Home » Language IDEs » ServerTools (WTP) » Validating an XML snippet against a default schema, without referencing it
Validating an XML snippet against a default schema, without referencing it [message #199983] Wed, 19 September 2007 03:56 Go to next message
Originally posted by: oemer.yildiz.semanticedge.com
the user is able to open an (WST) XML editor which gets its contents
from a custom IEditorInput. It only returns the relevant part of the
"backing" XML document. Is it possible to tell the editor to validate
this snippet against the schema specified in the document?
Ömer
Re: Validating an XML snippet against a default schema, without referencing it [message #200160 is a reply to message #199983] Thu, 20 September 2007 22:34 Go to previous messageGo to next message
>Hi,
>Best regards,
>Ömer
Hi Ömer,
Can you clarify your scenario? Do you mean you've got a custom editor from
which you want to invoke validation, that the WST XML editor isn't
validating your document, something else? The more details the better.
Lawrence
Re: Validating an XML snippet against a default schema, without referencing it [message #200168 is a reply to message #200160] Fri, 21 September 2007 03:53 Go to previous messageGo to next message
Hi Lawrence,
the editor I'm opening is the WST XML Editor, but not with a custom
IEditorInput, which only returns a specific snippet of an XML document.
So the editor doesn't know anything about that, therefore it does not
see the schema declaration in the backing XML file. If there were a
schema declaration the editor would automatically do schema validation
on user input. My question was whether it is possible to tell the editor
programmatically against which schema to validate... because it only
sees the XML snippet, and no schema declaration at all.
I hope i could clarify my scenario :-)
Ömer
lmandel@ca.ibm.com schrieb:
>> Best regards,
>> Ömer
> Hi Ömer,
> Lawrence
Re: Validating an XML snippet against a default schema, without referencing it [message #200176 is a reply to message #200168] Fri, 21 September 2007 04:30 Go to previous messageGo to next message
Sorry, there's an error in my first sentence.
I meant that, the WST XML editor is opened *with* a custom IEditorInput,
which returns a specific snippet of an XML document.
Best regards
Ömer Yildiz schrieb:
> Hi Lawrence,
> Best regards,
> Ömer
>>> Hi,
>>> Best regards,
>>> Ömer
>> Hi Ömer,
>> from which you want to invoke validation, that the WST XML editor
>> isn't validating your document, something else? The more details the
>> better.
>> Lawrence
Re: Validating an XML snippet against a default schema, without referencing it [message #200355 is a reply to message #200176] Mon, 24 September 2007 00:38 Go to previous message
Hi Ömer,
The XML editor delegates to the XML validator for validation. As you've
said, the validator needs to be able to find a schema for the XML document
- in your case fragment. Does your fragment use namespaces? If so, have
you tried registering schemas for your namespaces in the XML catalog?
(Window->Preferences->Web and XML->XML Catalog) This can be done
programmatically or manually.
Lawrence
Previous Topic:Using EJB client classes in an RCP application
Next Topic:Design view with WTP?
Current Time: Sun Nov 02 15:23:45 EST 2025
Powered by FUDForum. Page generated in 0.03230 seconds
