Home » Newcomers » Newcomers » Build numbers
Build numbers [message #199761] Thu, 15 March 2007 15:59 Go to next message
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
Is there a way of getting eclipse to generate auto-incrementing version
or build numbers, as many IDE's do? The build number should increment
either every time I make a change and run, or at least every time I use
the "export" command to generate a .jar or .war file.
Ideally, they would somehow be written into the .war and .jar files I'm
exporting, but even if that can't be done, it would be nice to have them
stored and available somewhere in the eclipse UI so I can help track
versions and modifications without going to a full-blown source code
control system.
If this is something that can be scripted within eclipse, that would be
ok too, but I have no intention of learning to use ant to do my builds,
just to get this functionality.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: Build numbers [message #199789 is a reply to message #199761] Thu, 15 March 2007 17:31 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
David,
it's not directly available as an option, but is easy to do:
Please add a custom ANT builder, and create a build.xml file that will
call BuildNumber task. This task will store build number in a properties
file and update it every time it's called. If you want the build number
to be increased every time, Eclipse performs build (eg. every file
save), you also have to indicate this in builder options.
Finally properties file can be included in your .jar file or anywhere
you want and accessed like any other properties.
In your project properties, on Builders tab add new builder, choose Ant
Build, and choose your Build file.
build.xml might look like:
<?xml version="1.0"?>
<project name="project" default="default">
<target name="default">
<buildnumber file="file.with.buildnumber.properies"/>
</target>
</project>
Please let me know if you have any further questions.
> control system.
Re: Build numbers [message #199823 is a reply to message #199789] Thu, 15 March 2007 19:59 Go to previous messageGo to next message
I'll give that a shot and post back if I have any trouble; thanks!!
In article <etcdvh$1p6$1@utils.eclipse.org>, jacek.pospychala@pl.ibm.com
says...
> David,
> </target>
> </project>
> > control system.
Re: Build numbers [message #199858 is a reply to message #199823] Fri, 16 March 2007 11:05 Go to previous messageGo to next message
Ok, I got a build number the very first time after I set this up, but
not since, and I tried recreating the build, and again it worked the
first time, but isn't running again when I change code and save. Here
is what I have:
I made a builder called "BuildNumberBuilder", specifying C:\PROJECTS
\workspace3.2.1\eddSrv\eddSrv.build.xml as my buildfile. Under build
options, I selected "Specify working set of relevant resources", and
selected the top-level project "eddSrv" as the resource. I also told it
to refresh the project contents after a build. Now when I change a
class and save it, I don't get a build number increment.
What am I missing in my setup? I did a bit of googling about Ant, but
couldn't find anything that helped; there isn't enough detail about how
to set things up in the buildfile, and especially not enough examples.
eddSrv.build.xm:
<project name="eddSrv" default="default">
<buildnumber
file="C:/PROJECTS/workspace3.2.1/eddSrv/eddSrv.build.number "/>
</target>
</project>
eddSrv.build.number:
#Build Number for ANT. Do not edit!
#Fri Mar 16 10:53:56 EDT 2007
build.number=2
In article <MPG.2063a807e4a189089896de@news.eclipse.org>,
ns_dkerber@ns_WarrenRogersAssociates.com says...
> says...
> > David,
> > </target>
> > </project>
> > > control system.
Re: Build numbers [message #199963 is a reply to message #199858] Fri, 16 March 2007 18:44 Go to previous messageGo to next message
In your ANT builder properties, go to "Targets" tab and set "Auto Build"
target.
> is what I have:
> eddSrv.build.xm:
> <buildnumber
> </target>
> </project>
> build.number=2
>> says...
>>> David,
>>> </target>
>>> </project>
>>>> control system.
Re: Build numbers [message #200108 is a reply to message #199963] Sat, 17 March 2007 15:57 Go to previous message
That did it; thanks!
In article <etf6kd$e11$1@utils.eclipse.org>, jacek.pospychala@pl.ibm.com
says...
> target.
> > is what I have:
Previous Topic:getFontRegistry problem
Next Topic:Problem with XMLConfiguration
Current Time: Tue Jul 01 13:38:57 EDT 2025
Powered by FUDForum. Page generated in 0.10848 seconds
