Home » Eclipse Projects » GEF » Picking up the help documentation
Picking up the help documentation [message #198134] Fri, 07 October 2005 13:04 Go to next message
I am a newbie to eclipse and GEF. I am trying to develop an application
that I am sure could be solved with Draw2d. However, the documentation
is not showing up in my eclipse help as the FAQ describes. The visual
editor documentation shows up; does it override the GEF documentation?
Is there some other unzipping that needs to be done beyond the GEF
download into eclipse?
Re: Picking up the help documentation [message #198141 is a reply to message #198134] Fri, 07 October 2005 13:09 Go to previous messageGo to next message
Originally posted by: colinc.santurcorp.com
user@domain.invalid wrote:
> Hi
> Thanks
Sorry about the user name, I didn't set up the acct in my newsreader.
Colin
Re: Picking up the help documentation [message #198171 is a reply to message #198134] Fri, 07 October 2005 15:19 Go to previous messageGo to next message
You must download a ZIP of GEF that contains the documentation (*.doc.isv).
Did you do this?
<user@domain.invalid> wrote in message news:di69rl$9o4$1@news.eclipse.org...
> Hi
> that I am sure could be solved with Draw2d. However, the documentation is
> not showing up in my eclipse help as the FAQ describes. The visual editor
> documentation shows up; does it override the GEF documentation? Is there
> some other unzipping that needs to be done beyond the GEF download into
> eclipse?
> Thanks
Re: Picking up the help documentation [message #198185 is a reply to message #198171] Fri, 07 October 2005 15:27 Go to previous message
Yes, I have \eclipse\plugins\org.eclipse.gef.doc.isv_3.1.0. This may be
more of an eclipse question than a GEF question. How does eclipse
register the documentation into Help?
> Did you do this?
>>Hi
>>eclipse?
>>Thanks
Previous Topic:SelectAll action use wrong editorPart.
Next Topic:Eclipse RCP Developer Wanted
Current Time: Fri Apr 25 21:14:17 EDT 2025
Powered by FUDForum. Page generated in 0.03290 seconds
