Home » Eclipse Projects » Eclipse Platform » lock file in metadata remains after shutdown
lock file in metadata remains after shutdown [message #199322] Sun, 22 February 2004 11:34 Go to next message
I'm wondering if this is a simply "bug", or a change in design.
I have some automatic programs used to "test the workbench" each of which
are invoked, one after the other, in a .bat file.
I used to have some logic in there so that one test wouldn't start until
the last one ended, and it detected that one had ended by the fact that the
lock file was "gone".
It seems for several milestones, at least, the lock file is always there.
I guess Eclipse itself somehow knows to look at date/time stamp ... or is
there now some other "lock file" that prevents two workbenchs starting on
the same workspace?
Re: lock file in metadata remains after shutdown [message #199390 is a reply to message #199322] Sun, 22 February 2004 15:16 Go to previous messageGo to next message
Originally posted by: dj_houghton.nospam.ca.ibm.com
The code has changed in the 3.0 stream to use the FileLock class
available in JDK 1.4 and therefore existance of the file is not checked,
it is whether or not you can create an exclusive file lock on the file.
> which are invoked, one after the other, in a .bat file.
> the lock file was "gone".
> is there now some other "lock file" that prevents two workbenchs
> starting on the same workspace?
> Thanks
Re: lock file in metadata remains after shutdown [message #199436 is a reply to message #199390] Sun, 22 February 2004 16:13 Go to previous messageGo to next message
On Sun, 22 Feb 2004 15:16:38 -0500, DJ Houghton
Ok, thanks, that's very helpful.
Pardon my lack of Windows knowledge, if this is in fact common knowledge
.... but is there an easy why to tell from a .bat file if a file is locked?
[I can see in your code how to do it from Java, but would prefer not to
start a VM just to determine if its locked].
Re: lock file in metadata remains after shutdown [message #199780 is a reply to message #199436] Mon, 23 February 2004 09:22 Go to previous message
Sorry, I don't know.
>> checked, it is whether or not you can create an exclusive file lock on
>> the file.
> locked? [I can see in your code how to do it from Java, but would prefer
> not to start a VM just to determine if its locked].
Previous Topic:Re: [eclipse-dev] hand over system properties ( java -Dx=y ) to e clipse exe?
Next Topic:Reading XML api
Current Time: Sat Nov 08 04:07:39 EST 2025
Powered by FUDForum. Page generated in 0.03310 seconds
