Warnings being interpreted as errors [message #199652] |
Fri, 17 August 2007 06:04  |
Hello there,
I'm having an annoying problem with Eclipse Europa CDT on windows using
cygwin. It happens with either the internal builder or the make builder.
Below is an excerpt from the console output. The problem I'm having is
that even though the particular source file compiles correctly, some of
the warning info is being interpreted by Eclipse as errors. Please excuse
the overuse of templates, the design isn't mine :)
The lines beginning ../TerrainImportHandler.hpp:117: and
../TerrainImportHandler.hpp:1120:, with the message 'instantiated from'
followed by a method signature, show up in the problems view as errors
when actually they're just giving extra information about the following
warning. Is there anywhere I can configure them to be warnings? I know I
can filter them out in the problems view if I want but this is only a
partial solution.
Thanks for any help, the console output follows,
Phil
Building file: ../GDMFacade.cpp
Invoking: Cygwin C++ Compiler
g++ -D_LIB -I../../../include -I../../../thirdparty/includes
-I"C:\p_wingfield\GEDIS\source\InternalUtilities"
-I"C:\cygwin\usr\include" -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP
-MF"GDMFacade.d" -MT"GDMFacade.d" -o"GDMFacade.o" "../GDMFacade.cpp"
In file included from ../GDMFacade.cpp:16:
../TerrainImportHandler.hpp: In instantiation of
`gedis::gdm::ASCDataStore<gedis::gdm::CTerrainPoint>':
../TerrainImportHandler.hpp:117: instantiated from
`gedis::gdm::CTerrainImportHandler<gedis::gdm::CTerrainPoint >'
../GDMFacade.hpp:134: instantiated from here
../TerrainImportHandler.hpp:1068: warning: `class
gedis::gdm::ASCDataStore<gedis::gdm::CTerrainPoint>' has virtual functions
but non-virtual destructor
../GDMFacade.hpp:163:33: warning: no newline at end of file
`gedis::gdm::ASCTile<gedis::gdm::CTerrainPoint>':
../TerrainImportHandler.hpp:1120: instantiated from
`boost::shared_ptr<const gedis::gdm::CGridObject<PointType> >
gedis::gdm::ASCDataStore<StorageType>::GetTile(const
gedis::CLatLongCoord&) [with StorageType = gedis::gdm::CTerrainPoint]'
../GDMFacade.cpp:266: instantiated from here
../TerrainImportHandler.hpp:829: warning: `class
gedis::gdm::ASCTile<gedis::gdm::CTerrainPoint>' has virtual functions but
../../../include/GEDIS_GDM_If.hpp:347: warning: inline function
`gedis::gdm::CBitmapPoint::CBitmapPoint(unsigned char, unsigned char,
unsigned char, unsigned char)' used but never defined
Finished building: ../GDMFacade.cpp
Re: Warnings being interpreted as errors [message #199776 is a reply to message #199652] |
Mon, 20 August 2007 12:27  |
> partial solution.
You would have to edit the source for the error parser. It's not a
configuration problem. The error parser is incorrectly parsing the
output and thinks your warnings are errors.. You should open a Bugzilla
for this problem.
Chris Recoskie
Team Lead, IBM CDT Team
IBM Toronto
http://www.eclipse.org/cdt
FUDForum. Page generated in 0.03511 seconds
