Home » Newcomers » Newcomers » running editor programatically
running editor programatically [message #198196] Wed, 07 March 2007 10:27 Go to next message
Originally posted by: raushansharma2004.yahoo.com
hi,
i want to know how to run an editor programmatically.
i have written editor in MyEditor class
i have created one toolbar button ,what i require is when this button
is pressed, the editor should be called.can someone give me its solution
Re: running editor programatically [message #198220 is a reply to message #198196] Wed, 07 March 2007 11:06 Go to previous messageGo to next message
Originally posted by: Markus.Bon.qgrp.com
The standard way to open an editor is using openEditor(...) from
org.eclipse.ui.ide.IDE:
IFile myFile = ...
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
IEditorPart editor = IDE.openEditor(page,myFile);
This opens the editor which is associated to the type of file you selected.
If you want to specify the editor to be opened explicitely (e.G. your
MyEditor), you can open the editor with a call like this:
IWorkbenchWindow workbenchWindow =
PlatformUI.getWorkbench().getActiveWorkbenchWindow();
workbenchWindow.getActivePage().openEditor(myFile, editorID, true);
regards
Markus
raushan schrieb:
> hi, i want to know how to run an editor programmatically.
> button is pressed, the editor should be called.can someone give me its
> solution
Re: running editor programatically [message #198248 is a reply to message #198196] Wed, 07 March 2007 12:46 Go to previous message
Charlie Kelly is currently offline Charlie KellyFriend
Hi Raushan,
Inside the run method of an Action that you associate with your toolbar
button, use the following:
IWorkbenchWindow iWorkbenchWindow =
IWorkbenchPage iWorkbenchPage = iWorkbenchWindow.getActivePage();
iWorkbenchPage.openEditor(myEditorInput, MyEditor.ID);
You will need to create a class that extends EditorInput.
Charlie
> solution
Previous Topic:Killing Eclipse does not start even after -clean option
Next Topic:Building workspace in command line
Current Time: Sat Nov 02 20:02:50 GMT 2024
Powered by FUDForum. Page generated in 0.07842 seconds
