGzwkP7PHgeww3jHCcKPIx lcp84Oqe8OA8
w+IRghNzoAc/ILhHFs9UNMp5TEh6cRE/kvHD3PDiQjk0bSj4sTu8JTPzjBbt bra0qJjTaLAg
708dp+y4aW65DbiEpET9bs40MQbWKKjZTlU50aZErjHbukQtpH5w1VJJUddm xhuHyjh1TNo3
uCjR7ZupemdNEv3d2uFm6SRSPlLENzao6CmxUTWOoSI8gVIowDCzE/KU0Roo DskpUQqP4TAa
tmF6eLwQInXThLFDAhvIIwQDxeNo5cMchB1VgmaeoE4n8Z6hKXe0n0mxN2Km rChv0MUYXjpi
wAoIfpSD0sJtrRJ90UhPvzLtgrQyWguqB+A55pK99FvoHk5FMf0qGQZaJ9Fa hBJMzgjnvw8P
Sknkn/0o9U1P45rq0wUHMfMUZreegtrqmzOAedWn05ifBqkPnKnOW3IcwXB1 Pi1Ll5OQy1VL
XDVpLPfdRj8zidtXRx8kIhQex+qmU7i91bd2AOFQfj/WhQrylhXmLZOPSDeX yU+jukwu9Sb7
MCenLkLqxFlcaNo0pOkhmU3DHcfRusif77srfxB5rXk1EVq11jxfNHICvAAh j99zFk2hglPo
bq0ZQCJUJLiNDLe/KMeezLCfhRXy+r3n2Yzc3Q7d7fe+iB1D1+You7KUe9N4 IENxd/3Yncan
96OkHw+HCvKXFR7BRVfBeZxzV9/n0/jCfrzk0rMiXySRPlT2Y5+r+sms6r40 nhYwHhy6nPQJ
wqFQsb/4BL7CEJp0BHf7J53AN+hb8SviBSU5E48JPSVpfHtI3l8y3n0vunxX uo+Upxn6/nvA
X5DGyT486ve+gr0CxkHGsrCdEQadR4+w6jsZq9out2rIBZPdu/yT0zi3H7VZ kzKoLRoFwbgm
5XAdsqsva5fixsjMQ/8ezHw8I3xQ6vsuyRxBRVmh65N9vu+7+zJBesX99IYp Vi9IR/OOUhJ4
pHelv1MFdpOGzcYaShCVkmIeJcl8+LAAc2ldgCoEUI2lqEErfW2j2V/HEhh0 sp3+eXHon5Sd
WEEjw23UpeuoA6+mttaAE6TvHK0X0IifUTu7hPV4BxvwHq0f4E7Kym3sWtzF boTG6tDO1qCT
raPJtI2mxA4kWQoWe5imvsdofQIO66MZ7hB2sTTuZYO4j72BB9jbNGf9C7ul fDwo0ewkebFL
moZHpHLsk5bgcekmPCmF0SdF8JS0FQekLhyUenBI6sNh6SCelQ4T/ShukQZx VDqP56VX8YL0
OvqlN5EmZE5K/8DL0nsYlN6n7imKyVkqKlQw8BP8lHYB6TS9rJeQXCoN4FW8 Rkhuk/bi5/gF
VStd2o1f4nXkw5DuxxvYSEVou3QPfoVfU4FyyI5LJCHjAnsLv8FvCfdL7DUx PlGR+oAdw+/w
e3jpxbaYfVBM727GH4hPodevwx+JWkJv3IU38ScU0ytb8Jag0lvX488udSvq 8Tbpm0zvKMRf
8Fe3Wr7jlsl3/wdQSwMEFAACAAgAp3s3N0d1wVqVCAAADB0AADoAAABidWls ZGZpbGVzL2Rl
L2tuYXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9KQm9zc0RlcGxveS5qYXZh pVltb9s4Ev4e
IP9hIuB27dZR0vvoXO6aNO4ivW5TxMkFh8XiQMu0rYYStaQUJwjy32+GpCxS kvOyG7SxLA7n
fZ4ZMgVLbtmSw5zHtzmrFjFPRFpoHv+YSa3nvBDygauj3Z3dnTQrpCrhB7tj cc7L+Pry61H4
tipTEX+SQvCkTGXetzrlZZvZfZyxHHXIeF7Gv55ylk+5uuPqk8zzPkYB/cXs B9J8Yxn32Uq1
tAbE1gJDerZ5PM8X8ui1xNOSlZb5wbt3uzvwDm5YWsJCKmjoQS6AwZdT5AKs KESaMFI8NvTm
10dWlSvccyPFYsnyJfyb3L1ZP9jdKaoZ7oNEMGRiWFkldnceSTqAlQ+441eW 5pBxZDiPjToa
qhzdCywn8ZBqpxufx26L+/hYMMUyYGqp3ZvNzyeZoWPnINKcx7BIlS6JriL7 xlCuOFRKkKH0
WLNHOoHUmicyn7c5NrvX5LIyzbisrOt0lSRc60UlHCun5wF9OE9o9Dx+pOje DA0eTEuV5svf
fjfaD4nw0WyCg4Ori7OLMZxNTq9/2f9OFvKSK7s4fdAlz2IUHBe4vxT5ICKX fZbK+heV0yRL
leitOI6GR9bdAKV6sA9ODkC6gAFJjwXPl+UK9o7h78N6cUOFO1dKriHnazjH algyceJcMblP
eEGpMWiI6Sea3LOkFA9QruXGb5BVGIMZB13wJF2k6O4BVt0I3XEfuhTTwYZA D/fGEMF78LQk
g6yUp/rBuhKtVtcY02M/3bi6pkJd8tK8xHVj8W+Hvzd8KCT4n9x45TQ4hvO8 5EuuYswwzfGL
3fbB29YXCiuUlKFMgp9Jd6fWe4h+HtUmWqtaQpGittuPG2UE/MJLk6nagAkk GzQZ10S9WFPT
9/lkkeZzS29s8wU2OARy9sN8Hpv4NwuDyKKMNl4Yk5w04cdUy7WUwIZTKQUq CDMpzms95sjV
vY8/n3ydTkKbz9I5NMgFC4aQ8K96fdbw+4wLhteCCc37wkrBVHe4ikSHR56I Dfh1KtiItDDk
vUAoQreleoXypPIYsU3yrrD+uGDYdRxa4c96RdkwCGyPnQX/YaLigyEcO/3h p59g0NH7AD4c
DuEfrZTpK1ZUxqQjqoQRI/gDzpKVy6wRaImJxEpYc0jQf7qUhcmsQsmlQhfA XsDrm4Rvjk2G
2mqIcixpTK470xMIQZGvRlMiILxF9uhS5JxLKvaAF8kqPLdYBOrY+k847HfC 34wT0FGHw4bF
ow892+DRVCSG2UsnneYJN2W4zdt+PTokreU8NY/v37e3HwVGTwXnBQZjlpae 4Vcrxdk81rQ4
+HB46JdKXX9Ue0Gt2GKO0/xO3vKBq8wRROmGKBp5ZYq95bFGn6dRiNBEtelA jxCZmUZgJ4/t
2wieQpXadTtwhTsMtQz2kPWdgMAgCnhZKAxeDdtcCP3CgWfcrGMPMb3cIhR+ G1ib/XiFm72K
Nl/RmpBguNXV2Ega0q63q9e62o2czs2eqd8FTUOTL6fwhSnTRTSsU2zOXCmp 6FkIZGmaAKsQ
LvzoQykDZoqXlcohKlXFo1FYi9IgwIont6b8vcpIyb9UxfQ+oomx0hElElVR qgM2kZd5SJ4H
i6TlQ7my2wg4eRys3/AaKKweRhYqirhhbcO9GiRCj7EaRwd0TTS9Orm8+t/Z 5PvXi/9OLqOA
I66bPQnD3SGQBX4iLJicXDr/ZulyVW6cdXV5PYlgVpX+aKjahpPWdSuIYSrb hueBLiNyZ8Zu
UZjmOVkmPd9r4+KWvtvHi00NmMoJc9nPJgLXVqbjhJdXQrwFPm38+2TFVm9f 5HYWfCsHHpZ7
n96WLuZ/VAivg9ZpBkeH86+Ts+HQ5/EY1iD6000JXp4PNOeZplCs8JiBETN1 drNJC/MVEYCJ
dN5hx+NlDGYE2l/zWXyfiWGH5kwil28XVwF/x5BKfP/LyeW+lbUXbt42JVFu trwFwQhElR7E
48n/wmm+2OJeSkCbHdR8ewnqADRFb7oxyXzO+W8yBt32yRQGlajDvLqSmtiN O5vsmenGoCOW
5loqy4KQ9AfO8G0Pkxf23pJlBnbaadaxdVMAqHpf3fYVATaNuJS2RQyGbX5m xsBtNFcubJj3
nIvccC/k0h3gS1zX4aTyihQxSfJMFJzUaTVr7Oj48+O0KgqaH2+YytEQzJIq NxBHaRLSTrGd
65DbcSfjgvWWvqTVoBmS6GPc4vhSmJ6dCNDUvqHAijraEvEQ8nxl+qAPCbyg Dzt10IrBhCph
3CbpSWLi+2fyuMdF/bmMAubPpTMp8HJG/6mc7jJ6Ia9b8Nf6+hTM880Xvw2f LyzSR/49GIJ9
RKCEx6d6iKABxyG7HYRouvJmNZwbfbaslX80QYzcREBm49lEZoXgpT+Y6WCk CEapyGw93+zy
NkUwpzZEoMiEkGvqd8wcds2gpzJ7jmMzzF+fZcFUmTLhMHjkBkY7leFYKFJd NvLEQzNb2Zu8
+mrNvxBoHfxefRxuj+vPDzEHB30FabKrPgb2urcFm/7z68GtuS/GY7EQ7YjY o1NDtP2gsdW/
I2O8/R1qTD7dIrQ793XqvYWpDZPv7lJ9vMWiv4S0DbstgNvRo1Pi7vx3xbOi OQNCzyFw23TZ
iDDA5XCz5vkqoOzLOTzodpS3naDPrK6iL6j6mpEYerD3sQ+O3zy0tHzWgP1f n1VeMTL2bni+
EXRaAb7AsE3yOZ4MqXAqpcjUVrbS+bNSlFHDCFq9pN6O9kQgyToPVwobVh0H HceX2EMMTHFg
d2gImwk+jHob1JN37ThPFwtu9MbEK/DIirhjABvoX15fSsb+jf+26y6E1Zdv F58/lRp5c9Il
fnXYN+ZsDideLFuHi64i2zL2zdkXqPF2w839MZ+TyJCpfXTccX5IVjDY/NkE +P2w9TcZfm/5
Yx0nt1eKJdgMN/zcFcX+h6OArXttb7aNTPz1f1BLAwQUAAIACACDezc3G3Ac g3oBAADCAgAA
RgAAAGJ1aWxkZmlsZXMvZGUva25hdWYvZWNsaXBzZS9qYm9zc2RlcGxveWVy L0pCb3NzRGVw
bG95ZXJFeGNlcHRpb24uY2xhc3OdUclKA0EQfRVjRuK+JO7bTaM4eBAPigc3 iIxe1Nw7SRlb
x54wPXH5LE+CBz/AjxKrJ0FBA4INvbyaqlfv1bx/vL4B2MS8hwxhq87+rVGt K59roW5a9m+q
kbV1bobRE8f+yb6gww46eqxxM9GR8ZAljN+oe+WHyjT8rw+EEcuxVmGFYyv4 snxIoBPC4EFk
bKJMUlFhi3vRXkTI7Wqjkz1CYSX4JjxPYm0aO6sVQvYgqnMePRgaQB79hOFA Gz5r3VU5vlDV
kAljQVSTlkoaC+4Es8m1toTt4F8Odwh99pStVY20wS9phFIXwUGXmYgLJ3/S yZ/6s+ziOo4e
nIPUvMePZWM4lvF0pSbkz6NWXONj7TzPdjez4UqxDBIZMnTMoBc5uT1BGfTJ JjdaOQcksic4
I3eutPaCwec0Z1jOfBotSG0RI/IqtrMwirH0Z+YwjgnhcFyFDldZOrqeXmlt /QXFn2QLUrSY
ki21077IvA6Ze02LYCdxNq2e+wRQSwMEFAACAAgAqXU2Nwf+GoYaAQAAhwIA AEUAAABidWls
ZGZpbGVzL2RlL2tuYXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9KQm9zc0Rl cGxveWVyRXhj
ZXB0aW9uLmphdmG1UTtPwzAQ3iPlP3xjiapUzBFSBWUojwkB8zW5JG5dx7Id KEL8d+wkuGUA
sSD5bMl338vWVO6oYVSc7xT1dc6lFNpyvt101lasZffGpkiTNFlk2fWhZO1E p1B3Bq5l3Fz6
MXzN5WmCDMO2pN61fui5k3VDqsFtoA+tUIs00f1GihKlJE8w0KwmlqMKHxyr yiLepMm7h8Nb
CceohYEO0Ea8kGNYR84T10KRhOy8tGUjSD6xsZ7icb3CBc7vioCZyK4MB2QI xFH8VbgW2946
EPZsrX+m/JsqlpoM7WHvx+6plzHcD7FmD86I4GsCngXIEAywvWaDWWwVg9jH n8xGnyBV+YJQ
ypPx8fX+w/0cpx+2DpK/BJrHmZjMr09QSwMEFAACAAgAg3s3N2utQM1wBAAA zQgAAEEAAABi
dWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9KQm9z c0RlcGxveWVy
VXRpbC5jbGFzc5VVXVfbRhC9CwYrxoTUISSEjzilBIODBTRJwYQkYAyB2oLy YQo0pcJeGxkh
6UgyhYee/I7+grymL+acck7b5/6ons5KrkuKQ8OLpJ29M3Pnzuzqz79+/Q3A OMpBNDGMFbh8
aKiVoszzumY5XC7vm45T4JZunnJbXp6j1XxttelqehABhltl9ViVddUoySv7 ZZ53GfqXlfkl
ZTab3svOpWeV9fRaLr2WWlGUdGpjaUVhiGT+dVp3bc0oTTO0p0zDcVXDzal6 hUu4wdBVPjqR
NePYPKT0a9ml2YJquabN0PpcMzT3BUNzbDjHEEiZBR5CM26GEUIbQ0dGM7hS Odrn9oa6r3OR
0syrek61NbGuGQPugeYwTGSuWznRbStx17Nv2jrDo9jlkoYvmyR0MTA5hHu4 H0T3B+r5kDB6
0MsQIiVs19nS3AOGO42C7wTRz3D3vxtzFU0vcFtClKGlqOk8GUIfPhe6DHwk Uk4gBsN4hCFS
VrUsbhQYRj+polq6aRFiOIwRxBkk1/Q3GTpjDUUYpTweN5nQe45rL2iiHaGi ZhTWuX3MqcUz
sd2PETiRj1RDLfEjbrhydo6rhu9EA2TQAGqmQf0JpU/y3BILJ4gvGZ5ep8d1 3yCeUhUejwr1
XV61TYvbrsadEJ7gpoRJhh6xnTDUI2KYKKp5mtDThJhPTdUlJBmGTLuUKBsW GV1uE4I7CcWD
E2OXn7gLvpMI+TyMGdBgtzncrSU7ZZhs0Iyr2+OfRdL6FUNvI4IVW09YhyVH whyNkcdQ6PEP
jDQidSXMM9y76G7Z5rFGHRf+EhaEOIaVlGVdHK8D03GT42NTU0G8rulyIvuO 8pIvSK3iEBax
LIbya4pfK84T+LXqHLjidNJcSsgyDKRsropWRM1i9MMg0aJKc1NIRkNYwTdB rNZKref0Ra43
M4w1MZ8hOrlZ7jg0QSFMYEPQ2GQYuVrjehTvwCxiK4xvsU2DrJvmYcX6/yug 1pEgdgn7aWMs
4Q3DbMZLIMpvCIoONb4lh+ry0EWn2iW66G7vNrp4W6inFu12ZRrNOQGa8+4J Q1/min4SqokT
qD9zVQMI1erUznfsGkd53azYee5fEl2XLuOECISHIKL0N2O4jxa00jtIqyZI ZGXir0DPMFlk
ejN6t4ycof0XD9JBz1bP2IFb9Az7AHyGCL1v4DY6a85vvGBAfCRyp4q7P6Pz HH3bkQdneDhS
xRdVxN57hscXDPUUNz1+fRTwAXEcuJAqjgQREKlkjBF6nL4DtDMhkrIeotJC lrfneLJ9hmeZ
eOSryFQV01vxyMvIrP+RiqTFB8ueY3E7foal7DtElXNMbHuEMkRotArF5zR6 hvXfmfI4IlWR
+wM7yjsMJAN18HcE7g7U0d0BAR99T8QGieg4HbZV7JAWK7XCnqGdnpMk9RRp lqTipqm8GUK/
InSKykhDwTJ5ZclrFXt0Dn/CpifAC6/wt/ierKAIP+IHqFT6IGXYR54yTKAX BXASb5XkKaJE
X3vo92xCpANPYO1vUEsDBBQAAgAIAOp8Njf6ARtQOQQAAAMLAABAAAAAYnVp bGRmaWxlcy9k
ZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95ZXIvSkJvc3NEZXBsb3llclV0 aWwuamF2Ya1W
bW8aORD+jsR/mOyXLmm1234slF4JIb1tA0RAmp6qCrmLASdee+X1BtCp//3G L0uAC8mdFAlY
sMfPzDzzjIecpHdkQWFGoztBynlEU87ygka3v2RRzGjO5YaqVr1Wr7Esl0rD LbknUakZj66U
zKnSjBaH++soIwJhMyp01D+jRIypuqeqK4WgqWZStA7sBcmYWERooOlaH9lN BNOM8KeNBvbR
W6c0947qtfj09BojhpSTooC5VKCXFGyKUOVYr8Ep2I9PpNRLtLmRfL4gYgFf DTNmy7zjei0v
f3GWerQvZ4hy7kGMl3rtb7QD9PllcJ4AhkVBzq3HR6mIjLXFBcgVuyeaQqGJ Rg9zJgiHsVaY
ERi0Qaffm/bPep3BuDf61ht1h4NBrztJhgNoQ3CbrWMm7uUdVfGon3RmJNdS Ba2WgfYxdRU1
Dkw0NnK4Hl1uGSlymrI5ozP0zGkELrLq8SknimQwLbS6wO1qVVFdKgEdi4SB oyIw2hXTSwgM
TDMOdjN03PkEfWoLqm0w14qHfqny0jCHLKEYftyZzbagSBads7WjD9gcwupM ZKMobjCEMIiD
BrTboFXpsLZoAD5yBxjA663TlrP47R6UF/Spk/Gxo793eXf1Bi0d01YEQISh Gj+OqqM60CdM
VCoDJqwaov36jCmFDwSWSEs7WGqdN+N4xe6Y6+VIqoX9Gd/YtSL/I8cWbf8p V+cy+Uz1iGZS
006a0qKYyP7GhhN8fCGgDzH5uK8johYFdGWWGRI4E9SuRAeymvwfYqqzeqnk 6qA1tzcCdMQG
qFJSFSDTtLRyWy2xdpB6dLxGjkr28WBMEd0ieAX/+GnzacCTweyq+9Ro2HLA qVhg+5y04d2h
Zi0aCLqChHO6ILyjFqW5Zx/yC4PemqSab0A6Uu0+ZGWh4dduk580wUh3x2Vj X/m+F1Ha2Jl4
w/zrrot2O9fg/Hj7s9HyvDntm7ZFUeyqPt3y1qws4IVk5vAeJhNeEjIvMHTD 2MNyWCVqt6OC
ar+3Cf10iZJBMkk6l1O8Yie975PpRac7GY7+egMBBhbdijxiaKjmBP37oeOP XiD5Um2C533g
jTm9+vp5ejXqXSTfe+MK3Obv5xnOY6zefwC7Gg2/Jee90RRREQgjRD65TAlf ykI33719/96i
OJz9WQqpXhuSSs69H602e8rzBkZ3eydDGxDWHGt4oWQGt2LGonzL9K4QvKpS otMlhAeDGuj6
uNaPdHIY2HFmvuKEPUhpTrClZ07idG2U2keloITCxhtcgAOt72rV6XQrzsnw fNiEJd5TeEfQ
rXd8eUHbeVPmcOJOPH5FeNsnWYYHq/BRlIYpRMSlvCvz8Ol/BFV+JoPxptA0 i2SpsTSoWy7C
wEE7fpzXSEvX8WHjgJwXK1kYXNrYTb0ep+mVieeZ/zqvIXj1XH13MnBf/EBx qbb8fMbdfwBQ
SwMEFAACAAgAg3s3N18+GJZ8BAAAkggAAD0AAABidWlsZGZpbGVzL2RlL2tu YXVmL2VjbGlw
c2UvamJvc3NkZXBsb3llci9KQm9zc1VuZGVwbG95LmNsYXNzlVbdUxtVFP9d knSXsLVtKG0R
qAsVCAESWqzaBNoSCpYaaDV8mKLVTfYSFja7cXeD8B/44oxvjjM6Pjm+8GIf oMpIfXOGPjhO
/x/Hs7sJFBMZ3J3Zc8+553fu+bonOfj7130A12EJaGIYUnli3VAqKwle0LWy zRNredO2VV7W
zS1uJR6kiVswfF5AkOH8mrKhJHTFKCYe5td4wWE4M6YZmnObIRAdWGQITpoq DyOAZgkhnGE4
l9EMPlcp5bk1r+R1zhDJmAVFX1QszeWrwqCzqtkM8cz/8SlFuJKiGQyXosuZ I9+yjqUZxdTA
TDMuoFVA5Jjn2S3b4SUJF9FGXpsVCqLNB2tm4hEhHcJzpZQScZmho3bYhKEu KZojf6HYsu0o
lsPVMNrRIeB1htYGeAmd6GIQyq5IJyfbog18XBTwBkPP0caMrvOiok9YxUqJ G87UZoGXHc00
BHQzXP63gXRF01VuibjGEJvaVAqOviWbBpeVKl4uVWxHznPZLvOCtqJxVe5O ymHI6HUr1OWu
+iVEMUC1VMplbqgMndGZgcx/HJVyEYMShjDMIDqmv8lwMVoPId2r6A1jBDcE XGcYOU1171W5
BUfTJYziLYaWInf8yls6Q1+jPDY6ewRvS3gH7zKEVzRDzXJrg1sM4w2bxRNt JkqKoRS5m7nE
bJorhg+aNA2D2p3KkBKQpK6oU/bvw5xS4iLGGLq9wOK212tJm4xoBT4+S81a Cy+MW+htxh1M
CLjLcOHIo7Rp6nSyhDQmGULTE5nsFLVYpk6DOpQ2wlotZaqA9463uhebiJmq NO5K4760Be9j
VkCG8nm6yCXM4SE1iWZsmOt0ZbVo5oQspOpT/GrWfcXU8smVrGqFKUsfSPgQ WQYp78e+qOgV
7k2dxyIWaM7U7inZiNMjYonas1IVishRiifKZVmz5ZqQqyKWGa5VxYbpyLWN IZdbJVOyY8qq
SdY+ocFVh4+H8SkUAZ/VJoDn9eGVlZD3RmDZHwpKYX3eUgrutKPbSdOutUH4 lGDbsbw+jzTe
rXZx9LQNSyPIzK+5NWHoOrFkDGfzpj5z2E7EE/JVPlJfHIYmvnk4Qo8ngDbD WbNiFfi05o3+
Y+M77iLQDaoi3KeJVvSbQV+BuARRRjQU24X4s7cdpu8ZT9hCLyD5CkTPEm3G azjng9n3EEkT
ePkU5yOXdnAlth/8AZ17uJrbg5yL9Ozizdj+Dvp2QObjz2OBG8+QyMSe4ebs Hm7lIqldjM89
xe1kcGg4ci/4GwK5wGCW6HQuELmf/QUPQkiG2kO/404y2B7cwaNvMeseNk+H EWSxMWTpJGsu
/COC/4QWd/mYli792BOFM4M7eNK0HdimEEX8gQNqPT8leVyhbxtJ2ykFHehH F+I0pEfRg3H0
0hjpo6vbjyWiT2jScwyghEFUMIyvSfM7yvWPRLfpn8EubuI5zcwDJPECY/iT LPyFu16673t1
eYkCVKIujmOFvBnFNyhilbwZx1fQsEb1TONLrGMSQTpRp7dEZXpBJTFgenUt ewX9/B9QSwME
FAACAAgA3IE2N1CTFgzFAgAAfAcAADwAAABidWlsZGZpbGVzL2RlL2tuYXVm L2VjbGlwc2Uv
amJvc3NkZXBsb3llci9KQm9zc1VuZGVwbG95LmphdmG1VU1vGjEQvSPxHyZ7 WlJqkisIKSRN
q/TzQNMcohyMd1gMXntlewMI5b/X9n5BRKKkUpFYL57xmzczb0xO2YqmCAmS laTFnCATPDdI
ljNlTIK5UFvUo26n2+FZrrSFJX2kG5JR6Y5lKC35cYlUTlE/or5SUiKzXMnR y/6/Zkvn85Nm
GGAHp6e3sgwEFEJYoHkuOKMeCKhMYE25hbnSYArG0BjS7cAphMcFLezCWe6U mKdUpvDNp+FN
/jvodvJi5rCACeqAv146+Dpct7PzBAAcBb84tH9iAiUXv1zkVNMMqE5NuTPw S0XBWIfDgEsL
GeUynlrNZXr/ENx73nEXDsF0ayxmRBWW5M7FChlHNbOJTO48hzU1HlBbTKLe qMwDwOpt+VIh
AfA5xB6fCJSpXcDJGM57tbHxcicXWq1B4hpuhMCUiolOC9+v6w3D3OcfR9cb yqzYgpLoOQcz
ZIWxMEMwOTI+55jAyRAi+AB7UT3BMsxT/VIm71LQt1rAuOzMp0pvt5YLkqIt 26VFyOD+7KFN
1DVt8AWto+0iB+0Ba8Q3rH2OSrP2PxZzzmVS+oeQLe96bcULarYM6zhUrTXE UZAOMaGLQx+N
Mxz/cC2vY0WHicDVAtkqyKqauMQLr0njUinhEoGZEjc138TFrfbJ58n36fXo kKKnd+BcZk24
fFQrjCvyfYh44xT19zJxstzV3XnqtzqB4NNIdweRH3Ai3OiRcjeCp7ZuzynH FefeIb/RvlwP
zpBZeeAPFQXGPRiPncgLPCbh18bG8SLuE7XMQuFr87DdfalOReX6SpXeVxr4 fy2C9zIZDN7b
qOPlnuQ5cAN1raq76dnoozD4xvZVeFLZZjL6/tfC3x1WQaLIsQhvokb2prA6 6S56toC4ufIA
N71n9yluSsipdf+cvzVlTpQNAY220BI+no8a2PKlMpyF/bDrHn8BUEsDBBQA AgAIANR1Nzd+
Bj9LcQIAAGQSAAAXAAAAYnVpbGRmaWxlcy9qYm9zczMyMy54bWztV8ty2jAU XZuvUD2smLHc
dqabxmHRyaZdZibTtbCvEzmy5UoyhDL8e69sOQSHZ4CWtrCy0X2ec48kR6WS GcSGFCyHaz+B
UsgpPBkoNJeFT0gCKauEaZdo9hGATmCESyOmIeHq2qf+sOdFGKkEZaYuVMkq DbTx8smYiQr/
/PDeD9faVkXH+pM1fm3tKjE8B1mZbmy0N0zdw3JLi7rRxIsyprAzbVIu0KQ/ cyjQiVSPvLin
2NY87M9ymVQCqA00pxOm/CFBby/6yUvrqTFJDcCzpfWzGYj7eREvYlEl4IoZ DMIBHdR12jjw
9GrRZmmWo3CRpi46xKrrh3dBcOewIjwlCn5UXEHymQSB627MSCyY1i0E9LFg VUohFrxEpLOR
1Npxrei3L/h29wx+7Vgy84DEXvVnGtQY1K2U5gaTxEaq6TzEOFCYsI7DhAia d4oF+lgAISnj
QhaglER0jKqghh0BiZCalrA2Ni2rkeD6YS3qYdv+mNmnHuLqRbkcA9mXP2Kk I2xFapcH0Y20
ACiJhlgWia4TvJhma+igdvbfGTcklXamrEGOWBxExs1RqFjnIfioMQ/0VBvI d6DtAN68Zddl
8c473EZho90tOobsAB1nx9Vxa7FSzbatbXL+3xSdHU3R2UXRv1HR2aGK3qBn K8m36hn+Qj3b
idxzjNp4X9NbF+3chA0dYZ/D5vVHFQNH2+ngBDvdZZvbTNpe25y38e7Sftl0 vkISEGAWg7Dj
rWq52ZQJjd2SKGyibRuDtpTOkXfGF4xjfDOsPYWWmXlxr/yH4Fh14XrT9GWn mb5dyVlcEi7n
yWFEwomJxOdeFLqDbfgLUEsDBAoAAAAAAJx0NzcAAAAAAAAAAAAAAAALAAAA YnVpbGRmaWxl
cy9QSwECFAAKAAAAAACcdDc3AAAAAAAAAAAAAAAADgAAAAAAAAAAABAAAAAA AAAAYnVpbGRm
aWxlcy9kZS9QSwECFAAKAAAAAACcdDc3AAAAAAAAAAAAAAAAFAAAAAAAAAAA ABAAAAAsAAAA
YnVpbGRmaWxlcy9kZS9rbmF1Zi9QSwECFAAKAAAAAACcdDc3AAAAAAAAAAAA AAAAHAAAAAAA
AAAAABAAAABeAAAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL1BLAQIU AAoAAAAAALx8
NzcAAAAAAAAAAAAAAAAqAAAAAAAAAAAAEAAAAJgAAABidWlsZGZpbGVzL2Rl L2tuYXVmL2Vj
bGlwc2UvamJvc3NkZXBsb3llci9QSwECFAAUAAIACACtezc3m3XFEF4JAACF EQAAOwAAAAAA
AAAAACAAAADgAAAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL2pib3Nz ZGVwbG95ZXIv
SkJvc3NEZXBsb3kuY2xhc3NQSwECFAAUAAIACACnezc3R3XBWpUIAAAMHQAA OgAAAAAAAAAB
ACAAAACXCgAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVw bG95ZXIvSkJv
c3NEZXBsb3kuamF2YVBLAQIUABQAAgAIAIN7NzcbcByDegEAAMICAABGAAAA AAAAAAAAIAAA
AIQTAABidWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlwc2UvamJvc3NkZXBsb3ll ci9KQm9zc0Rl
cGxveWVyRXhjZXB0aW9uLmNsYXNzUEsBAhQAFAACAAgAqXU2Nwf+GoYaAQAA hwIAAEUAAAAA
AAAAAQAgAAAAYhUAAGJ1aWxkZmlsZXMvZGUva25hdWYvZWNsaXBzZS9qYm9z c2RlcGxveWVy
L0pCb3NzRGVwbG95ZXJFeGNlcHRpb24uamF2YVBLAQIUABQAAgAIAIN7Nzdr rUDNcAQAAM0I
AABBAAAAAAAAAAAAIAAAAN8WAABidWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlw c2UvamJvc3Nk
ZXBsb3llci9KQm9zc0RlcGxveWVyVXRpbC5jbGFzc1BLAQIUABQAAgAIAOp8 Njf6ARtQOQQA
AAMLAABAAAAAAAAAAAEAIAAAAK4bAABidWlsZGZpbGVzL2RlL2tuYXVmL2Vj bGlwc2UvamJv
c3NkZXBsb3llci9KQm9zc0RlcGxveWVyVXRpbC5qYXZhUEsBAhQAFAACAAgA g3s3N18+GJZ8
BAAAkggAAD0AAAAAAAAAAAAgAAAARSAAAGJ1aWxkZmlsZXMvZGUva25hdWYv ZWNsaXBzZS9q
Ym9zc2RlcGxveWVyL0pCb3NzVW5kZXBsb3kuY2xhc3NQSwECFAAUAAIACADc gTY3UJMWDMUC
AAB8BwAAPAAAAAAAAAABACAAAAAcJQAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9l Y2xpcHNlL2pi
b3NzZGVwbG95ZXIvSkJvc3NVbmRlcGxveS5qYXZhUEsBAhQAFAACAAgA1HU3 N34GP0txAgAA
ZBIAABcAAAAAAAAAAQAgAAAAOygAAGJ1aWxkZmlsZXMvamJvc3MzMjMueG1s UEsBAhQACgAA
AAAAnHQ3NwAAAAAAAAAAAAAAAAsAAAAAAAAAAAAQAAAA4SoAAGJ1aWxkZmls ZXMvUEsFBgAA
AAAOAA4ACAUAAAorAAAAAA==
--------------090809070104000304080609--
Re: Modified JBoss plugin which waits for successful deploy [message #200513 is a reply to message #200386] |
Tue, 25 September 2007 12:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------090002040107080308070208
Here's a third version. Now connection errors on startup will cause only a nice
error message, and an argument "debug" is added. If it is set, there is a lot of
output, otherwise there are only import messages.
Still, I do not know how to specifiy the host. Does anybody have an idea whether
this information is available in jboss323.xml ?
Best regards
Wolfgang
ZXBsb3llci9QSwMEFAACAAgAVqA4NyfRgdqWCgAA7hMAADsAAABidWlsZGZp bGVzL2RlL2tu
YXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9KQm9zc0RlcGxveS5jbGFzc41X eWAU5RX/fTNJ
ZrIZCC6Xq6KDiDmIu4KCdYMHR7DBBWkSggkeTHa/hIHJTNyZTaDUUi0ePdRq a5VYUWsVK1A1
ahKgIBWL1trWs3dra2trb1utvbzeN7PJ7pJAs3/Mt/O983vv99735tn39+wH MBsfKJAYqlM8
tt42Mu0xnrTMLpfH1rU5rpviXZazkadjSxfS22L/TUERw4R1RrcRswy7I3ZR 2zqe9BhK5pu2
6Z3LIFdWNTMULXJSPAQZpRqKUcJQnjBtvjzT2cbTTUabxRnCCSdpWM1G2hTv 2c0ib63pMtQk
xu5RLUl1GqbNMKVydSLnWaOXNu2O2qp6BccwnJwj1FsW7zCsBemOTCe3vboN Sd7lmY6tYCLD
1MMVLMyYVoqnVUxmmNvU4+hOWvfWpjnnupHV4OqdGdfT27judvGk2W7ylG7a rseNlO606yGE
MVWE4ViGyZWjeNgsOI7TcDxOoEAaXV3cTjGcUFlflTiCN7UqTmTQ43ombek9 hul5Zid3Mp7L
k46dcvXVKd6W6bhU6NWF3ukMp41m+Yj6heQMDadgJoPqOQGRYVLlSBHinYCp KioZin2zIVSj
RsGsApwEvBpOQ5TOyK/IGJZ7WDgCKNVWtao4nWH6UH70M4bDW+Hrr6jRbcfT K0KYgzMVnMFw
+tjRwtMrPdPSMBfzGMo6uOfTVqYthlPHFCE67kcQV3A2wzF5mLI93sHTGmox nyLWZaRdTntH
SHh9Kc7F+QrOKwzRRoJMp4YFWEhlRNkk6UDYdGIrSNIjeW50UvIXk2BwHtKn t5sWxUbFEgaN
gpPFQlxX8VGGUj0LimgIS5FQcCHDxFG0algmAKp0iS3LFsG9SMMKfIwh1G7a qUae7uZphlmV
rUFQNsQ6Ddvo4CJHsWULuWEHLIsc26Y8UkGRo41U+cG23u5k7JR+nl8OKwUo mw8D5VD+jwLK
ObhYQyVaRK2PjGtrVbOC1QzHj3AvUL3c6OQqLiVs+fCIun7A4y75Zyb5Ocuo iQyBJIRWTC3F
GrQpMAoyvdBxLDqrhiSoSIuXLEg01lFEEyM46PTtDNNWUXX6SaK+EWj3Qe2a dpJThtYSCocz
FI2qWMdw7CrRWzj1EL+2afXIRcPSixH8UiHY6FLgFOCnibqSkdJwBShNxa7F eRe1xsqlVc0q
CEshc6gEUiq6s5JRIRkN4leGDfi4go1UCWPLr4ZN+ARVs2l3O+upeZuViaNE vnZkwlaPzP7q
o9dglkvFJ6k4cgfS09zLpG2eiusKPkVl4EvY3IutbEiEsFn0p08zjKN6z+VA xTVZzihxRolT
wXUMM5x0R9A/Yqlh3lhOrN5ud0K4FjNK6fFZDZ/D50W4PcOjEJya+D/SjYKv thQ34gsKbmI4
ZSz8Gm4WRkqWLKhP1C0W12qNii/RNVnolc+rm64e8NXoPQGOUo7N9ekCzV/W cJuAbVFTw8o6
4f9WDb24g1QL/zOuuJVHxF/FndTScti5i2FZoeFooy8tTFcM8VUUmjeo9tca 3Vz3HD25lifX
+wXB02kn7Ypo3KPhq+KMSmPTgoamusWiQ35Nw31+LyQ2FdupUvIKSHj/dQ0P YgcxZET/Hp/I
z3qtSPsMFd+glkWWXb3doDaZ0qfri3zzbtCVLCcozRT3iO5GhdqHNTyCPlLo ZtpyFl0xxPgW
MnSDxBq5gOFjDMf5+kSJNxawUzWXoR+DCgYIeQWCGnZjD8XUpLo2PCct2llV nu767H5tGb6J
/Qr2UV5GUjU8gQOUS5tv8A6/mofr5EnRgPP9EtfCU3Q22swBTheGDml4Gs9Q Cihay32dNMu1
hgg2z2r4rqBobUFrazasDHXS7zFcNkoNUqQtl9foBcUmYJLjsDOWFdeHAycS QP3Q6eyyOCE4
v0R/QO3QMl2SHyJbG4csKniBzp0LzCKHJju/M5XheQyqeJnhpGEjeQbyDi5Q QsX0I2rhORMr
jOR6amAiVD9hOCMPdeJupaEu40WPDiMVP2OYnSc4NvSp+AVhIf+ayCSTnKeE ZAiv4tcKfjV0
fft5Hh5eNbzmj9ldwY1OB2hKG0kxUdOUStCdOEpjJQS2OdZiMVMxsFa/C6T9 UWg8KREXV1Mw
ShC1XlCzI0DlWO9/wpLTtk40f7oIj3o3UIWQK/XDYKK5hd6X+EGjqyrrTn32 IqTzjCPF+ezh
keCnY6QK8McwMzGG5k6CJU72s+aYQg1UNJSfJOEsB5acD1MSo2GR1E0Szh6O LgJ2ofIcB4PE
NwxPf4WJJnWhRieTTvIlpvhimpA33EYFP6aDKtefEyT6R19f9FToLUYro7W4 egDqIz45RM8S
f3MiyuipBQy0jqO1FONRHggXPwKVxnzIm6v3F9+Fiur9JXdh+l5MaNmLcEt4 0gCmVO/vRyQ8
rR8n9ePkAZz6hDyfuO5GdbiiunhOP6p6MW1YICYExO4Qc9H8annOIGYvqy6i 5axz+3COz7iI
GGuILVxHj2nCwgWBUD/qjx/E8niRz9ZAbJGifjQRhbZXRYqeRrG0cy9aW8KX DOCyeHEfLo+X
yPMUeZ66XXInq9tQPVmdEOrqxclDtjgpEXuWMNMxbManmT6NCFkDW1Q2CesH 0RkpihSH3aJ9
kFvkmkZaq1vkcKZxN3qKES+NlB7AmniJr+JK4WNJzse92NxSM4Cr4iFfx9WB jkhoSMmWQMkB
XBsvi5QdwruRsn5c75+u7DF8pg839OOWrZgU/qLY68Ot8ZKiecp2vCzItx/C c/4a/gqFfiue
8OnhbXnid5N4Lyr7cK/v3v3CPaI80I+dIuC7hgNAWgXhobgWftSX13bjcYb4 +O24LDJ+N/bS
/3GRccLRcl/Vt4SqcnI2UOHLlI9m86DPeCSbpPrbDL0fbBNR+04v9kXKnsZg +LkgwRSy7zOW
DdHzcS2iHcIdwrUXA9euGdW1l0Z37YFIqB+vbMUKn+mHgmlcHprK8+J9WkHA RnV+KBfDJ+jJ
nkDz4TXtnveuDv7cjfEEvvCPSWY7Zk5Wtor3e8M/9d8nC9LP/b+hxKx+/FLa Ke+kogV2yN10
GeySXX/1y5gtRQNRZlDpzqTv70rUoIo+l2bhHPrkXoXZaMGZdJPPRQfm0ch6 Nk2Utbgf87GD
Bq1dOB+DWIh9qKNYLsFB1OMQluMl+v77BxqYQt9xIaxkE7CKnYiLWQWtUbSy ubiE7F7OmrCG
Jek7yaK1G51sE65gW+CyW7CB3U4fFHdiE7sXV7JBbGb7aD4/iC3sBVzL3qB5 +01a38L17B3c
wN7DjZKMm6RjcbN0Em6RzsKtUh1uky7B7VKK1g70SuuI7uE+6Spsl67Dg9JW 7JC2YZf0KB6S
9uBh6UX0Sa/iMeltPC5LGJBPwaBchd1yDcVrHurlC/CkvAJPyatxSF6DZ+T1 eI6i+Lzcgxfl
TXhJvhKv+K3wALVEanf4DX5LbzXyUryO31EzXCNPwe9xB0W9Qy7HG/gD9dqb pdfxR/wJRRiU
9uPP+Au10H3SbvwVKWqvB6R+/I1kFRwkL98kCZVFJRV/p9iWsib2mhhiEWLd 7ADewtsoozj0
iAkUGkWiAf8kvnEUjwvxDlHL6cR34l/4N1EfxUb8x6fuQRr/FVQ6Rwn+h3f9 Xv+e3+Tf/xBQ
SwMEFAACAAgAVKA4NyzrZ36xCQAAXSIAADoAAABidWlsZGZpbGVzL2RlL2tu YXVmL2VjbGlw
c2UvamJvc3NkZXBsb3llci9KQm9zc0RlcGxveS5qYXZhpVltb9s4Ev4eIP9h IuA2dusq6e43
Z73bNMke0us2RexusCiKAy3RthJZ1IlSnCDof78ZkpJIvThOt0Bj2SLn5ZmZ Z4ZSyoI7tuQQ
cv8uYcXC50EcpZL7t3MhZcjTWDzy7GR/b38vWqciy+GW3TM/4bn/5frjiftr kUexfybimAd5
JJKuu1OeN4U9+GuWoA1rnuT+n+85S6Y8u+fZmUiSLkHO+qv5La75xNbcFiuy pXbA1x6opefV
5WWyECe7Lp7mLNfCj1692t+DV3DDohwWIoN6PYgFMPjwHqUAS9M4ChgZ7qv1 6s87VuQr3HMj
4sWSJUv4D8Fd3T/a30uLOe6DIGYoRInSRuzvPZF2AK0fcMefLEpgzVFg6Ctz JBQJwgssIfUQ
SWMbD32zxXy8S1nG1sCypTS/VP/OxBqBDSGOEu7Dr/Pst+aKRZTJnPYW5PMY 8hWHIovJebos
VeK62EiApgjJA4E6ahkbAjOP1lwUGlRZBAGXclHERmC3Lfkqymo5MBApAc7i 4Ri8kM+LpWdC
hJewFiG3pBzRh4FbYnjxI0IZa0R1MM2zKFl+/aYgGtLCJ7UJ8uxRX5jvANEC BrTKj3myzFdw
MIGf4aefoPHbL8NyQ7WTzM/EBhK+gUsslyWLT40nFw8BV64MvNlGYHLSUs55 5aqEdYFRmHOQ
KQ+iRYSAR4nMOQspEB68dgx4Dd5YBYmANjjrIEj4qtD55g1PSsO+lxdHR2cr HtwpDEs8Swv8
ctFciBjLFT/jc4XzBBYslvykD6FJDxq0zmjx+f8KlKH3ff3525A2KanDer21 dRcoUXj5G/xS
wXeoFB6OIBE5HJa4oUqo8bAQAeBoRI8NFgJ5VvCu/dWFzjBMvOwLhmVilzrP vhBJLnmufsT7
Gobjb7VJlKn4n6p+ZspmApdJzpc887G6Jccvettba9v0EVNk7eNyP0X9eYwJ ppWSMVSxGgNj
FqYNImPyZayyqqEUV5hqlr7KoDp14N88V4wgFZFDUDH5uFzUyfPl+i5MFlES 6vWDEuzauaOj
ywWGsdZXxCGFeCEKJJtBgDm6Ql7kCaASzSp0hbWf5UU6HJGxCeXBisDYRHFs 1lep3jZIM8vA
00YZVb8rpLQZI2gbSoleOjmBpIjjrnLIeF5kCbx5267Lut+BmN+qz4nK/frG wNPdTKqIj0ld
FPAJ9YzSASde7+sqvixdDFGq+d3/4/Tj9MKN73kUQt0hsTyx9fzewQp/4A0l q0ELdQpT4mb3
VPATOLbiWTfZVj9QKnW7s37AlocpEskV6hOZJYhV3WXFJNYww+kmrOK6WVHm DxzffePBXywu
+KAmIOL2QcvuI3h7PIRfG+XRFVY0RpUemoQRozYLnAUrU0UjkALzkOWw4UAZ K3ORqipKM7HM
EAI4cGR9EvDJiFmjtRI8rACGhXSvZg9qBihXoitI3ZibKB4hRcnEd3PuyCJd qQWLztSWr7/B
cTcI/1IgIFDHfSzdxT8kQ7EPhtlKJxklAVeF1Ie2zT2+7/XwdX/N3lA75Rgy PX5ERrxNc5XK
rjIGeP26ue7EAXQac55ioOdRboE6w1bOQl/SzcHb42O7DMvaprp26lDzhR8l 9+KOD0zVj8CL
qkXeyKIAHF2eShb/PrJDAGpVNeA8gafm8hinUV//6sF316QmJwwMKQxdK509 /bDXFhuK46Fu
LY4aF3AHVeor7hg/ru/jeUQNOpoP8dtAo2CHzd1s8Yf6iv65C4a94GOLrpe2 8S92Bd8cpAzw
lqufY5rxLz68hw8sU/1ZYmPCGYpnmcikblIJV+2OFUhOdj5ALhxhpqF4NJt4 I7fyheIbNewR
2Vh1GBG+xBn0u0fnoEJ6lFpUs5F0xHhWLlIzdW6SlY+6t2qa5r5z/4aXtKTt ULrQUGQp7Rvu
ldiwufZ6rirXm85Or2f/Pb/4/PHq74trz5GI99WegOFulzYdnIh5Lk6vDb7r aLnKK7Bm118u
PJgXuX24yZqOk9Vl4/FhKpqOJ44tI4Jzze5QmeQJeSYs7KWCuGFv/+BW1YCq ITeX7WwiKm9k
+kFj+GiQ9dFRl1adAV3afG25rXSbEN4rg7sieqmksTUXurAGw262BrCv23ho 3eboMWic/XEA
uvx4cT4c2jKe3NrGOJlZx6ofnPT4WlKIzfCp6vemSjf1FZmFxVHYEsf9pQ9q kHuz4XP/YR0P
W2vOBUr5dDVz5BuBRB1vPpxev9G6DtzN/RztppYCgIpWYzAirqDOGVIxHnh9 aEPvMElF5bC6
WVxNio3jk9PQ9RGsL35UOTqtaUbpXFBGuGYrNbSQzm3RfcaZHwHW18VE0B6W kg9deGlmW7F7
iyOIrTT9b0G+me0qU84a+ytSqq0atzbNrs6vxnCjGg2y3EZkWgQ1pVs8aDaT iuJy8JLCUgze
rKwW+tXsiKZ3UWAXl2D/tUihDRCoEZIOBAudeAcGInM4i8XSPD7K8b50R8wd klal7ZYoGK3T
Yl770cLz3bRIUxr8b1iWoCOYt0WiMoES1107xclIutImrRpw7u+cuMpq6t2u tTR492chOTmo
B1r6GDcMfC7qW2c1tKVrXNOqWrHacnq3TepqS7igt7001TghvqBCGzeXdNQI afiRMumArLtU
UEG4rVrIgOcL5odKpi3ombJp8H3j63fnnFd/sQemy4XunZ79HB7bp0ech8fq ctwj6jW90jz/
2XB7qsYJ3xbLGvlIs97I4mU8s4p1GvPcHqGlM/w5Q6+ntl5Wu6xNHvI/tmzi XBbHYkMNgKmH
IGokz9b6fM/mOFjZIlOW5RGeYjXFj8xor+dnHODjSOa1vvixnoL1m4TyMb79 oKjxQGDnxyTN
g9X2cfNFJ0atZATOCUxpqVaQrjFUvNUbHm+XaXF3Fq7ffEGAl83Y6gN0vaj/ cNkbqZFyTf91
Labo9Chtz/ot5miwdS3ks3k9OO7x6B9xeC2uh8pbdryA2KvoW5HfyoK1sh2O E7rgzBOHGV+n
9VMH6Hjs0HfusHQSARv+J5k7kX2/9y3kdGvrwnT7JLnV5l1OTdDRTJ66+suL h7wGeHXQ/vls
98Khf8fO1upt+ANm0QXO+Z6q3yLLyNVG0dCjjyKj1Bp6jcm+2o7+eCDIOyvd Ux1g6Tst1NbY
sVidP9g9OsLmMR96nR3Xek0IYbRYcGU3tqO0yOnFiupA9O4Sr83Td99+BdL3 XBf7xPOP0bc/
EFH6QrLF3znslTvV8dKKZeN42DakL2NfnH2OGS93XL0o4SGpdIXqSyMdB6Jg BYP63Sh/GDbe
a/MHLR/rOLibZSzA7l7Ja76bMmLNz/oVjtKJf/4PUEsDBBQAAgAIAGp8Nzcb cByDegEAAMIC
AABGAAAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95 ZXIvSkJvc3NE
ZXBsb3llckV4Y2VwdGlvbi5jbGFzc51RyUoDQRB9FWNG4r4k7ttNozh4EA+K BzeIjF7U3DtJ
GVvHnjA9cfksT4IHP8CPEqsnQUEDgg29vJqqV+/VvH+8vgHYxLyHDGGrzv6t Ua0rn2uhblr2
b6qRtXVuhtETx/7JvqDDDjp6rHEz0ZHxkCWM36h75YfKNPyvD4QRy7FWYYVj K/iyfEigE8Lg
QWRsokxSUWGLe9FeRMjtaqOTPUJhJfgmPE9ibRo7qxVC9iCqcx49GBpAHv2E 4UAbPmvdVTm+
UNWQCWNBVJOWShoL7gSzybW2hO3gXw53CH32lK1VjbTBL2mEUhfBQZeZiAsn f9LJn/qz7OI6
jh6cg9S8x49lYziW8XSlJuTPo1Zc42PtPM92N7PhSrEMEhkydMygFzm5PUEZ 9MkmN1o5BySy
Jzgjd6609oLB5zRnWM58Gi1IbREj8iq2szCKsfRn5jCOCeFwXIUOV1k6up5e aW39BcWfZAtS
tJiSLbXTvsi8Dpl7TYtgJ3E2rZ77BFBLAwQUAAIACACpdTY3B/4ahhoBAACH AgAARQAAAGJ1
aWxkZmlsZXMvZGUva25hdWYvZWNsaXBzZS9qYm9zc2RlcGxveWVyL0pCb3Nz RGVwbG95ZXJF
eGNlcHRpb24uamF2YbVRO0/DMBDeI+U/fGOJqlTMEVIFZSiPCQHzNbkkbl3H sh0oQvx37CS4
ZQCxIPlsyXffy9ZU7qhhVJzvFPV1zqUU2nK+3XTWVqxl98amSJM0WWTZ9aFk 7USnUHcGrmXc
XPoxfM3laYIMw7ak3rV+6LmTdUOqwW2gD61QizTR/UaKEqUkTzDQrCaWowof HKvKIt6kybuH
w1sJx6iFgQ7QRryQY1hHzhPXQpGE7Ly0ZSNIPrGxnuJxvcIFzu+KgJnIrgwH ZAjEUfxVuBbb
3joQ9mytf6b8myqWmgztYe/H7qmXMdwPsWYPzojgawKeBcgQDLC9ZoNZbBWD 2MefzEafIFX5
glDKk/Hx9f7D/RynH7YOkr8EmseZmMyvT1BLAwQUAAIACADSoDg3fgS2o7UG AAC2DAAAQQAA
AGJ1aWxkZmlsZXMvZGUva25hdWYvZWNsaXBzZS9qYm9zc2RlcGxveWVyL0pC b3NzRGVwbG95
ZXJVdGlsLmNsYXNzlVZbd9TWGd0HG48YJiQZwAkQqLh6bGMLaChgSIgvQ2xn ZpxgY2o3wZFn
ztiyNZIqaRw7vTe90LRN06ZNQnpL6YV29SXNw5hVr9V2rT61+U9d3UdSxxAm lLzocvRd9tnf
Pt+nf//nr38DcBJ/TGGLwImKNJYds141ZNm2vEAaS/NuEFSkZ7tr0jfGh/g2 krxdCS07hXaB
R5bMFdOwTWfBmJhfkuVQ4MB4aWSsNFjMzxWH8oOlyfzl6fzl4YlSKT88NTZR EsgWNp0mQ99y
Fs4LPDTsOkFoOuG0adelhm0CnUu1VcNyVtxlpr9cHBusmF7o+gIdFyzHCp8W aMt1Twu0D7sV
mUYbdmSQxnaBhwuWI0v12rz0p8x5W6qUbtm0p03fUu/JYnu4aAUCpwqfdueE u31BhtH6Fd8W
OJa7d0vd9y5p6BQQRhqPY28Ke+5iLzbJYB+eEEiTCT8MrlrhosDuVsFnUzgg 8NjHPwzVLbsi
fQ26wNaqZcuBNPbjkOLl8CdEmlYWRzM4hi4ya3qedCoCfQ+0oyTdeRWiO4Me 9ApooRt/FNiV
a0lCH/NE2AxazwWhf8lS5UhXLacyKf0VyRL35mZj31WjZjrmgqxJJzSKQ9J0 YhPKxaHcLNdh
NdL51bL01EuQwmcFTn+aijZ9UzhNzBHgOqtsPO+7nvRDSwZpPIkdGs4K7FOf +x2zxq30V80y
9bjWr9RombaGAYEu11/oX3I8LobSp4UM+kuRORGHcjW8FDupkBcyeAqU8fZA hkmyNYGzLai/
fzHik0dmnxF4ohXAum/3e8sLgYYhiiZCqPj4nxk5IrsaRgQev9Pd890Vi/VV /houKXIcb8Aw
bHWYFt0gHDh54tw5DaP0G/alGdJJH4vJ0JPtpiEwnsFzKFCRFTlfpy46W+xw tns6hVJC8KoR
IzCSYM1YRTyvtPwCEyYxokqNmsFiqA51JOdJXElhKqGiGSouQrPYGUxHrcJj 9nAyNMvLUz6L
peHzAofjzbiO7lb1uyHoVZNirQzoKs1sBl9Qkk+zGRRlEFCmaZzCSwriNYGe +xeyCYWgNbws
cLDgusuKwrqnt259ioD5DMrgCe2waV33/n/zSdSRQpW2D3akNLDvaPGq2mob utNYVrSy2R2+
i9Zht1arO1Y54qu5pW1w4KXg3t3i1oJQ1jL4InjA26TP6+4Yp+XysEV1IPE1 Cplj5PSwW7cr
uuOGejkGpoeuHkSY9JwV6FaoR21SVnTTpl9lTb9ImCtYTeEVgZ0tImewpvpg Kiq6zW1+SWCw
EPGoSt2SC72rdS26mlIQ2DY379ojsbjFLIXOk+NxtHQWWnUTNqy2crgqsL9w H7HTaouk0YHC
/WRMq44g6Zm5B2+YHWWWLc/oRwsPUE1q53sCe6O9KGjGpFXzbDlihvKS69dM to7vUy+jowO1
2kDAbnkdh5QC3sjgR1Gt3XqYwo8FdmzSoZzTtHkrg5/iZwKPluu+T8hTVk0W LdtWk5njfTyN
N/GOOlDvcmDnxtX5vo73Mvg5fqHGSJRe4Mid3UCFbjV+1dz9VQa/xvuUwIr6 zZiofuz4JGel
5di6yYKoYm9XIys57jz7lSYL7DiFT+ZIjalJt+6XZTzuOu/5rehXzjjIhtnG /zISjq3o4D3F
ty3Q0M5n/t/wmuGKwbvgfWvPOh76S2TyMK8d0WIWj/CaiQ3wKN+BbdiJXYnz S0yhvvX2ZHc3
8NgN7NrA/pnsZ9ZxsKeBIw3kPogWjt+x0EyxI8KnM+AhYjx2R6pe9BOASmXg BK1P8lmhPqWS
ij8RylaufLSBJ2fW8blCb/ZM9lwD56/2Zi9mB+OH4WxePYhi9tm9tzG2geJM 7zomireQK+29
gVRfA5c3cGomgneV8LgwEyPsW8eLfxel7JxyPJ7VGjD/AVmKLBdiSyu2VAa3 MDLQzojanvYG
lj5ELRs0UBelWzi+ub6Z6lUGUCtJrj3tKlnfB6TiKCf5GU6Da/g2pbkc3d/n e0xWFXt4vcDy
PcU6PE3CLuIwBuk1Qrry9HwWZzFGi+fwDNv7i3iBEaZQ4XxycJURZ/A6x8wb rNlbmKPuX2b0
edykxR8Y/c9YxL+YVRVhNJLKR/gyvsK7hn/iq/ga6T9Ky6/jG0R0FkfwTbxG 1NdQw7eItI3R
d+I7+C4LdRNd0dd2FpADO9HKa4ykCn5u3w2c2cD1mezr6/hB8UP8UBFzfANv ztzGT9bxdgM3
buOX5Cn7G5KUyIacboozy9BAnddXqKJVwnk1Aq7HCfDbSD3qSW2B/YK/lL/D 7+ktuAUV5dZ/
AVBLAwQUAAIACADRoDg3ZxmzuV8FAADCDwAAQAAAAGJ1aWxkZmlsZXMvZGUv a25hdWYvZWNs
aXBzZS9qYm9zc2RlcGxveWVyL0pCb3NzRGVwbG95ZXJVdGlsLmphdmHNV1tP 20gUfkfiP5z6
pQ6LnPaxCbRNwbRpSUBJKF2tVtFgT5KBsccajyHRiv++Zy5OHOdSturDCohh 5vg7t+9cyEj0
QKYUYho8pKSYBDTiLMtpcH8n8jymGRcLKtuHB4cHLMmEVHBPHkmg6FwFQzzh 9JwoeiFkQlR7
XaZQjAf6dtv5tRQZlYrRvI49DxKSokkJTVXQ+0RJOqTykcozkaY0Ukyk7Zp8 ShKWToMzkSRF
yiKiZcJ5RLO9wqn2YcdtN2WKEb5fqG8eVUWHB82joxt0DyJO8hwmQoKaUTCx hDKYhwdwBObj
IynUDGVuBZ9MSTqFbzoF+kr/NA8PsuKOs8ihff2EKOcORGs5PPgH5QB1fu2f dwHNoiAmRuPW
uAVa2uACZJI9YmogVxiuCCYsJRyGSqJHoNH6nV447n0KO/1hOPgeDs6u+v3w bNS96sMpePfJ
vMnSR/FAZXPQ63ZikikhvXZbQzubziTVCrQ1xnK4GVwuI5JnNGITRmPUzGkA 1rLy8TEjkiQw
zpW8wOvyVFJVyBQ6BgkNR/qgtU9MzcDTMK2mV/XQxs456FybUmWMuZHcd0el loZ+yQQUzW92
4ngJisGiEza34QM2Ab98JzBW5Ldogu81vQacnoKShcVaogE4yy2gB38slbat xLN9UJ7TfW82
d736XI27zTcoYSNtSAAk1aHGj53sKF/oEZaWLAOWGjYE6/kZUgonBGYYllNv plTWajaf2AOz
TSMQcmr+bN6aszz7kGE9n34RT+ei+5mqAU2Eop0oonk+Er2FMcd7/5uATprk fY1Hd4Kf07ti
CqPBTagTGJu/EhFTYDmg734iJBZPobJCNWp8G/2XiLl3uxMgcBKhgvcv6FEn TSOpbcGbaEbj
Yw2cQv/m8lKfWktoXObho5pJ8VRrCUs46KQLoFIKib5FUWFo/jRDzkDkjEdT dpbKdl81eewh
+HdCcJRZBbYBew2qVtaRrh8ip3nAaTrF0n11Cm/r9WLQIKVP0OWcTgnvyGmh B8LKR98L5yRS
fIHpo0DcPSRFruCu2mBetUCXTUVlY73qXB/AssKugN1to88G1a6hcf5683ej 7WJn6063DCRk
teKiZexapQT8JopbvNUIxQYlshxN1xFbHfulo+Y6yKlydwvfTbag2++Oup3L Mbb3UfhjNL7o
nI2uBn8eg4eGBfdpFjAUlBOC+t3Ac69eYPCFXHg/14Hdenz97fP4ehBedH+E wxLc+O/qApcO
zN4LwK4HV9+75+FgjKgIhBZiPLmICJ+JXLXevnn3zqBYnPU5DpGa6yAVnDs9 Si5qzNtMvukV
vmfGmeaJwwQH6h1XyqBdwjhNmsBrJvjGMyQPkuFCigTu05gF2TJla8Q0vQD8 2p4BdF4vFzOS
lk1ufQZVxHDAzFEXZnSocO0bScyqv7L5ebP6dvSXMhr4K+4btSBPCDaa2BYd 6sPa6SF3kdR+
4xgPoFZ9L62e7V3JSf9aUtGPSyEedFKLzNi7f/PZmunyubTE32ppQ1Mi4Kiu yPz9albYO8lo
0W2MreJACdvHdJQ3zFwn1PYhhCFPkvDXuWVffwm/hotc0STACWWluWGUKHgM qVBl6vV0dUH1
cQQyZVc+7OiEI/viBXxoeCv0bUz4n9eRpR9SD4toO71f/5yUKOC9/lnRba05 t97YwLXra+St
ZLi9E0gsjs6GyxtuSZs7FE4D8w9FHOxc5Z1FO3aznevIo2CxU1Zd2R3aMWwu I5V1Y19Gl/ms
/x8L8epX28Q3JHzvy5dWkrTyvELBVXxWvF5BBRPz8DWeRkJvrDwuaBKH34gl tMc4Zzi3QX9h
Ym1CK+42als/fv8LUEsDBBQAAgAIAIegODeoV3ULSQUAAA8KAAA9AAAAYnVp bGRmaWxlcy9k
ZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95ZXIvSkJvc3NVbmRlcGxveS5j bGFzc5VV3XMT
VRT/3SZp0rBICZRay8eWKknTNIH6SVKUlvJRSEshpZhWlE1yG7bd7IbdTSni ByrWV3nQGX3B
GWf0pS/CTIowVp90xhcf/UN888Hx3N2ktaR0ajKz9+ucc885v9859/d/Hq0A OILP/GhiiBV4
Yk5XKjMJntfUssUTsznDsgq8rBk3uZk4O0SrS7q79sPL0DqrzCsJTdGLifO5 WZ63GZoHVF21
X2fwRHomGbwnjAIPwoMWCT40M+xIqzofq5Ry3JxQchpnCKWNvKJNKqYq1rVN r31NtRji6f/j
U4r0SoqqM+yJTKfXfMvYpqoXUz0jfuxkOLh2MKJpvKhog2axUuK6fXIhz8u2 auh+7GJof9LA
UEXVCtwMoI2h/7zOZcOU7RuGrNTULblUsWw5x2WrzPPqjMoLsqpbNlcKsjEj BxFCu8jCswxt
kQ3cmxQSz0noxF7Ko1Iuc73AsDcy0pN+iiupAPYzbE/KFVOTpws8VyleEUZk YaSLoW+ja55q
TGh2S3geLzAEbMM9ZNgdaVQh2Va0BxBh8DnXBhFFzI/edZxwZSX0IU4B8esV RbOeiN2lTapn
KoDDDF11JOT+1VyGHfvhmKwbthwOoh8v+fEiw+GtMGO4trpkq5qEl/EKw7Yi t13WmBrDoS1l
KNWC15D04+j68G4StiUJKQwQ3Y0Ksb/NVVWNxDjp2aTNlRKhRPUQqrOU7Mkz qkaRBXCcgVFM
Qxj24wTDrg20JZwUjPGXxZamiwSclnAGIwzBGVUvZLg5z02G3siU6/hCoqTo SpGLPCZGh7ii
uyInDF2nXBO9U36cY+hsEHbBGFNKPIBRQsNJaNxywkxaZETN82OjVGD1tAZx Fu0tGMdFPy4w
7FzLzZBhaHSzhAwmiCOnBtOZkxRfukGCkkNtIqjWoSoE8GYty3EhF3cR2IYp vOXHNCG2tRgl
XMHbxDpVnzfmqKGokfQm8aYaIZ9uZOn05lypSQVwlYpmLSDZ5HbF1GkiCiwn SjP/RGnWq2CT
0uwHlxDBjOhtjW5MieYxjmsSVMwySDk3uZOKVuFOK6b6IrYHKjUOBkBNcudg uSyrllzfFLkv
M3TXtkW91Q+c6rsmmGsbcsGIB2HC9sOqU9bxZbV9Sqg4rb7ssljJz02YSl50 dWqVQmeDRJJz
OUMbFrVONTFFyFm26ZRoaCPhZqtG+8hWOU8lZORmBdgM+zblAnVUcmVkFUBa k+Z/16FG7Bia
+MJqA1ifDzoMZoyKmeenVOfFW/dqxYUGukA4QfyaaEZPJX39tErQyGj0RZcR +ME5DtK32dnc
Rn9AcgVo3E5jC57BDle5qRsBMbJEdMV7D+Hoiu8euh6jNfsYoWxo9zL2RFeq 6Ajtq+JAFQeX
cehnzwBJfYNoKBz19lfR8zX2rSokhILYrQt7B6Ke/oc4MnofrzoSx0giRueh N1yhKgY7H+LU
WN9v8DUtPcbZbCi9jLGk9z7OJ319Hd7QJe9P8GQ9sQyN0awndDnzI7I+JJs7 mn/BeNLnmH2H
zHb4qlDIJNkriHnxK5wWBuY2NnB5U+Pkb6hEzn2PNjE1nGkw3VvF9aYlzxIl GbjDDhHLF1m3
M7ppfxf76dsBUcRRmsdwgCqzC8fQjcsII0u7V9GLW4jjNg7jDp0u0rtzl96P L3EU3yKJJRof
0KPxCAP4gzT/xHH8hUHCcIi10NiKYdaJM3TrORamPtyLMdaHCw7UFwlQghPz uEGrGP7GAm4S
2FfxK/l2i7y8je/wHt4nLt3FF/gAH8JLN39O+xNEkQew8BE+puoME4U+If8E uz51aLX4L1BL
AwQUAAIACACGoDg3HGoMiK4DAAAbCgAAPAAAAGJ1aWxkZmlsZXMvZGUva25h dWYvZWNsaXBz
ZS9qYm9zc2RlcGxveWVyL0pCb3NzVW5kZXBsb3kuamF2YbVWwW7jNhC9G/A/ THXYSFmX3uzR
rotNstsi7W4XqJv2EORASyObCUWqFBUnMPLvHVKiZDt2sSnQg02ZejPz5s1w 6JKn93yJkCG7
V7zOGaZSlBWyu4WuqgxLqZ/QTIeD4UAUpTYW7vgDf2QFV2RWoLLsywVyNUfz gOZSK4WpFVpN
j+O/Lu4I8xsv0Lsdn55eqyYQcPBhgZelFCl3joCrDNZcWMi1gapOU6wqNhzA KfivD7y2K3rz
l5b5kqsl/OrScK/cZzwclPWCfEEqOTn+5YLch3DDwcYRACAKbiFv/4kJNFzc 8qHkhhfAzbIC
uNRF4WykUNhs/bAwP7ZIgFyYyrr92skygevfP+8CKkw1mQcExLp0PLhMJhBl uKiXkafiH6HQ
GW7Zj93S5l5ZSiAFQT4KLlQ8t0ao5c2tJ5U44MYbgTVPzUP7G0DkEDsUk6iW dgXfzeAM3ryB
vb33STDoLMnbyug1KFzDlZS45PK8zeTTY4o+lTj6StJQCnatuzwrKGoSZoFQ lZiKXGBG1CuL
PAOdQwRvd6K/hWgCtZFw43W4jZJpoPAcHsbjyxWm916toFwIxwJoobWkTqZV fvSKziDnssLp
MS1mR/J2uDYKw79r8tHY3ZzdJs7Ie016/Jbpt4hGzsMevO+0OvEBT0agtIWT IBKFhF6PLUUA
kEgc4bClgDU1HrLvHppeohYz11SDWXPCPrZz49oKyZZom2NnZCPDu9ue0vyJ ClswXVtWkiMr
qSfCIXR+cyGxSaeNQOU+8SXua/szWpKN2sXPIEi7ITQJmIMjKuAPcc6Fyhp8 HMToOY/HVznJ
3MerZeZKkOuajmucUg+taG6gAgrSzhMXznJj6zIZObLK1WnlMlwLKVs82+60 wG4GqpbyUJ8Z
tLVR8P3Zy4YPaz9rQS/u/DrzzdW/iCM/6VjlKzFxYUWKsy80KIIke3pDf5ja CyJzc7JT+6I/
SFdB1ozitvvsp/PP80/TXYqO3g64SZ8J9aDvMW7JjyASHSgabWVCw2wTWuR5 tN3MDtMNvA1E
7j5ikm4K1uxG8NyXdp9y3HJOdvl1+Jed0wzjeItnWyd6cG28E2EEL7vL1X4H xNrB9CeXNcZ+
grhTeagjqDbh8Ez63WNS1i30X4R8nXrw/1URXstkPH5tLQ8Po/OyBFFB0IoI H7hftmfp5pv8
uSmddV0QZoHVkGn2MkK70P+QdAVxfxPgY7J3X+NjE2pu6Y/dH4an1DGdt/2B 8RxOdfvind/3
u/T1D1BLAwQUAAIACADroDg3maPsG4MCAACkEgAAFwAAAGJ1aWxkZmlsZXMv amJvc3MzMjMu
eG1s7VfLctowFF2br1A9rJhB7mO6SR0WnWzaZWYyXcv4msiRLVeSIZTh33tl y7wCAWJoaRNW
MrovnXOPHmGhZApDQ3KWwbUfQyHkFB4N5JrL3CckhoSVwjRTNP0IQCcQ4VTE NMRcXfvUH3S8
ECMVoMzUhSpYqYHWXj4ZM1Hinx/e+8FO2zLfsP5sjZ9au0oMz0CWZmH9qY6N 9oapEawvaVk3
mnhhyhSuTJuECzTpzhwKdCLVA89HFJc1D7qzTMalAGoDzemEKX9A0NsLf/HC empMUgGwsLR+
NgNxPy/k+VCUMbhier2gR3tVnTYOPD6ZtFnq6TBYpqmKDrDqavCu379zWBGe EAU/S64gviL9
vlvdmJGhYFo3ENCHnJUJhaHgBSKdRlJrx7Wi37/i190C/MqxYOYeif3SnWlQ Y1C3UpobTDI0
Uk3nAcaB3ARVHCZEv/6mWKCPBRCSMC5kDkpJRMeoEirYEZAQqWkIa2LToowE 1/c7UQ+a5Y+Z
HXUQVy/M5BjIsfwRIx1hW1K7PIhuqAVAQTQMZR7rKsFKN1tDB7Wz/8G4IYm0 PWUNMsSiFRk3
J6Fil4fgUW3e11NtIDuAtha8eeuu6+Kdb3AbBrV29+gY0hY6Tk+r48Ziq5rt svbJ+bUpOj2Z
otM3Rf9BRadtFf2Mnq0kX6pn+Af1bDvyyDZq4n1Lbl20SxM2bAj7Ejavv6oY WCrGEr7iHkNU
jpabTuudEM6wE75tg/tI3b8NHkH8c3ef5mW08YqJQYBZNsqBt7J1MBImNKJB wqCOtq9NmlI2
jswLvqCc4s2x8xRbZ2blXvofwbHtwvai7kvP032HkrO8ZLz286gtkXBmInHc CQN38A1+A1BL
AwQKAAAAAACcdDc3AAAAAAAAAAAAAAAACwAAAGJ1aWxkZmlsZXMvUEsBAhQA CgAAAAAAnHQ3
NwAAAAAAAAAAAAAAAA4AAAAAAAAAAAAQAAAAAAAAAGJ1aWxkZmlsZXMvZGUv UEsBAhQACgAA
AAAAnHQ3NwAAAAAAAAAAAAAAABQAAAAAAAAAAAAQAAAALAAAAGJ1aWxkZmls ZXMvZGUva25h
dWYvUEsBAhQACgAAAAAAnHQ3NwAAAAAAAAAAAAAAABwAAAAAAAAAAAAQAAAA XgAAAGJ1aWxk
ZmlsZXMvZGUva25hdWYvZWNsaXBzZS9QSwECFAAKAAAAAAC8fDc3AAAAAAAA AAAAAAAAKgAA
AAAAAAAAABAAAACYAAAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL2pi b3NzZGVwbG95
ZXIvUEsBAhQAFAACAAgAVqA4NyfRgdqWCgAA7hMAADsAAAAAAAAAAAAgAAAA 4AAAAGJ1aWxk
ZmlsZXMvZGUva25hdWYvZWNsaXBzZS9qYm9zc2RlcGxveWVyL0pCb3NzRGVw bG95LmNsYXNz
UEsBAhQAFAACAAgAVKA4NyzrZ36xCQAAXSIAADoAAAAAAAAAAQAgAAAAzwsA AGJ1aWxkZmls
ZXMvZGUva25hdWYvZWNsaXBzZS9qYm9zc2RlcGxveWVyL0pCb3NzRGVwbG95 LmphdmFQSwEC
FAAUAAIACABqfDc3G3Acg3oBAADCAgAARgAAAAAAAAAAACAAAADYFQAAYnVp bGRmaWxlcy9k
ZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95ZXIvSkJvc3NEZXBsb3llckV4 Y2VwdGlvbi5j
bGFzc1BLAQIUABQAAgAIAKl1NjcH/hqGGgEAAIcCAABFAAAAAAAAAAEAIAAA ALYXAABidWls
ZXB0aW9uLmphdmFQSwECFAAUAAIACADSoDg3fgS2o7UGAAC2DAAAQQAAAAAA AAAAACAAAAAz
GQAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95ZXIv SkJvc3NEZXBs
b3llclV0aWwuY2xhc3NQSwECFAAUAAIACADRoDg3ZxmzuV8FAADCDwAAQAAA AAAAAAABACAA
AABHIAAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95 ZXIvSkJvc3NE
ZXBsb3llclV0aWwuamF2YVBLAQIUABQAAgAIAIegODeoV3ULSQUAAA8KAAA9 AAAAAAAAAAAA
IAAAAAQmAABidWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlwc2UvamJvc3NkZXBs b3llci9KQm9z
c1VuZGVwbG95LmNsYXNzUEsBAhQAFAACAAgAhqA4NxxqDIiuAwAAGwoAADwA AAAAAAAAAQAg
AAAAqCsAAGJ1aWxkZmlsZXMvZGUva25hdWYvZWNsaXBzZS9qYm9zc2RlcGxv eWVyL0pCb3Nz
VW5kZXBsb3kuamF2YVBLAQIUABQAAgAIAOugODeZo+wbgwIAAKQSAAAXAAAA AAAAAAEAIAAA
ALAvAABidWlsZGZpbGVzL2pib3NzMzIzLnhtbFBLAQIUAAoAAAAAAJx0NzcA AAAAAAAAAAAA
AAALAAAAAAAAAAAAEAAAAGgyAABidWlsZGZpbGVzL1BLBQYAAAAADgAOAAgF AACRMgAAAAA=
--------------090002040107080308070208--
Re: Modified JBoss plugin which waits for successful deploy [message #200791 is a reply to message #200513] |
Mon, 01 October 2007 07:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------000606000607040507020307
Here is version 4, which uses server host and port from the ant task properties.
I think it is final now ;-)
Wolfgang
> a nice error message, and an argument "debug" is added. If it is set,
> there is a lot of output, otherwise there are only import messages.
> whether this information is available in jboss323.xml ?
> Best regards
> Wolfgang
UEsDBAoAAAAAADBrPjcAAAAAAAAAAAAAAAAOAAAAYnVpbGRmaWxlcy9kZS9Q SwMECgAAAAAA
MGs+NwAAAAAAAAAAAAAAABQAAABidWlsZGZpbGVzL2RlL2tuYXVmL1BLAwQK AAAAAAAwaz43
MGs+NwAAAAAAAAAAAAAAACoAAABidWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlw c2UvamJvc3Nk
ZXBsb3llci9QSwMEFAACAAgArKw+N2U1LhKvCgAALhQAADsAAABidWlsZGZp bGVzL2RlL2tu
YXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9KQm9zc0RlcGxveS5jbGFzc41X eWAU1Rn/vZ0k
M9lMCC4EjIoOIiZZYlYiYt0AypG0wQXTJAQTPJjsvoQJm5llZ5ZDsRbv2qrV 1iqxglYtHlg1
aAhSYyo2iqWt9ajau7b2rr1ttR793swmu0sCTf7Yl3nf+b7v933vey9+9NQg gLn4WIaPIRjj
ofWmnuoM8WjcSNg81N1h2XaMJ+LWFp4MLV9CX8vcLxl5DJO79Y16KK6bXaHz O7p51GEoWGCY
hrOIQaqobGXIW2rFuB8SClXko4ChJGKYfGWqp4MnW/SOOGcIRKyoHm/Vk4b4 Tm/mOesMm6Eq
MnGPakmqRzdMhmkVayIZz5qdpGF21VY2yDiG4eQMoSEe5116fHGyK9XDTadu c5QnHMMyZUxh
mH64giUpIx7jSQWlDPPqrVRSs5Jap7GRa3paga31pGxH6+CaneBRo9PgMc0w bYfrMc3q1PwI
YLqIwrEMpRXjONgqOI5TcTxOoDjqiQQ3YwwnVDRURo7gTK2CExnOCmupZFzb pBuOY/RwK+XY
PGqZMVuzeXIjTy6OxZLctrVuM2Y0WklHWxPjHamui4Q5TZibyXDaeA4d0ayQ nKXiFMxmUBzL
IzJMrRgrQryTMV1BBUO+a9aPIKpkzMlBj8er4jRU09H5hpQetw+Lkgew2sp2 BaczzBzJmjZv
NOrlrv7yKs20HK3cjxrMk3EGw+kTxxBPrnKMuIozMZ+hqIs7Lm1VMs5w6oQi RMf9BMIyzmY4
JgtppsO7eFJFLRZQxBJ60ua0dwQcNBRiEc6VcU5uiLYQknpULMYSKi5KMkl7 woYVaiRJh+S5
3kOYWEaC3nlIH2E0TrFRUM+gUnDSEAlrCj7FUKilsVLtx3JEZJzHMGUcrSpW CNzKCbEVN0Vw
z1fRiE8z+DsNM9bsIo3h/HEONHan3Qvc5lCPbupdXOQxtGIJ101PzVLLNCnX VIp0mGbqGd62
1mmlzJh2jltJqwRwWw8D7ghGjgLcGlygogJtokuM51irjDUMx49xz1O9Uu/h Ci4i/LkQqrbd
pIRFnRlRvnAFtZ8RIPnRjumFWIsOGXoOGpZYVpzOqiIKqu/8+sWR5jqKemQM B52+k2HGaips
N5HUcDztLvBtw4xyyuI6QupoFqurFXQzHLtatCVO7cdtC7Q65KIe1/Lh/cX8 MJGQYeVgrGUd
5TqmYgMolfl2nPMENdWK5ZWtCghvfmOkTGIKNqYlq4VktRe/ImzGpTK2ULVM LL8qLsNWqnjD
3Gitp7ZvVESOEvlxkLRmbPbXHL1O01wKPkMFlDmQluROKmnyWFiT8VkqFVfC 5E5oVVPEjytE
D7uKoZh6QiYHCq5Jc1YTZzVxyriOYZaV7PJ6TCg2yhvKiDWYnZYf12JWIf3c oOLz+IIIt6M7
FIJTI/9Hulnw1RbiJnxRxs0Mp0yEX8UtwkhB/eKGSN0ycSFXKfgyXbC5Xrm8 mmFrHl+VtsnD
UcwyuTZToPkrKm4XsM1raVpVJ/zfrqIXd5Jq4X/KFvf5mPgruIvaXgY7OxlW 5Bqubnalheny
Eb7yXPM61f46ne5bx9Ki63h0vVsQPJm0kraIxj0qvibOKDe3LG5qqVsmuuh9 Ku53+yWxKdhF
lZJVQML7B1U8hIeJISV6/KRIdtZrRdpnKfgGwxyybGudOrXSmDZTW+qa925X LW55pRnjDtHt
aqH2MRWPo48U2qmOjEVbjD+uhRTdMqFmLmD4BMNxrj5R4s057FTNRejHgIy9 hLwcQRX78BTF
1KC61h0rKdpZZZbuhvR+bRG+iUEZT1NexlJVPIMhyqXJNzuHX9+jdfKsaMDZ fomr4zk6G21m
AKcJQ8MqnscLlAKK1kpXJ02B7X6CzYsqviMoaofX2lr1eIo66XcZLh6nBinS cZtXaTnFJmCS
4TBT8XhYGw2cSAD1Q6snEeeE4OwS/T61w7hhk/wIOb5lxKKMH9C5M4FZatFM 6HamIryEAQWv
Mpw0aiTLQNbBBUqomF6nFp4x0ahH11MDE6F6k+GMLNSJ+5fmwZRTfXQYKfgx w9wswYmhT8FP
CQvZ10QqGuU8JiT9+Dl+KeMXI1e8m+fRsVfFW+6AnvBufTpAS1KPilmcBlyC 7pRxGishsMOK
LxNzFwNrd7tA0h2XJpEScXG1eOMGURsENT0mVEz0/icsWR3dovnTRXjUu4Eq hFxpGAUTzTb0
Xe8Gja6qtDsN6YuQzlNMirPZA2PBT8eI5eCPYXZkAs2dBAus9IPomFwNVDSU nyjhLAOWjA/T
IuNhkdRNFc4eji4Cdq7yDAeDj28enRBzE03q/M30gInyekO8tSZnDcDVgh8z QZXrzgk++o/e
bfQr01eIVkZrfnAvlMddsp9+C9zNKSiiX9VjoLWY1kJMQoknnE8i9BSAdE1w UN6J8uCgshMz
92Ny234E2gJT92JacLAfZYEZ/TipHyfvxanPSAuI624EA+VBuaYflb2YMSoQ EgJid4Q5b0FQ
qhnA3BXBPFrOWtSHhS7jUmKsIrZAHf3MEBY+6Qn1oyGYXxMsqDl+ACvDeS5z EzGX5fWjhei0
vbos73nk+3bvR3tb4MK9uDic34dLwgXSfFmar+zy2aXKDgRLlcn+RC9OHrHI SYnYiwtjXaPG
XJrh0oiQNnC1wqZi/QB6yvLK8gN23tOQ2qSqZlqDbVIg1bwPm/IRLiwrHMLa cIGr4nLhY0HG
x/24oq1qL7aF/a6OKz0dZf4RJVd7SoZwbbiorGgYH5QV9eN693RFT+Bzfbix H7dux9TAl8Re
H24LF+TNl3fhVUG+YxiH3DXwVUrAdjzj0gM7ssTvJvFeVPThXte9rwv3iPJA P3aLsD8yGgDS
KgiPhtXAHlde3YcnGcKTduHiskn7sJ/+Ly4rFo6WuKq+JVSVkLOeClemZDyb B1zGI9kk1d9m
6P14h4jawV48XVb0PAYCh7wEU8i+x1g6RC+F1TJ1GHcK1172XLtmXNdeGd+1 B8r8/XhtOxpd
ph8KpuIsNJVkxfu0nICN6/xILkZPsCl9AtWF14x7PrzS++duTCLwBd4gmV2Y XSpvF9/3Bn7k
fpcK0k/cf/2ROf34mW+3tJtKF3hc2kpXwh5pi7u6xcyWo4kos6iAZ9NLvQJV qKRH0xwspMf5
asxFG+bRfX4mujCfBtezaRqsxW4soHlnEfbgXAxiCQ6gDsOox0E04BBW4k16 Kf4HTayYXnOT
sYpNw2p2Ci5gpJHNQzurxYWsEZewdqxlBr2WkrRuRQ/bhg3sBtjsDmxmO+hZ cS8uYw/icjaI
K9gBmtIP4mr2Oq5l79DU/S6t7+F69gFu9Em4yVeIm30n4hbfbNzqW4jbfOfh dl8H7vB109qD
Xl+C6Jfift912OW7EQ/5duJh3314xLcPj/qG8JjvDfT53sYTvvfxpKRgrxTE gBTCPqkGj0gL
0CCtwLNSK56TdAxLnXhB2oBDFMWXpMvxsrQNr0hX4TW3IQ5RY6Smh1/h1/RV JTXibfyGWuJa
6QT8FndS1LukUvwOv6eOeztZ/AP+iDwM+gbxJ/yZGukB8ugdxKjJDvv68ReS lXHQtwd/JQmF
zfMp+Bv+jkK6fN8Soyz8bCsbwj/wTxRRHDaJORQqRaIJ/yK+YorHeXiXqCV0 4rvwb8qLSha2
4D2XOoQk3hdUOkcB/osP3I7/odvqP/ofUEsDBBQAAgAIAKusPjf3JbikyQkA AIUiAAA6AAAA
YnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95ZXIvSkJv c3NEZXBsb3ku
amF2YaVZbW/bOBL+HiD/YSLgNnbrKune3hdnvds0SQ/pdZsiTi84FMGBlmhb iSxqKSlOEPS/
7wxJSaReHKdboLFskfPyzMwzQyllwR1bcAi5f5ewYu7zII7SjPu3M5FlIU9j 8cjl0e7O7k60
SoXM4ZbdMz/huf/18tOR+2uRR7F/IuKYB3kkkq67U543hT34K5agDSue5P4f 7zlLplzec3ki
kqRLkLP+YnaLaz6zFbfFCrnQDvjaA7X0tLo8T+biaNvF05zlWvjBq1e7O/AK rlmUw1xIqNeD
mAODj+9RCrA0jaOAkeG+Wq/+vGNFvsQ91yKeL1iygP8Q3NX9g92dtJjhPghi hkKUKG3E7s4T
aQfQ+gF3/MGiBFYcBYa+MieDIkF4gSWkHqLM2MZD32wxH+9SJtkKmFxk5pfq 34lYIbAhxFHC
ffh1Jn9rrphHMstpb0E+jyFfcihkTM7TZakS18VGAjRFZDwQqKOWsSYw82jF RaFBzYog4Fk2
L2IjsNuWfBnJWg4MREqAs3g4Bi/ks2LhmRDhJaxEyC0pB/Rh4M4wvPgRoYwV ojqY5jJKFt9u
FERDWvikNkEuH/WF+Q4QzWFAq/yYJ4t8CXsT+AV++gkav/1rWG6odpL5Uqwh 4Ws4x3JZsPjY
eHL2EHDlysD7IAqJ2Ylw3vPK0wxWBQZhxiFLeRDNI8Q7SrKcs5Di4MFrR/9r 8MYqRoSzgVnH
IMNYUJkdh6FEvOE2CaMvVA/fFGY33vCoNPd7eXFwcLLkwZ1CtkS5NMwvF82E iLGI8TM+VehP
YM7ijB/14TbpwYjWGS0+/7NAGXrft19uhrRJSR3W662t2wCMwsvfMG4lqvtK 4f4IEpHDfgkn
qoQaDwsRAI5G9NhgIZDLgnftry503mE6yq8YrYlNAFx+Jepc8Fz9iPc1DIc3 tUmUv/ifuODK
FNMEzpOcL7j0seYzjl/0trfWtukjZs7Kx+V+ivrzGNNOKyVjqI41BsYszCZE xqTRWCVbQymu
MDWe+SqD6tSBf/Nc8YTOOwgqfh+XizrZv1zfhck8SkK9Xvv2881Ix+ufeFHC X7t7cHA+x8DW
FhRxSEGfiwJJaRBg1i6RP3kCqFazD10hR8i8SIcjMj+hzFgSPOsojs36Kvnb JmoGGnjaTKPq
d4WdNqPLUEr90u0JJEUcdxWI5HkhE3jztl2pdV8EMbtVnxNVDfWNgae7XqZy YEzqooBPqLeU
DjgRfF/X9XnpYohSze/+h+NP0zM34qdRCHUnxYLFFvV7B098wBtKVoMo6qSm VJb3RAETOLTi
WTfjVt9QKnVbtH7A1ohJE2VL1CekJYhVXWjJMqxqhlNQWMV1vaRaGDi++8aD /7K44IOakqgH
DFp2H8DbwyH82iiYrrCiMaoY0SSMGLVj4CxYmroaQSYwD1kOaw6UsVkuUlVX qRQLReV7jqzP
Aj4bMSu0NgMPK4Bhad2rGYW6BsrN0BUkc8xNFI+QomRiwBl3ZJGu1IJFZ2rL 19/gsBuEfygQ
EKjDPt7uYiSSofgIw2ylUxYlAVeF1Ie2zUa+7/UweH/NXlPf5RgyPaZERrxN fJXKrjIGeP26
ue7IAXQac55ioGdRboF6tZTYz/2Mbg7eHh7aZVjWNtW1U4eaL/wouRd3fGCq fgReVC3yRhYF
4IjzVPL695EdAlCrqkHoCTw1v8c4tfr6Vw++uyY1OWFgSGHoWuns6Ye9tthQ HA91s3HUuIA7
qFKnccf9cX0fzy1qItJ8iN8GGgU7bO5miz/UV/TPXTDsBR+bdr20jX+xLfjm wGWAt1z9EtNZ
4Ozje/jIpOrYGTYmnKq4lEJmukklXLU7ViA52fkAuXCEmYbi0bTijdzKF4pv 1PhHZGPVYUT4
EmfQ7x6dl4rMo9Simo0yR4xn5SI1U+cmWfmoe6umae479695SUvaDqULDUWW 0r7h3gwbNtde
z1TletOr48ur/5+effl08b+zS8+RiPfVnoDhbpc2HZyIec6OLw2+q2ixzCuw ri6/nnkwK3L7
ECSbjpPVZePxYSqajieOLSOCc8XuOE3pCXkmLOwzBXHD3v5RrqoBVUNuLtvZ RFTeyPS9xvDR
IOuDgy6tOgO6tPnaclvpJiG8VwZ3RfRSSWNrLnRhDYbdbA1gX7fx0LrNYWTQ eEaAA9D5p7PT
4dCW8eTWNsbJzDpW/eCkx1cZhdgMn6p+r6t0U1+RWVgchS1x3F/4oAa5N2s+ 8x9W8bC15lSg
lM8XV458I5Co483H48s3Wteeu7mfo93UUgBQ0WoMRsQV1DlDKsY9rw9t6B0m qagcVjeLq0mx
caByGro+lPXFjypHpzXNKJ0LygjXbKWGFtK5KbrPOPMjwPq6mAja/VLyvgsv zWxLdm9xBLGV
pv8NyDezXWXKSWN/RUq1VePWpquL04sxXKtGgyy3FlKLoKZ0i0fPZlJRXPZe UliKwZuV1UK/
mh3R9C4K7OIS7L8WKbQBAjVC0oFgrhNvz0BkDmexWJjHTDnez9wRc4ukVWm7 IQpG67SY1X60
8Hw3LdKUBv9rJhN0BPO2SFQmUOK6a6c4GWWutEmrBpz7Wyeuspp6t2stDd79 WUhODuqBlj7G
DQOfi/rGWQ1t6RrXtKpWrDac3m2TutoSLuhtL001TojPqNDGzSUdNUIafqRM OiDrLhVUEG6q
FjLg+YL5oZJpC3qmbBp83/j63Tnn1V/sgel8rnunZz+vx/bpEefhsboc94h6 Ta80z3/W3J6q
ccK3xbJGPtKsN7J4Gc+sYpXGPLdH6MwZ/pyh11Nbz6td1iYP+R9bNnEui2Ox pgbA1EMQNZLL
lT7fsxkOVrbIlMk8wlOspviRGe31/IwDfBxlea0vfqynYP3GoXzcbz8oajwQ 2PoxSfNgtXnc
fNGJUSsZgXMCU1qqFaRrDBVv9YbH22Za3J6F6zdkEOBlM7b6AF0v6j9c9kZq pFzTf12LKTo9
Stuzfos5GmxdC/liXiOOezz6Wxxei+uh8pYdLyD2KvpW5DeyYK1si+OELjjz xOGKr9L6qQN0
PHboO3dYOomADf+TzK3Ivt/7FnK6tXVhunmS3GjzNqcm6GgmT1395cVDXgO8 Omh/f7Z74dC/
ZWdr9Tb8AbPoDOd8T9VvISW52igaevRRSEqtodeY7Kvt6I8Hgryz0j3VAc58 p4XaGjsWq/MH
u0dH2CzmQ6+z41ovDiGM5nOu7MZ2lBY5vVhRHYheceK1efru269A+p7rYp94 /jH65gciSl9I
tvhbh71ypzpeWrFsHA/bhvRl7IuzzzHj5Y6rFyU8JJWuUH1ppONAFCxhUL8t 5Q/Dxvtv/qDl
Yx0Hd1eSBdjdK3nNd1NGrPlZv8JROvHPX1BLAwQUAAIACACIbj43G3Acg3oB AADCAgAARgAA
ZXJFeGNlcHRpb24uY2xhc3OdUclKA0EQfRVjRuK+JO7bTaM4eBAPigc3iIxe 1Nw7SRlbx54w
PXH5LE+CBz/AjxKrJ0FBA4INvbyaqlfv1bx/vL4B2MS8hwxhq87+rVGtK59r oW5a9m+qkbV1
bobRE8f+yb6gww46eqxxM9GR8ZAljN+oe+WHyjT8rw+EEcuxVmGFYyv4snxI oBPC4EFkbKJM
UlFhi3vRXkTI7Wqjkz1CYSX4JjxPYm0aO6sVQvYgqnMePRgaQB79hOFAGz5r 3VU5vlDVkAlj
QVSTlkoaC+4Es8m1toTt4F8Odwh99pStVY20wS9phFIXwUGXmYgLJ3/SyZ/6 s+ziOo4enIPU
vMePZWM4lvF0pSbkz6NWXONj7TzPdjez4UqxDBIZMnTMoBc5uT1BGfTJJjda OQcksic4I3eu
tPaCwec0Z1jOfBotSG0RI/IqtrMwirH0Z+YwjgnhcFyFDldZOrqeXmlt/QXF n2QLUrSYki21
077IvA6Ze02LYCdxNq2e+wRQSwMEFAACAAgAqXU2Nwf+GoYaAQAAhwIAAEUA AABidWlsZGZp
bGVzL2RlL2tuYXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9KQm9zc0RlcGxv eWVyRXhjZXB0
aW9uLmphdmG1UTtPwzAQ3iPlP3xjiapUzBFSBWUojwkB8zW5JG5dx7IdKEL8 d+wkuGUAsSD5
bMl338vWVO6oYVSc7xT1dc6lFNpyvt101lasZffGpkiTNFlk2fWhZO1Ep1B3 Bq5l3Fz6MXzN
5WmCDMO2pN61fui5k3VDqsFtoA+tUIs00f1GihKlJE8w0KwmlqMKHxyryiLe pMm7h8NbCceo
hYEO0Ea8kGNYR84T10KRhOy8tGUjSD6xsZ7icb3CBc7vioCZyK4MB2QIxFH8 VbgW2946EPZs
rX+m/JsqlpoM7WHvx+6plzHcD7FmD86I4GsCngXIEAywvWaDWWwVg9jHn8xG nyBV+YJQypPx
8fX+w/0cpx+2DpK/BJrHmZjMr09QSwMEFAACAAgAmaw+N0r0XIgMBwAAdg0A AEEAAABidWls
ZGZpbGVzL2RlL2tuYXVmL2VjbGlwc2UvamJvc3NkZXBsb3llci9KQm9zc0Rl cGxveWVyVXRp
bC5jbGFzc5VWW1McxxX+WsDuaFnL9lrCxrpkJNkCIcHYihVLi29clgBZFhkQ GGJbHnZ70cDs
zGZmlkCcu2PnHiVOFEe535V7bD8sqlAVp1J+SKUqL6nKU8oPecnPSPL1zGhB 1lrBLzPdp0+f
c/o73zndf/3PH/4I4EH8PoldAg+UpLHimLWyIYu2VfWlsbzo+n5JVm13XXrG +CBnw/HsfGDZ
SbQK3LFsrpqGbTpLxuTisiwGAofGC8NjhYGJ3IWJwdxAYTo3NZubGposFHJD M2OTBYFMfmvT
dOBZzlK/wG1DruMHphPMmnZNatgt0LFcWTMsZ9VdofupibGBklkNXE8g8Yjl WMFjAi3dx2cF
WofckkyhBXvSSKFd4Pa85chCrbIovRlz0ZbKpVs07VnTs9Q8FrYGFy1f4FT+ 3Z6c4bYvySCU
n/dsgWPdNx/p+M0iDR0CwkjhHtybROcN6EUqaezHAYEUkfACf84KLgrsa2Z8 IYlDAne/fWGw
Ztkl6WnQBdrKli2zKRzEEYXL0XewNKs07k/jGLqIrFmtSqck0LujE8Xu+pWJ 42n04ISAFrjR
osDe7qYg9NJPGJtB7Qt+4I1YKh2psuWUpqW3KpniySb+b5YsRPbXjIrpmEuy Ip3AmBiUphOZ
IaUcUtJyHWYslVsryqqa+Em8V+D0u8l6Y28Sp3muMJAamWCc89yq9AJL+ik8 hD0azgjsV8t9
jllhiH1ls0jOrvcpxlqmrSEr0OV6S33LTpXCQHrUkH5fIVRnxIFcC0aiTcrk I2k8ClK93ZdB
7Gxd4MyO4NmOflSdRP8JgQPNAqx5dl91ZcnXMEhihREqPK6rESOiq2GYyWPo WcPQMEI2ZzWM
Ctx7HWpnSQ9cPYLfOOd6gZ6CwHgaH0CelCzJxRqJ0dHdLJezGtgd7tkeXNVz Vy0yTEWn4RxX
hzxphm7GIkD1GLIkpmLk14xosxFrxAopPIkZVQjnaSX2H6Zw1PQvBqojhLUw h/kknooxapiK
stNgQRoLYZ+pMvJgOjCLKzMes6jhaYGjUYSuo7tl/cYQ9LJJppeyunLzbBoX VL2k2EkmpO+T
vymcgqlCXBTouXWGG6H0K9hYsIfzrruicKlV9eZ9UwFQTmMJ7CkJm9q16v/v XDFtklim7s5q
TQM7ohZJ1VFbcDwFV8FKf0dvgHXIrVRqjlUM8WocaTc8MJ/+jf1x3Q9kJY0a Vtn3pccesS+K
03JZhWEeCHyFDF9jcQ+5NbukO26gF6PAFC39MCa92/J1K9DDHitLumlzX2ld f5xhfgQfTeJ5
gbuaWE7jY6qJJsOk2zzmJwQG8iGOKtVNsdC7mueiq0EFEkC1wOt9L+yHqm4E dl9YdO3hqGDE
AouHxVAlKB35Zu2HHS7BreF11FIMiMHB/C2qgeq7JJUO5W/F89BoHFn3zltt osi85mj9/vwO
0k1yfZUdJDyUCs2YtipVWw6bgRxxvYrJpvMygRkdzVYqWZ999hKOKIpcTuOb IRncGtnyLYE9
W7iozSnqfDuN7+C7AncWa57HkGesipywbFvd+3w8jKfwCr6vKu4HfA50j6sG cAk/SuPH+Im6
pEL3AvdtbxfKdLPLXd3qP0vj57hKjqyqR8xk+W31FRdT00vxl0yIYkO7IkDc D8iNUgMFtqT8
O2OkLrhpt+YVZXSZdtz0aOlTm3GY3biFrz4CjjYk+E9ytgsaWjnm64nfNCUG /4L/tp4N3PZa
qHI7v4lQmMEd/KYjBdzJObAbd2FvvPkZulBrJ3oy++q4+wr2buLgfOY9Gzjc U8d9dXS/GgpO
bhM0XOwJ49Np8AhjPLbN1Qn0MQDlysAD1H6QYxX1KeV0VztD0Xiw5CYemt/A +wq9mYczZ+vo
n+vNPJ4ZUIPQ6VDsNJPj50TkPdsaLr2fS52tkejANYz1ZibUtH9OZNsyk0qy iSfnezcwnW27
ipPZxIEr0DoTdcxu4tR8aOKDygQlz0RWOhMbeO4NkU1kimp7Z1tGq0P+CVY2 EaqvxOqVLadX
kcsmQ8PJOpzX8aHMh+tYpwnlsbGw5fHjykRyy2NSeexMvEoYZ1GGxavmMt7A n9mC1f+fnEdA
O3xrAmcJWpY57CfYj+I0HsM4nsA0Brk7h6cxQgujWKHURR4BCngZU7R0noU1 h6t4ipYX8CY1
/4Jn8Tc8h3/ApJci3oLEv3jd/BuWaIUdJrJMijFF+GSYSDX6VMQpjj6NF0Ii /hefwYuM/jT+
jpe42spIXsNn8TkmeAVd+Dy+QOllVvcX8SWO3iTvvoyvkMhvxatJUoTvjZiN L9CmotTZ/Vfw
8CYuzWe+toGvT7yObyj8Tm7ilflruLKB79Xxw2v4KeHM/IJYxsQk9lv0zzAY YJXfNfJ0HWfw
fHgsPXKAX0XH4kgdhh2JT+Jf4zfcLfDb0Mrv/gdQSwMEFAACAAgAmKw+NzD/ aTJnBQAAPBAA
AEAAAABidWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlwc2UvamJvc3NkZXBsb3ll ci9KQm9zc0Rl
cGxveWVyVXRpbC5qYXZhzVdbb9pIFH6PlP9w5JeaFNm7j4WkLSGkpQ0kAtJ0 n9DEHmASe8Ya
jxNQ1f++Zy42hgDNVn1YRcEwPv7O7TsXZyR6JHMKMQ0eOSlmAY0SluU0eLgX eR7TLBErKtvH
R8dHLM2EVPBAnkig6FIFYzxJ6AVR9FLIlKj2pkyhWBLou7vOb6TIqFSM5tvY yyAlHE1KKVfB
4JwSPqbyicqu4JxGigne3pLnJGV8HnRFmhacRUTL9JYRzQ4Kc+3Dnrt9zhQj yWGhobnUFR0f
hScnt+geRAnJc5gJCWpBwcQSymAeH8EJmI+PpFALlLkTyWxO+By+6hToW/o/ PD7KivuERQ7t
yzmiXDgQreX46AfKAer8MrzoA5pFQcyMxp1xC7S0wQXIJHvC1ECuMFwRzBgn CYyVRI9Aow07
g950cN7rDMe90bfeqHs9HPa6k/71EM7Ae0iXIeNP4pHKcDTod2KSKSG9dltD O5u6kmoF2hpj
OdyOrqqI5BmN2IzRGDUnNABrWXn5mBFJUpjmSl7i7fJUUlVIDh2DhIYjfdDa Z6YW4GmYVujV
PbSxcw461+ZUGWNuZeK7o1JLQz9kAormh504rkAxWHTGljZ8wGbgl88Exor8 Dk3wvdBrwNkZ
KFlYrAoNwFluAT14WyltW4mf9kKTnB56Mtz36M963G2+QQkbaUMCIFyHGj/2 sqN8YEAYL1kG
jBs2BJv5GVMKpwQWGJYzb6FU1grDZ/bIbNMIhJybn+GdOcuzDxnW89ln8Xwh +p+oGtFUKNqJ
IprnEzFYGXO8938I6DQk71/yyHoL7oKuRtbxl5I3utBNQZmS3xK4F8kFvS/m MBnd9jQXYvMr
FTEFlgOG0U+FxDosVFaoxhZ1J/8l+O7Z/gwInEao4P0r2t1paCS1LXgnWtC4 qYE5DG+vrvSp
tYTGZUo/qoUUz1vdpYKDDl8BlVJI9C2KClMxzwukXxlAbcreqtvtq+ahS0S9 CO1RE2pHOhdN
uBciQZx18Btw0OhaIZfljGSpV0NUGdMqJeAP0c/irccbNg+R5dg0OX2uHfsN V7/mdpBT5e6t
fDd1gv6wP+l3rqbYeie975PpZac7uR790wQPDQseeBYwFJQzgvrdMHKPXpII 2/HK+7UO7KTT
m6+fpjej3mX/e29cghv/HdFwIcBRXIGF4XnBkrgMJSK4GLq8Ydqwu5opwXVA y57lMv4WvKoD
6vQ61BfDLTCF5Xvdima6RixIaGpUo1hlzRo1Kiv3O30zuv7Wv+iNpmh7szQz ERFJFiJXrb//
evfuFaHbRLGGNMwSoJ/b3CAgUktNgSJJHK6Sq61Ovz8CepBq/x0mOFBvh9tQ akKybZrgG08a
bU31SylSeOAxC7KKkBuDyLQO8Lc2HKDL7cFmhmHVEzenX00MR9sSdSFfxwoX zolEzvprm3+W
X0xZG+P3tKMyGvgVN52tIM8I9qW4ZYiB+nDWD7AysWT9RhMPoLE5bV/bG3Y3 MSf9e0lFP66E
eNRJLTJj7+Gda2emy2tlib/T0oamRJCguiLzD6tZY+8lo0W3MbaKAyVs5eso vzBzk1C7ZxaG
PE17v88t+/hr+DVe5YqmAQ40K50YRokC2xkXqky9bjQuqD5OTKbssonLKkmQ ffEKPjS8Nfou
JvzP68jSD6mHRbSb3m9+TUrdyt/8quh21pzbhmzg2tsL7J1k+N5AILU4pu3b vOFS9XLlwlln
XmXiYO9LhLNozyq3d3t5Eix2yup7ikPbtZfUNo9DGa3yuf0GDfH6q23iLyR8 7/PnVpq28rxG
wXV81rxeQwUzc/E1nkZCb6w87nMSR/uEpXTAkoThVgL6T89oKIe0c7ex9b6B 138BUEsDBBQA
AgAIAKysPjffWabRZAUAAFMKAAA9AAAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9l Y2xpcHNlL2pi
b3NzZGVwbG95ZXIvSkJvc3NVbmRlcGxveS5jbGFzc5VV23MTVRj/neayaVgE AqVWbltAmoY0
gSIqSVFayqWQlkJLsa0om+xJuu1mN+xuahHvF5xhePDFYXScwScdZ3iRhxZk rLw54/jqo3+I
L47f2U1aS0OnJjN7bt/3ne/y+33n939+XgRwGF9IaGJIajw9Y6rVYpoXDL3i 8PR03nIcjVcM
6wa30+f6aHXZ9NcSggybp9VZNW2oZil9IT/NCy5DuEc3dfc1hkC8c4wheNLS eBQBNMsIIcyw
KaebfKhaznN7VM0bnCGWswqqMabauljXNoPulO4wpHL/x6cs6ZVV3WTYHp/M Lfs24tq6Wcp2
DkjYwrB3+WDAMHhJNXrtUrXMTffUXIFXXN0yJWxlaH3aQF9VNzRuR9DCcHR0 yuZcsWylaFVt
Ra1ZcJRy1XGVPFecCi/oRZ1rim46Llc1xSoqUcTQKhLxPENLvIGHY0LiBRk7 sJNSqVYq3NQY
dsYHOnPP8CYbwW6G/RmlahuKw+1Zbvdqms0dR5k2NX3Ysl1lUuP5aumqsK0I 2+0MXY1uf+Yd
QnOfjP14kSHiWv4hw7b4ahWS3YzWCOIMIe/aKBJISji4Ai2+rIwupChOfr2q Gs5TKfEBle2c
iOAQQ3u9RsqRpRR3ePY7koppuUpHFN14ScIRhkPrwUx/bXXZ1Q0ZR/Eyw4YS d3082QbDgXVl
KNuMV5GRcGxleDeo5GUZWfQQEawq8aLFV9Wt9DDpuaTN1TIVj5gSq+OX7ClF 3aDIIjjBwCim
PvRLOMmwtYG2jFMCSFJFbBmmSMAZGWcxwBAt6qY24qGB4UKDSFbvTPjBzaXL qqmWuMh1erCP
q6Zv5qRlmlQPIkdWwnmGHauE/YINqWUewSBVzEt6yvFSkRHI1Av8+CDRs576 KM6htRnDuCTh
IsOWZZf6LMugm2WMYJRwdLo3N3KKcpBbJUEJpCYT1evl1CJ4o1aJlJBL+cFt wATelDBJVV1f
jDKu4i1Cpm7OWjPUjvR4bo14G2RzcjWSJ9fGU00qgmtErOWAFJu7VdukiSBh XtC38BR960xZ
g77d4DLiKIrO2Kj01HeGMSVDxzSDnPeTO6YaVe41cuIgMSJSreE0AmqxW3or FUV3lPqmyH2F
YV9tW3CyfuAxdEqg27UUzUpFYcOV4NRh7fmy1HxlVL2HouIjXS3MjNpqQbwJ 1GWFToNEknN5
y+gX/YB4M0GVc1zbo3GskXDYqVEjvl7ME82s/LQoNsOuNbHAsJFcGVgqIK1J 87/r2OraMTTx
uaUmsTIfdBgdoUemwE/r3nu54s1LCQ20g+oE8WuiGT209JVolaaR0RhKLCDy k3ccpW/Y29xA
f0D2BWjcSGMznsMmX7mpExExsqOJxfA9dCQWpXtof4zN448RG49tW8D2xOI8 2mK75rFnHnsX
cODXQA9JfYdErCMR7p5H5zfYtaSQFgpity4c7EkEuh/i8OADvOJJHCeJJJ3H XveF5tGbCHYn
Qt07HuL0UNdvCDXdf4xz47HcAoYywQe4kAl1tQVjl4O/IDAeSI7QmBgPxK6M PMJ4CJlwW/gJ
hjMhz/jbZLwtNA+VDJM9TcxLX+OMMDDT2MCVNY2T17EyufgDWsTU8qbR3MF5 XG+6H7hPqQZu
syRh/Q7r9EY/+e9iN33bIKicoHkSe4if7TiOfbiCDozT7jUcxE2kcAuHcJtO 79ALdZdemm9x
DD8igwc0PqLn5Ql68Cdp/oUT+Bu9LIw+tonG7ehn7ThLt55nXdSND2OIHcFF r+CXqKxUVMzi
HVolqfpzuEElv4Y/yLeb5OUtfI/38D4h6i6+wgf4EEG6+Ut8hFECyiM4+Bif EEe7CEif4jMP
Y5974Lr1L1BLAwQUAAIACACkrD43mxl748YDAABHCgAAPAAAAGJ1aWxkZmls ZXMvZGUva25h
dWYvZWNsaXBzZS9qYm9zc2RlcGxveWVyL0pCb3NzVW5kZXBsb3kuamF2YbVW S3PbNhC+a0b/
YctDTDkqlEdPUtWJ7SQdt0nbqeL24NEBIpcSZBBgQdCP0fi/ZwESpCRLnbgz PUigwH18++2H
hQqe3PAlQorsRvEqY5hIUZTI1gtdlikWUj+gmfR7/Z7IC20srPktv2c5V+SW o7Ls8zlyNUNz
i+ZCK4WJFVpNjtv/vliTzW88Rx92dHp6pepEwMGnBV4UUiTcBQKuUrjjwkKm DZRVkmBZsn4P
TsF/veOVXdGbv7XMllwt4VdXhnvlPqN+r6gWFAsSySnwL+cUPqTr9zYOAABB cAtF+09IoMbi
lncFNzwHbpYlwIXOc+cjhcJ668eF+amxBMiEKa3brxwtY7j689OuQYmJJvdg AbEuHA4uB2OI
UlxUy8hD8Y+Q6xS3/EduaWovLRWQgKAYORcqnlkj1PJ67kENnOHGO4E1D/VD 8xtAZBA7KyZR
Le0KvpvCW3jxAvb2fhgEh9aToq2MvgOFd3ApJS65PGsq+XCfoC8ljr6sDCJQ EZmuTFtqCXlF
3CwQygITkQlMCX1pkaegM4jg5Q6AlxCNoTKSGHMqPEtTQ62BtUrFH06C156h eTSYBHCP4WE0
ulhhcuN5DJwGFCwYLbSWpHFa5XvP9RQyLkucHGNpeoQRZ9dkYfhPRTFqv+u3 84Fz8lEHnf2W
67fQScHDHnUpUHjiE54MQWkLJ4E7SgkdH1uMACCBOIJhiwFrKjzk3z7UKiPx mStqzbQ+e++b
iXJlhWRLtPWBNLKm4dW8gzR7oH7nTFeWFRTISlJLOJ4ubiYk1uU0GUgFJ77F XW9/Rku0YaML
SNrxNA42B4dXsD+EORMqre1ryK/nw5rPN/QQ6OmqGI0uMyK+Q1DJ1DWF5E5H O05IVSuaMaiA
0jazxwGw3NiqGAwdfOU6t3I13wkpG3u2rb2AdwqqkvKQ8gzayij4/vXTIxDW bi6DXqz9OvVy
617EkZ+KrPS9Gbu0IsHpZxoqgaS9DkB3vJrLJHUzteX/vDtal4HolPI2++zj 2afZh8kuRAdv
x7gunwl1q28wbsAPIRKtUTTcqoQG3yaI5nG4LW9n0w7HDUTu7mKSbhVW70bw 2LV2H3LcYB7s
4mvtn2qpHtzxFs6mT/TghL2T4ZC6XO93jFgzqv7issLYzxR3Tg8pgnoTjtO4 2z1GZdWY/guR
z2MP/r8uwnORjEbP7eXh8XRWFCBKCFwR4AM3zvZ03XxTPDe301YFYRZYDalm TzM0C/1nSVYQ
d3cD3g/27na8r1PNLP0J/GJ4Qoppo+0PjMdwqpsXr/y+36Wvr1BLAwQUAAIA CADFrD43sZhj
O6MCAADxFAAAFwAAAGJ1aWxkZmlsZXMvamJvc3MzMjMueG1s7VdNj9owED2H X+FGnJBw+qFe
tlmkVntpT9VKq54NmbDOOnFqO7AU8d87Thy+ls8FCm3hlOA34/F742cnzJVM oGdIxlK49SPI
hRzBs4FMc5n5hEQQs0KYeogm7wHoELo41GUaIq5ufep3Gl6ImXJQZuRS5azQ QKsonwyYKPDP
d2/9YC22yJbQHy34JdpVYngKsjBT9IcqN+INU31YXNKsboR4YcIUrkybmAuE NMeOBTqU6oln
fYrLmgTNcSqjQgC1iSZ0yJTfIRjthb94biM1TlISMEXaODsDcT8v5FlPFBG4 YlqtoEVbZZ02
Dzy/GLSzVMNhMJumLDrAqsuHN+32g+OK8Jgo+FlwBdENabfd6gaM9ATTuqaA PmWsiCn0BM+R
6aQrtXZaK/rtC749TMkvA3NmHlHYT82xBjUAdS+lucNJekaq0STAPJCZoMzD hGhX7xQL9LEA
QmLGhcxAKYnsGFVASTsSEqI0tWB1bpoXXcH141rWgw3Bn6NIgdaTmrQFSJJF /LtUxo1aBgfM
PjVQGi9M5QDIvi1AjHSar6jezYMChVoA5ERDT2aRLieY2xAW6NRy+B+MGxJL 25YWkCKdB+l5
dxQ110UI3q3gbT3SBtIdlD9A+iVVF/f/auUPaI4wqPxji5dAcoCXJMf1khqx 0lHssrZZyv/m
KskluUpydZU/6CrJ2V1lg6dYW3itp8Bf6Cm2pffswzrf1/jeZbs0c4G6w5z4 l2CgZ91ysGbL
7b+dqo6ZQ0TQLfoz2zvYi+EEXnw14r264jRGvEfnbLoB1t+oS9+TEQgws07b 8XK7yGbMhEY6
SRhU2bb1WV3K0ql/wde0430CnOIgXpR27nr/D/GZHJ9P73X9n5ym/3dVd3bR up7JZ+4EOHEn
4HMjDNzh3/kNUEsDBAoAAAAAADBrPjcAAAAAAAAAAAAAAAALAAAAYnVpbGRm aWxlcy9QSwEC
FAAKAAAAAAAwaz43AAAAAAAAAAAAAAAADgAAAAAAAAAAABAAAAAAAAAAYnVp bGRmaWxlcy9k
ZS9QSwECFAAKAAAAAAAwaz43AAAAAAAAAAAAAAAAFAAAAAAAAAAAABAAAAAs AAAAYnVpbGRm
aWxlcy9kZS9rbmF1Zi9QSwECFAAKAAAAAAAwaz43AAAAAAAAAAAAAAAAHAAA AAAAAAAAABAA
AABeAAAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL1BLAQIUAAoAAAAA ADBrPjcAAAAA
AAAAAAAAAAAqAAAAAAAAAAAAEAAAAJgAAABidWlsZGZpbGVzL2RlL2tuYXVm L2VjbGlwc2Uv
amJvc3NkZXBsb3llci9QSwECFAAUAAIACACsrD43ZTUuEq8KAAAuFAAAOwAA AAAAAAAAACAA
AADgAAAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95 ZXIvSkJvc3NE
ZXBsb3kuY2xhc3NQSwECFAAUAAIACACrrD439yW4pMkJAACFIgAAOgAAAAAA AAABACAAAADo
CwAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNlL2pib3NzZGVwbG95ZXIv SkJvc3NEZXBs
b3kuamF2YVBLAQIUABQAAgAIAIhuPjcbcByDegEAAMICAABGAAAAAAAAAAAA IAAAAAkWAABi
RXhjZXB0aW9uLmNsYXNzUEsBAhQAFAACAAgAqXU2Nwf+GoYaAQAAhwIAAEUA AAAAAAAAAQAg
AAAA5xcAAGJ1aWxkZmlsZXMvZGUva25hdWYvZWNsaXBzZS9qYm9zc2RlcGxv eWVyL0pCb3Nz
RGVwbG95ZXJFeGNlcHRpb24uamF2YVBLAQIUABQAAgAIAJmsPjdK9FyIDAcA AHYNAABBAAAA
AAAAAAAAIAAAAGQZAABidWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlwc2UvamJv c3NkZXBsb3ll
ci9KQm9zc0RlcGxveWVyVXRpbC5jbGFzc1BLAQIUABQAAgAIAJisPjcw/2ky ZwUAADwQAABA
AAAAAAAAAAEAIAAAAM8gAABidWlsZGZpbGVzL2RlL2tuYXVmL2VjbGlwc2Uv amJvc3NkZXBs
b3llci9KQm9zc0RlcGxveWVyVXRpbC5qYXZhUEsBAhQAFAACAAgArKw+N99Z ptFkBQAAUwoA
AD0AAAAAAAAAAAAgAAAAlCYAAGJ1aWxkZmlsZXMvZGUva25hdWYvZWNsaXBz ZS9qYm9zc2Rl
cGxveWVyL0pCb3NzVW5kZXBsb3kuY2xhc3NQSwECFAAUAAIACACkrD43mxl7 48YDAABHCgAA
PAAAAAAAAAABACAAAABTLAAAYnVpbGRmaWxlcy9kZS9rbmF1Zi9lY2xpcHNl L2pib3NzZGVw
bG95ZXIvSkJvc3NVbmRlcGxveS5qYXZhUEsBAhQAFAACAAgAxaw+N7GYYzuj AgAA8RQAABcA
AAAAAAAAAQAgAAAAczAAAGJ1aWxkZmlsZXMvamJvc3MzMjMueG1sUEsBAhQA CgAAAAAAMGs+
NwAAAAAAAAAAAAAAAAsAAAAAAAAAAAAQAAAASzMAAGJ1aWxkZmlsZXMvUEsF BgAAAAAOAA4A
CAUAAHQzAAAAAA==
--------------000606000607040507020307--
FUDForum. Page generated in 0.06726 seconds
