Home » Eclipse Projects » Eclipse Platform » How to get the Eclipse directory path?
How to get the Eclipse directory path? [message #199919] Mon, 23 February 2004 11:37 Go to next message
Originally posted by: cjammer.earthlink.net
I'm looking for a quick and reliable way of getting both the Eclipse
directory and the plugin directory. Presumably, the Eclipse directory is
the parent of the plugins directory, but this is not always the case.
I need this to work on Eclipse 2.1.1 or 2.1.2.
If I try something like:
Platform.getPlugin("org.eclipse.runtime.core").getStateLocation();
I see this error:
java.lang.NoClassDefFoundError:
org/eclipse/core/internal/boot/DelegatingURLClassLoader
Same error with:
Platform.getLocation();
and
Platform.getPluginRegistry();
What's the standard way of finding (for example) "C:\eclipse2.1.1"
or "C:\eclipse2.1.1\plugins" from inside a custom install handler
that extends BaseInstallHandler?
Re: How to get the Eclipse directory path? [message #200095 is a reply to message #199919] Mon, 23 February 2004 14:49 Go to previous messageGo to next message
Hey, I got it working... turns out I was missing org.eclipse.core.boot.
> I see this error:
> Same error with:
> and
> What's the standard way of finding (for example) "C:eclipse2.1.1"
> or "C:eclipse2.1.1plugins" from inside a custom install handler
Re: How to get the Eclipse directory path? [message #200103 is a reply to message #199919] Mon, 23 February 2004 14:49 Go to previous messageGo to next message
Originally posted by: cjammer2.earthlink.net
Ok, I got it working... turns out I was missing org.eclipse.core.boot
> I see this error:
> Same error with:
> and
Re: How to get the Eclipse directory path? [message #200479 is a reply to message #199919] Mon, 23 February 2004 21:28 Go to previous message
Originally posted by: pascal.rapicault.ibm
BootLoader.getInstallURL()
PaScaL
> I see this error:
> Same error with:
> and
Previous Topic:Can an EditorActionBarContributor contribute to your plugin's menus?
Next Topic:Can a menu item be enabled when an editor is inactive but at the top?
Current Time: Thu Oct 30 17:32:04 EDT 2025
Powered by FUDForum. Page generated in 0.24960 seconds
