Visual Editor plugin problem! [message #198410] |
Fri, 20 February 2004 13:09 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jumamurat.web.de
Hello everyone!
I installed Visual Editor plugin. and there was no error. I just
unzipped it to eclipse home folder. and everything is showing up in Help
as it should. but i want to use it is not showing up in any place. So i
found out that i need EMF build 1.1.1 and GEF Build 2.1.2. But i need
earlier versions of both these plugins for OMONDO UML plugin I don't
know what to do. then i installed both emf and gef with 2
versions(stupid solution) but in this case eclipse complained that for
Visual Editor i need later versions of emf and Gef even though they were
also installed. I couldn't find a way to use both of this plugins
together. I am using eclipse2.1.2 Linux. Any idea?
Regards, J. Bayjan!
Re: Visual Editor plugin problem! [message #198522 is a reply to message #198410] |
Fri, 20 February 2004 15:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
You need to have separate installations. One for OMONDO and one for VE.
They just have incompatible requirements.
Though have you tried the newer versions only for OMONDO. I don't know
how back-level it is, but it may work with the newer versions.
Thanks, Rich Kulp
Re: Visual Editor plugin problem! [message #200836 is a reply to message #198522] |
Tue, 24 February 2004 13:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thank you! I have tried to make them work together. But if it is
ultimate soltuion then i should install seperate installations of
eclipse! Somehow i wanted them work together, which would be nice!
Regards, J. Bayjan!
FUDForum. Page generated in 0.01933 seconds
