Home » Archived » BIRT » NullPointerException in buildDataSource
NullPointerException in buildDataSource [message #198331] Mon, 30 October 2006 09:51 Go to next message
Originally posted by: mauricio.sag.com.br
I am trying to use to create the DataSource as in the example:
http://wiki.eclipse.org/index.php/Dynamic_Table
But this occurring the following error:
at design.GeraArquivo.buildDataSource(GeraArquivo.java:167)
This is the code that I am using:
164 public void buildDataSource() throws SemanticException {
165 OdaDataSourceHandle dsHandle = reportFactory.newOdaDataSource(
166 "Data Source", "org.eclipse.birt.report.data.oda.jdbc");
167 dsHandle.setProperty("odaDriverClass", "org.firebirdsql.jdbc.FBDriver");
Somebody could help me?
Debtor for the attention.
Re: NullPointerException in buildDataSource [message #198484 is a reply to message #198331] Tue, 31 October 2006 15:04 Go to previous messageGo to next message
Does this driver exist in the drivers directory?
Jason
"M.c.P." <mauricio@sag.com.br> wrote in message
news:ei53gl$l3j$1@utils.eclipse.org...
> Hi
> java.lang.NullPointerException
Re: NullPointerException in buildDataSource [message #198579 is a reply to message #198484] Tue, 31 October 2006 18:55 Go to previous messageGo to next message
Originally posted by: home4slc.pacbell.net
I was trying to run this example as well and I am using the code that is
on the wiki (the standard oda driver class, not Firebird.)
I've been trying to debug this - I'm new to BIRT so I apologize ahead of
time if some of the below is obvious to folks, but if someone could
explain what is happening to help me learn, I'd be most appreciative.
I'm getting a NullPointerException at this line in the
DECreateDynamicTable.java code;
dsHandle = designFactory.newOdaDataSource(
"Data Source", "org.eclipse.birt.report.data.oda.jdbc" );
It appears to me that in the newOdaDataSource method of
org.eclipse.birt.report.model.api.ElementFactory.java
that this line of code is returning null;
if ( ODAProviderFactory.getInstance( ).createODAProvider( null,
extensionID ) == null )
from there it appears that the instance of ODAProviderFactory is being
creataed, but the NullPointerException is occuring when the
createODAProvider method is being called.
The createODAProvider method relies on the baseFactory variable, an
IODAProviderFactory being initialized via the initeTheFactory method
being called.
The only place I can see where this method is called is in
org.eclipse.birt.report.model.plugin.ModelPlugin, and when I try to
debug the program it never appears to be called.
So, if what I have said above is correct, what calls the ModelPlugin's
start method, which is where the initeTheFactory method is called?
Also, if this is a bug I'd be happy to log it in bugzilla, just let me
know please.
I'm using BIRT 2.1.1.
Susan
> Jason
>>Hi
Re: NullPointerException in buildDataSource [message #198611 is a reply to message #198484] Wed, 01 November 2006 06:40 Go to previous messageGo to next message
yes, i use it in the connection of my application.
Jason Weathersby escreveu:
> Jason
>> Hi
Re: NullPointerException in buildDataSource [message #198619 is a reply to message #198579] Wed, 01 November 2006 07:28 Go to previous messageGo to next message
I already wrote this in bugzila:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162877
Thanks!
Susan Cline escreveu:
> being called.
> know please.
> Susan
>> Jason
>>> Hi
Re: NullPointerException in buildDataSource [message #198808 is a reply to message #198619] Thu, 02 November 2006 15:03 Go to previous messageGo to next message
What are you setting your BIRT HOME to?
Jason
news:eia3tf$eca$1@utils.eclipse.org...
> Thanks!
>> being called.
>> org.eclipse.birt.report.model.plugin.ModelPlugin, and when I try to debug
>> know please.
>> Regards,
>> Susan
>>> Jason
>>>> Hi
Re: NullPointerException in buildDataSource [message #198914 is a reply to message #198808] Thu, 02 November 2006 20:15 Go to previous messageGo to next message
--------------080608010400090506050803
Content-Type: text/plain; charset=us-ascii; format=flowed
Hi Jason,
Regarding BIRT_HOME the first time I ran the example I figured out this
needed to be set, however, I am pointing only to the runtime. Does it
need to point to the full BIRT eclipse install?
I will make comments to the wiki page after I get it running, because I
believe the instructions can be improved upon for others.
Here is my BIRT_HOME:
config.setProperty("BIRT_HOME",
"C:/projects/BIRT/downloads/birt-runtime-2_1_1/ReportEngine");
C:\Documents and Settings\Administrator>dir
C:\projects\BIRT\downloads\birt-runt
ime-2_1_1\ReportEngine
Volume in drive C has no label.
Volume Serial Number is 8017-F8A8
Directory of C:\projects\BIRT\downloads\birt-runtime-2_1_1\ReportEngine
10/31/2006 03:40 PM <DIR> .
10/31/2006 03:40 PM <DIR> ..
10/31/2006 03:40 PM <DIR> configuration
09/26/2006 10:44 AM 1,485 genReport.bat
09/26/2006 10:44 AM 1,105 genReport.sh
10/16/2006 11:08 AM <DIR> lib
10/16/2006 11:09 AM <DIR> plugins
10/16/2006 11:08 AM <DIR> samples
10/31/2006 11:45 AM <DIR> workspace
2 File(s) 2,590 bytes
7 Dir(s) 58,010,800,128 bytes free
Which plugin do you suspect is not being found? If it is the plugin
containing ModelPlugin.class, I checked under the BIRT_HOME/plugins
directory and found the
org.eclipse.birt.report.model_2.1.1V20060926-0959.jar file which
contains this class.
I've attached my java class for you to look at and see if you find
anything else if the setting I have for BIRT_HOME is correct.
Also, I did run the SimpleCreate.java program and it ran successfully,
although I realize the second example is more complicated - but at least
my BIRT_HOME was set correctly for the first example.
Susan
> Jason
>>Thanks!
>>>Hi,
>>>being called.
>>>know please.
>>>Regards,
>>>Susan
>>>>Jason
>>>>>Hi
name="DECreateDynamicTable.java"
Content-Disposition: inline;
filename="DECreateDynamicTable.java"
import java.io.IOException;
import java.util.ArrayList;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.model.api.CellHandle;
import org.eclipse.birt.report.model.api.DataItemHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.LabelHandle;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.RowHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.TableHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import org.eclipse.birt.report.model.api.elements.structures.Comput edColumn;
import com.ibm.icu.util.ULocale;
* Dynamic Table BIRT Design Engine API (DEAPI) demo.
public class DECreateDynamicTable
ReportDesignHandle designHandle = null;
ElementFactory designFactory = null;
StructureFactory structFactory = null;
public static void main( String[] args )
try
DECreateDynamicTable de = new DECreateDynamicTable();
ArrayList al = new ArrayList();
al.add("OFFICECODE");
al.add("CITY");
al.add("COUNTRY");
de.buildReport(al, "From Offices" );
catch ( IOException e )
// TODO Auto-generated catch block
e.printStackTrace();
catch ( SemanticException e )
void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle = null;
System.out.println("designFactory is " + designFactory.toString());
System.out.println("dsHandle is " + dsHandle.toString());
dsHandle.setProperty( "odaDriverClass",
"org.eclipse.birt.report.data.oda.sampledb.Driver" );
dsHandle.setProperty( "odaURL", "jdbc:classicmodels:sampledb" );
dsHandle.setProperty( "odaUser", "ClassicModels" );
dsHandle.setProperty( "odaPassword", "" );
designHandle.getDataSources( ).add( dsHandle );
void buildDataSet(ArrayList cols, String fromClause ) throws SemanticException
OdaDataSetHandle dsHandle = designFactory.newOdaDataSet( "ds",
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dsHandle.setDataSource( "Data Source" );
String qry = "Select ";
for( int i=0; i < cols.size(); i++){
qry += " " + cols.get(i);
if( i != (cols.size() -1) ){
qry += ",";
qry += " " + fromClause;
dsHandle.setQueryText( qry );
designHandle.getDataSets( ).add( dsHandle );
void buildReport(ArrayList cols, String fromClause ) throws IOException, SemanticException
//Configure the Engine and start the Platform
DesignConfig config = new DesignConfig( );
config.setProperty("BIRT_HOME", "C:/projects/BIRT/downloads/birt-runtime-2_1_1/ReportEngine");
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
.createFactoryObject( IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
try{
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
//open a design or a template
designHandle = session.openDesign("c:/temp/hello_world.rptdesign");
designFactory = designHandle.getElementFactory( );
catch (Exception e){
System.exit(0);
try {
//designFactory = designHandle.getElementFactory( );
buildDataSource();
buildDataSet(cols, fromClause);
TableHandle table = designFactory.newTableItem( "table", cols.size() );
table.setWidth( "100%" );
table.setDataSet( designHandle.findDataSet( "ds" ) );
PropertyHandle computedSet = table.getColumnBindings( );
ComputedColumn cs1 = null;
cs1 = StructureFactory.createComputedColumn();
cs1.setName((String)cols.get(i));
cs1.setExpression("dataSetRow[\"" + (String)cols.get(i) + "\"]");
computedSet.addItem(cs1);
// table header
RowHandle tableheader = (RowHandle) table.getHeader( ).get( 0 );
LabelHandle label1 = designFactory.newLabel( (String)cols.get(i) );
label1.setText((String)cols.get(i));
CellHandle cell = (CellHandle) tableheader.getCells( ).get( i );
cell.getContent( ).add( label1 );
// table detail
RowHandle tabledetail = (RowHandle) table.getDetail( ).get( 0 );
CellHandle cell = (CellHandle) tabledetail.getCells( ).get( i );
DataItemHandle data = designFactory.newDataItem( "data_"+(String)cols.get(i) );
data.setResultSetColumn( (String)cols.get(i));
cell.getContent( ).add( data );
designHandle.getBody( ).add( table );
// Save the design and close it.
designHandle.saveAs( "c:/temp/sample.rptdesign" ); //$NON-NLS-1$
designHandle.close( );
System.out.println("Finished");
}catch (Exception e){
--------------080608010400090506050803--
Re: NullPointerException in buildDataSource [message #198964 is a reply to message #198914] Fri, 03 November 2006 06:33 Go to previous messageGo to next message
Hi.
I also twirled the first example (SimpleCreate.java) and I functioned
correctly.
Mine birt home is this: config.setProperty (“BIRT_HOME”, “C:
/birtruntime/birt-runtime-2_1_1/ReportEngine”);
It will be that it is problem in BIRT_HOME?
Susan L. Cline escreveu:
> Hi Jason,
> Susan
>> Jason
>>> Thanks!
>>>> Hi,
>>>> that is on the wiki (the standard oda driver class, not Firebird.)
>>>> ahead of time if some of the below is obvious to folks, but if
>>>> someone could explain what is happening to help me learn, I'd be
>>>> most appreciative.
>>>> "Data Source",
>>>> being creataed, but the NullPointerException is occuring when the
>>>> being called.
>>>> ModelPlugin's start method, which is where the initeTheFactory
>>>> method is called?
>>>> me know please.
>>>> Regards,
>>>> Susan
>>>>> Jason
>>>>>> Hi
> try
> al.add("CITY");
> al.add("COUNTRY");
> qry += ",";
> try{
> try{
> System.exit(0);
> try {
> buildDataSource();
> // table header
> // table detail
Re: NullPointerException in buildDataSource [message #199033 is a reply to message #198964] Fri, 03 November 2006 14:51 Go to previous messageGo to next message
Jason helped me with this. Our BIRT_HOME is set fine, but what I did
not know (and the wiki entry does not mention it) is when you run the
application from Eclipse, all of the libraries under BIRT_HOME/lib must
be included in the Build Path for the project.
So in my environment, my BIRT_HOME was set to this:
so I added all of these jars to my Java Build Path in Eclipse;
chartengineapi.jar
com.ibm.icu_3.4.4.1.jar
commons-cli-1.0.jar
commons-codec-1.3.jar
coreapi.jar
dataadapterapi.jar
dteapi.jar
engineapi.jar
flute.jar
js.jar
modelapi.jar
org.eclipse.emf.common_2.2.0.v200606051102.jar
org.eclipse.emf.ecore.xmi_2.2.0.v200606051102.jar
org.eclipse.emf.ecore_2.2.0.v200606051102.jar
sac.jar
scriptapi.jar
I'll update the wiki page for this example to be more explicit about a)
setting BIRT_HOME for your machine, b) which reports have to exist
before hand and which one is created, and c) which jar files need to be
in the Eclipse Build Path.
Susan
M.c.P. wrote:
> Hi.
> correctly.
>> Hi Jason,
>> this needed to be set, however, I am pointing only to the runtime.
>> Does it need to point to the full BIRT eclipse install?
>> I believe the instructions can be improved upon for others.
>> least my BIRT_HOME was set correctly for the first example.
>> Regards,
>> Susan
>>> Jason
>>>> Thanks!
>>>>> Hi,
>>>>> most appreciative.
>>>>> "Data Source",
>>>>> method being called.
>>>>> method is called?
>>>>> me know please.
>>>>> Regards,
>>>>> Susan
>>>>>> Jason
>>>>>>> Hi
>> import org.eclipse.birt.report.model.api.DesignConfig; import
>> import
>> try
>> al.add("CITY");
>> al.add("COUNTRY");
>> SemanticException
>> qry += ",";
>> try{
>> Platform
>> try{
>> ULocale.ENGLISH ) ;
>> designHandle =
>> System.exit(0);
>> try {
>> buildDataSource();
>> cols.size() );
>> table.getColumnBindings( ); ComputedColumn cs1 = null;
>> // table header
>> ).get( 0 );
>> ).get( i );
>> // table detail
>> ).get( 0 );
>> ).get( i );
>> //$NON-NLS-1$
Re: NullPointerException in buildDataSource [message #199062 is a reply to message #199033] Fri, 03 November 2006 15:08 Go to previous messageGo to next message
Thanks Susan
"Susan Cline" <home4slc@pacbell.net> wrote in message
news:eig6js$38e$1@utils.eclipse.org...
> Jason helped me with this. Our BIRT_HOME is set fine, but what I did not
> application from Eclipse, all of the libraries under BIRT_HOME/lib must be
> chartengineapi.jar
> commons-cli-1.0.jar
> coreapi.jar
> dataadapterapi.jar
> dteapi.jar
> engineapi.jar
> flute.jar
> js.jar
> modelapi.jar
> sac.jar
> scriptapi.jar
> setting BIRT_HOME for your machine, b) which reports have to exist before
> hand and which one is created, and c) which jar files need to be in the
> Eclipse Build Path.
> Susan
> M.c.P. wrote:
>> Hi.
>> correctly.
Re: NullPointerException in buildDataSource [message #199388 is a reply to message #199062] Mon, 06 November 2006 14:38 Go to previous messageGo to next message
> Thanks Susan
>> chartengineapi.jar
>> commons-cli-1.0.jar
>> coreapi.jar
>> dataadapterapi.jar
>> dteapi.jar
>> engineapi.jar
>> flute.jar
>> js.jar
>> modelapi.jar
>> sac.jar
>> scriptapi.jar
>> Eclipse Build Path.
>> Thanks,
>> Susan
>> M.c.P. wrote:
>>> Hi.
>>> correctly.
>>>> Hi Jason,
>>>> Regards,
>>>> Susan
>>>>> Jason
>>>>>> Thanks!
>>>>>>> Hi,
>>>>>>> of time if some of the below is obvious to folks, but if someone
>>>>>>> could explain what is happening to help me learn, I'd be most
>>>>>>> appreciative.
>>>>>>> "Data Source",
>>>>>>> being called.
>>>>>>> ModelPlugin's start method, which is where the initeTheFactory method
>>>>>>> is called?
>>>>>>> me know please.
>>>>>>> Regards,
>>>>>>> Susan
>>>>>>>> Jason
>>>>>>>>> Hi
>>>> import
>>>> StructureFactory structFactory = null; public static void main(
>>>> String[] args )
>>>> try
>>>> al.add("CITY");
>>>> al.add("COUNTRY");
>>>> "Data Source",
>>>> SemanticException
>>>> qry += ",";
>>>> try{
>>>> Platform
>>>> try{
>>>> ULocale.ENGLISH ) ;
>>>> designHandle =
>>>> System.exit(0);
>>>> try {
>>>> buildDataSource();
>>>> // table header
>>>> (String)cols.get(i) ); label1.setText((String)cols.get(i));
>>>> } // table detail
>>>> //$NON-NLS-1$
Thanks for the aid, but, I tried to use the classroom of wiki and the
error continues the same, I mattered to.jar them that you it cited and I
conferred the BIRT_HOME, and exactly thus… continues the
NullPointerException.
It has something that I am making made a mistake?
It would have something more than I forgot to make?
public void build( )
try
al.add("CODIPESS");
al.add("FANTPESS");
al.add("CODICIDA");
de.buildReport(al, "From POCAPESS" );
OdaDataSourceHandle dsHandle = designFactory.newOdaDataSource(
"org.firebirdsql.jdbc.FBDriver" );
SemanticException
qry += ",";
"C:/birtruntime/birt-runtime-2_1_1/ReportEngine");
try{
try{
designHandle = session.openDesign("d:/temp/teste.rptdesign");
buildDataSource();
// table header
// table detail
designHandle.saveAs( "d:/temp/hoho.rptdesign" ); //$NON-NLS-1$
Re: NullPointerException in buildDataSource [message #199395 is a reply to message #199388] Mon, 06 November 2006 14:08 Go to previous messageGo to next message
I'm not sure I can help if it is an odaDriverClass problem (since you
are using firebird), but I would suggest running the example with the
standard odaDriverClass first just to see if you can get this working.
So change this line of your code:
to this:
If this works, at least you know you have everything correct for the
standard driver and then you can try to troubleshoot the other problem.
Susan
>> Thanks Susan
>>> Hi,
>>> must be included in the Build Path for the project.
>>> chartengineapi.jar
>>> commons-cli-1.0.jar
>>> coreapi.jar
>>> dataadapterapi.jar
>>> dteapi.jar
>>> engineapi.jar
>>> flute.jar
>>> js.jar
>>> modelapi.jar
>>> sac.jar
>>> scriptapi.jar
>>> a) setting BIRT_HOME for your machine, b) which reports have to exist
>>> be in the Eclipse Build Path.
>>> Thanks,
>>> Susan
>>> M.c.P. wrote:
>>>> Hi.
>>>> functioned correctly.
>>>>> Hi Jason,
>>>>> because I believe the instructions can be improved upon for others.
>>>>> Directory of
>>>>> plugin containing ModelPlugin.class, I checked under the
>>>>> BIRT_HOME/plugins directory and found the
>>>>> successfully, although I realize the second example is more
>>>>> complicated - but at least my BIRT_HOME was set correctly for the
>>>>> first example.
>>>>> Regards,
>>>>> Susan
>>>>>> Jason
>>>>>>> Thanks!
>>>>>>>> Hi,
>>>>>>>> most appreciative.
>>>>>>>> "Data Source",
>>>>>>>> the createODAProvider method is being called.
>>>>>>>> an IODAProviderFactory being initialized via the initeTheFactory
>>>>>>>> to debug the program it never appears to be called.
>>>>>>>> method is called?
>>>>>>>> let me know please.
>>>>>>>> Regards,
>>>>>>>> Susan
>>>>>>>>> Jason
>>>>>>>>>> Hi
>>>>> import
>>>>> try
>>>>> al.add("CITY");
>>>>> al.add("COUNTRY");
>>>>> "Data Source",
>>>>> SemanticException
>>>>> qry += ",";
>>>>> try{
>>>>> Platform
>>>>> try{
>>>>> ULocale.ENGLISH ) ;
>>>>> designHandle =
>>>>> System.exit(0);
>>>>> try {
>>>>> buildDataSource();
>>>>> cols.size() );
>>>>> // table header
>>>>> ).get( 0 );
>>>>> } // table detail
>>>>> ).get( 0 );
>>>>> //$NON-NLS-1$
> Thanks
> import
> try
> al.add("CODIPESS");
> al.add("FANTPESS");
> al.add("CODICIDA");
> SemanticException
> qry += ",";
> try{
> try{
> buildDataSource();
> cols.size() );
> // table header
> 0 );
> ).get( i );
> // table detail
> 0 );
> ).get( i );
Re: NullPointerException in buildDataSource [message #199408 is a reply to message #199395] Mon, 06 November 2006 15:24 Go to previous messageGo to next message
Hi.
You it could order its project to me?
so that I can use I eat example, since its functioned correctly.
> to this:
> Susan
>>> Thanks Susan
>>>> Hi,
>>>> did not know (and the wiki entry does not mention it) is when you
>>>> run the application from Eclipse, all of the libraries under
>>>> BIRT_HOME/lib must be included in the Build Path for the project.
>>>> chartengineapi.jar
>>>> commons-cli-1.0.jar
>>>> coreapi.jar
>>>> dataadapterapi.jar
>>>> dteapi.jar
>>>> engineapi.jar
>>>> flute.jar
>>>> js.jar
>>>> modelapi.jar
>>>> sac.jar
>>>> scriptapi.jar
>>>> exist before hand and which one is created, and c) which jar files
>>>> need to be in the Eclipse Build Path.
>>>> Thanks,
>>>> Susan
>>>> M.c.P. wrote:
>>>>> Hi.
>>>>>> Hi Jason,
>>>>>> runtime. Does it need to point to the full BIRT eclipse install?
>>>>>> Directory of
>>>>>> first example.
>>>>>> Regards,
>>>>>> Susan
>>>>>>> Jason
>>>>>>>> Thanks!
>>>>>>>>> Hi,
>>>>>>>>> code that is on the wiki (the standard oda driver class, not
>>>>>>>>> Firebird.)
>>>>>>>>> "Data Source",
>>>>>>>>> is being creataed, but the NullPointerException is occuring
>>>>>>>>> when the createODAProvider method is being called.
>>>>>>>>> variable, an IODAProviderFactory being initialized via the
>>>>>>>>> initeTheFactory method being called.
>>>>>>>>> try to debug the program it never appears to be called.
>>>>>>>>> method is called?
>>>>>>>>> let me know please.
>>>>>>>>> Regards,
>>>>>>>>> Susan
>>>>>>>>>> Jason
>>>>>>>>>>> Hi
>>>>>> import
>>>>>> try
>>>>>> al.add("CITY");
>>>>>> al.add("COUNTRY");
>>>>>> "Data Source",
>>>>>> SemanticException
>>>>>> "ds",
>>>>>> qry += ",";
>>>>>> try{
>>>>>> Platform
>>>>>> try{
>>>>>> ULocale.ENGLISH ) ;
>>>>>> designHandle =
>>>>>> System.exit(0);
>>>>>> try {
>>>>>> buildDataSource();
>>>>>> cols.size() );
>>>>>> // table header
>>>>>> ).get( 0 );
>>>>>> } // table detail
>>>>>> ).get( 0 );
>>>>>> //$NON-NLS-1$
>> I conferred the BIRT_HOME, and exactly thus… continues the
>> Thanks
>> import
>> try
>> al.add("CODIPESS");
>> al.add("FANTPESS");
>> al.add("CODICIDA");
>> SemanticException
>> qry += ",";
>> try{
>> Platform
>> ULocale.ENGLISH ) ;
>> try{
>> buildDataSource();
>> cols.size() );
>> // table header
>> ).get( 0 );
>> ).get( i );
>> } // table detail
>> ).get( 0 );
>> ).get( i );
>> //$NON-NLS-1$
Re: NullPointerException in buildDataSource [message #199415 is a reply to message #199408] Mon, 06 November 2006 15:28 Go to previous message
Sorry my google english
M.c.P. escreveu:
> Hi.
> Thanks
>> to this:
>> Regards,
>> Susan
>>>> Thanks Susan
>>>>> Hi,
>>>>> chartengineapi.jar
>>>>> commons-cli-1.0.jar
>>>>> coreapi.jar
>>>>> dataadapterapi.jar
>>>>> dteapi.jar
>>>>> engineapi.jar
>>>>> flute.jar
>>>>> js.jar
>>>>> modelapi.jar
>>>>> sac.jar
>>>>> scriptapi.jar
>>>>> about a) setting BIRT_HOME for your machine, b) which reports have
>>>>> to exist before hand and which one is created, and c) which jar
>>>>> files need to be in the Eclipse Build Path.
>>>>> Thanks,
>>>>> Susan
>>>>> M.c.P. wrote:
>>>>>> Hi.
>>>>>>> Hi Jason,
>>>>>>> out this needed to be set, however, I am pointing only to the
>>>>>>> Directory of
>>>>>>> find anything else if the setting I have for BIRT_HOME is correct.
>>>>>>> first example.
>>>>>>> Regards,
>>>>>>> Susan
>>>>>>>> Jason
>>>>>>>>> Thanks!
>>>>>>>>>> Hi,
>>>>>>>>>> Firebird.)
>>>>>>>>>> apologize ahead of time if some of the below is obvious to
>>>>>>>>>> folks, but if someone could explain what is happening to help
>>>>>>>>>> "Data Source",
>>>>>>>>>> method is called?
>>>>>>>>>> just let me know please.
>>>>>>>>>> Regards,
>>>>>>>>>> Susan
>>>>>>>>>>> Jason
>>>>>>>>>>>> Hi
>>>>>>> import
>>>>>>> try
>>>>>>> al.add("CITY");
>>>>>>> al.add("COUNTRY");
>>>>>>> "Data Source",
>>>>>>> SemanticException
>>>>>>> "ds",
>>>>>>> qry += ",";
>>>>>>> try{
>>>>>>> Platform
>>>>>>> try{
>>>>>>> ULocale.ENGLISH ) ;
>>>>>>> designHandle =
>>>>>>> System.exit(0);
>>>>>>> try {
>>>>>>> buildDataSource();
>>>>>>> cols.size() );
>>>>>>> // table header
>>>>>>> ).get( 0 );
>>>>>>> } // table detail
>>>>>>> ).get( 0 );
>>>>>>> //$NON-NLS-1$
>>> and I conferred the BIRT_HOME, and exactly thus… continues the
>>> Thanks
>>> import
>>> StructureFactory structFactory = null; public void build( )
>>> try
>>> al.add("CODIPESS");
>>> al.add("FANTPESS");
>>> al.add("CODICIDA");
>>> "Data Source",
>>> SemanticException
>>> qry += ",";
>>> try{
>>> Platform
>>> ULocale.ENGLISH ) ;
>>> try{
>>> designHandle =
>>> buildDataSource();
>>> cols.size() );
>>> // table header
>>> ).get( 0 );
>>> ).get( i );
>>> } // table detail
>>> ).get( 0 );
>>> ).get( i );
>>> //$NON-NLS-1$
Previous Topic:Using a different data set for header and detail
Next Topic:BIRT performance
Current Time: Fri Sep 12 21:02:22 EDT 2025
Powered by FUDForum. Page generated in 0.07658 seconds
