Home » Language IDEs » C / C++ IDE (CDT) » Error Launching the Debugger
Error Launching the Debugger [message #198122] Tue, 24 July 2007 10:10 Go to next message
Originally posted by: losborn.asset-intertech.com
I have installed minggw and cygwin and then I installed Eclipse 3.3 Eroupa
and when I first launched I got a message that the Registery was blocked by
the Administrator. Does Eclipse need to edit the Windows Registery? Next I
built a hello world using the template and it built fine. However when I
launch the debugger I get the following
Error Creating session
Exec error: Launching Failed
Exec error:Launching Failed
Is this related to the Registery message? or is there another problem
THanks in Advance
Larry
Re: Error Launching the Debugger [message #198153 is a reply to message #198122] Tue, 24 July 2007 11:24 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
Eclipse and CDT do *not* touch the registry.
Problems could be:
- debugger is not on your path
- debugger is not called gdb (the CDT default)
Derek
Larry wrote:
> Hello,
> THanks in Advance
> Larry
Re: Error Launching the Debugger [message #198358 is a reply to message #198153] Thu, 26 July 2007 12:36 Go to previous messageGo to next message
Derek,
I have installed MinGW and Cygwin. They are listed first in the path for
windows and I'm using the default settings for Eclipse. Don't both tool
chains ship with gdb?
Larry
"Derek Morris" <dmsubs@NOSPAM.consertum.com> wrote in message
news:f855jh$nds$2@build.eclipse.org...
> Problems could be:
> Derek
> Larry wrote:
>> Hello,
>> Eroupa and when I first launched I got a message that the Registery was
>> blocked by the Administrator. Does Eclipse need to edit the Windows
>> Registery? Next I built a hello world using the template and it built
>> fine. However when I launch the debugger I get the following
>> THanks in Advance
>> Larry
Re: Error Launching the Debugger [message #198366 is a reply to message #198358] Thu, 26 July 2007 12:53 Go to previous messageGo to next message
Yes, but they might not be called "gdb". gdb is normally named something like
aaa-bbb-ccc-gdb or xxx-yyy-gdb. Search for *gdb.exe and see what you find...
Derek
Larry wrote:
> Derek,
> Larry
>> Problems could be:
>> Derek
>> Larry wrote:
>>> Hello,
>>> THanks in Advance
>>> Larry
Re: Error Launching the Debugger [message #198380 is a reply to message #198366] Thu, 26 July 2007 14:18 Go to previous message
Derek,
I found that the default install of the MinGW does not install gdb and that
it has to be installed seperately. I have it working now.
news:f8ajih$euk$1@build.eclipse.org...
> like aaa-bbb-ccc-gdb or xxx-yyy-gdb. Search for *gdb.exe and see what you
> find...
> Derek
> Larry wrote:
>> Derek,
>> Thanks,
>> Larry
>>> Problems could be:
>>> Derek
>>> Larry wrote:
>>>> Hello,
>>>> THanks in Advance
>>>> Larry
Previous Topic:How to connect JTAG tools
Next Topic:Symbol detection
Current Time: Mon Oct 20 02:20:00 EDT 2025
Powered by FUDForum. Page generated in 0.26579 seconds
