FlatFile error on latest runtime engine [message #198139] |
Sat, 28 October 2006 18:37 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: stuart.polonious.com.au
I have been debugging this for hours. Any help greatly appreciated.
We are using the flatfile datasource to merge data from many hibernated
tables to one flat file. This makes birt's life easy (or used to). Now
we are getting an error that is causing problems:
java.lang.ArrayIndexOutOfBoundsException: 461
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.splitSt
ringWithDoubleQuotes(FlatFileQuery.java:901)
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.fetchQu
eriedDataFromRow(FlatFileQuery.java:850)
eriedDataFromFileToVector(FlatFileQuery.java:822)
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.execute
Query(FlatFileQuery.java:161)
To debug this myself, I have tried to download a compatible version of
org.eclipse.datatools.connectivity.oda.flatfile. Would anyone know how
to get the source? The CVS is there for datatools but I'm not sure that
the release tags are? Alternatively, has anyone had this error and fixed
it?
TIA
Stuart
Re: FlatFile error on latest runtime engine [message #198169 is a reply to message #198139] |
Sat, 28 October 2006 21:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
This is the line that is stuffing up:
if(i < chars.length - 1 && chars[i + 2] == '"')
with this:
Anyone?
> at
> at
> at
> at
> it?
> TIA
> Stuart
Re: FlatFile error on latest runtime engine [message #200503 is a reply to message #198247] |
Mon, 13 November 2006 11:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I will try to find it.
Stuart
lzhu wrote:
> Hi Stuart,
> Can you provide the flat file you used which can reproduce the bug? Or it
> would be preferable if you can log a bugzilla entry for it.
> Thanks.
> Lin
> "Stuart Guthrie" <stuart@polonious.com.au> wrote in message
> news:ei0bgd$oap$1@utils.eclipse.org...
>> at
>> at
>> at
>> at
>> it?
>> TIA
>> Stuart
Re: FlatFile error on latest runtime engine [message #201205 is a reply to message #200503] |
Thu, 16 November 2006 11:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I cannot locate this file now. Sorry.
Stuart
> Stuart
> lzhu wrote:
>> Hi Stuart,
>> Thanks.
>> Lin
>>> at
>>> at
>>> at
>>> at
>>> it?
>>> TIA
>>> Stuart
FUDForum. Page generated in 0.04347 seconds
