JDT init hook [message #198535] |
Mon, 14 March 2005 20:00  |
Originally posted by: wharley.bea.com
I'm working on a plugin that adds Java annotation processing to the JDT. I
need a way to initialize my plugin and register some listeners. Ideally I
would do this at the same time that the JDT is loaded, since this
functionality is only useful in the context of Java but it is potentially
needed any time a Java file is compiled.
Is there a particular extension point that I should extend, to hook JDT
initialization? So far I haven't found anything that looks right.
Walter Harley
BEA Systems, Inc.
Re: JDT init hook [message #198695 is a reply to message #198607] |
Tue, 15 March 2005 16:53  |
"Tobias Widmer" <tobias_widmer@ch.ibm.com> wrote in message
news:d173vj$fnv$1@www.eclipse.org...
> Use the methods BundleActivator#start / stop of your plugin class. If you
> have set a dependency on a JDT plugin, your initialization code is
> guaranteed to be executed after the JDT plugin has been initialized.
Thanks, Tobias.
However, maybe I'm confused? I thought that BundleActivator#start would get
called when the plugin is loaded; but that it does not itself *cause* the
plugin to be loaded. In other words, if plugin B depends on plugin A,
plugin B is still not going to get loaded until plugin A actually makes a
call to it for some reason.
Am I wrong about that? Does merely declaring a dependency cause my plugin
to be loaded whenever the plugin it depends on is loaded?
If I'm not wrong, then my question remains: what should I extend, in order
to get my plugin to be loaded when the JDT is initialized?
FUDForum. Page generated in 0.04041 seconds
