Home » Language IDEs » C / C++ IDE (CDT) » Error launching scanner info generator... Again !
Error launching scanner info generator... Again ! [message #198426] Fri, 27 July 2007 04:13 Go to next message
Originally posted by: boris_de_bossoreille.hotmail.com
Hi all,
Sorry if the question is too much repeated... Anymay I haven t found any
solution corresponding to my configuration :
I'm trying to configure Eclipse to program and Debug a MSP430 (Texas
Instrument µC)... Anyway, this warning appears every times I Create a new
project :
error launching external scanner info generator (gcc -E -P -v -dD
C:/NATATION/Eclipse/Workspace/.metadata/.plugins/org.eclipse .cdt.make.core/specs.cpp
Does anybody reached this problem ???
Platform : Ecplise-sdk-3.1.2-win32
Plugin : org.eclipse.cdt-3.0.2-win32x86 and net.sf.mspgcc
Compiler : mspgcc-20060119
Thx
Bobish
Re: Error launching scanner info generator... Again ! [message #198467 is a reply to message #198426] Fri, 27 July 2007 11:08 Go to previous messageGo to next message
Bobish wrote:
> Hi all,
> new project :
> Thx
> Bobish
Sorry if there is another thread on this which I either haven't read or
forgotten, but is the gcc from MSPGCC in your path?
Is it called gcc or mspgcc? (It's been a while since I used MSPGCC so
you'll have to forgive me for asking).
If your executable is not called GCC then you'll have to modify the
scanner info command, or disable scanner info generation.
Chris Recoskie
Team Lead, IBM CDT Team
IBM Toronto
http://www.eclipse.org/cdt
Re: Error launching scanner info generator... Again ! [message #198498 is a reply to message #198467] Fri, 27 July 2007 11:28 Go to previous message
Oups ! I yhink you are right. I have verified the path of mspgcc with the
dos cmd and it is mspgcc. I am going to try
Previous Topic:Newbie questions
Next Topic:Default CDT Debugger window setup
Current Time: Wed Apr 16 13:27:32 EDT 2025
Powered by FUDForum. Page generated in 0.03976 seconds
