| UTF8 encoding [message #198515] |
Mon, 20 August 2007 08:27  |
Hi People,
I'm developing a plugin, that writes xml files. Since I'm not using xerces
or any other xml API I have a problem dealing with Unicode characters. For
instance the german "Ö" will be written like "À". But I need the
decompsoed form like "\u006F". Is there any class in the webtools that
could do this transformation?
Kind regards,
Klaus
| Re: UTF8 encoding [message #198835 is a reply to message #198515] |
Wed, 22 August 2007 22:35  |
Just to be sure, you do know you don't need XML APIs to read and write UTF-8, right?
There are plain 'ol Java io API's where you can specify the charset to use.
Also, one step better :) if you are using Eclipse IFile's, they have some capabilities
to automatically detect and use the appropriate charset, depending on the IFile's contentType.
Hope that helps,
FUDForum. Page generated in 0.05932 seconds
